Need help for my xbox controler (not wireless)
Hello there
I switched to Garuda Linux several months ago without too much difficulty.
However, I can’t get my xbox controller to work
sdl-jstest --list
No joysticks were found
However, it is correctly detected on the USB
$ lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 003: ID 046d:c31c Logitech, Inc Keyboard K120
Bus 001 Device 004: ID 045e:028e Microsoft Corp. Xbox360 Controller
obviously it’s for games and obviously wine control tells me there’s no controller (steam either, which makes sense)
I try xone-dkms and xone-dkmq-git without succes
I haven’t found a solution on the net but I’m continuing my research. If you have any ideas, I’d love to hear from you :slight_smile:
$ garuda-inxi
  Kernel: 6.10.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=ee04537d-1ba5-4b37-bb9b-96058b943b94 rw rootflags=subvol=@
    quiet resume=UUID=9cd84d9a-a46f-41e5-9325-508c37d075cc loglevel=3 ibt=off
  Desktop: GNOME v: 46.4 tk: GTK v: 3.24.43 wm: gnome-shell
    tools: gsd-screensaver-proxy dm: GDM v: 46.2 Distro: Garuda base: Arch Linux
  Type: Desktop Mobo: Micro-Star model: B450 TOMAHAWK MAX (MS-7C02) v: 1.0
    UEFI: American Megatrends v: 3.40 date: 10/25/2019
    L3: 32 MiB desc: 2x16 MiB
  Speed (MHz): avg: 3682 high: 3959 min/max: 2200/4208 boost: enabled
    scaling: driver: acpi-cpufreq governor: performance cores: 1: 3547 2: 3600
    3: 3848 4: 3600 5: 3718 6: 3600 7: 3600 8: 3959 9: 3581 10: 3933 11: 3600
    12: 3600 bogomips: 86398
  Device-1: NVIDIA TU106 [GeForce RTX 2060 Rev. A] vendor: eVga.com.
    driver: nvidia v: 555.58.02 alternate: nouveau,nvidia_drm non-free: 550.xx+
    status: current (as of 2024-06; EOL~2026-12-xx) arch: Turing code: TUxxx
    process: TSMC 12nm FF built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s
    lanes: 16 link-max: gen: 3 speed: 8 GT/s ports: active: none
    off: DP-1,HDMI-A-1 empty: DVI-D-1 bus-ID: 26:00.0 chip-ID: 10de:1f08
  Device-2: Logitech Webcam C270 driver: snd-usb-audio,uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-2:3 chip-ID: 046d:0825
  Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.2
    compositor: gnome-shell driver: X: loaded: nvidia unloaded: modesetting
    display-ID: :1 screens: 1
    s-diag: 1245mm (49.01")
  Monitor-1: DP-1 mapped: DP-0 note: disabled pos: primary,left
    model: BenQ EX2710R serial: <filter> built: 2021 res: 2560x1440 hz: 60
    dpi: 109 gamma: 1.2 size: 597x336mm (23.5x13.23") diag: 685mm (27")
  Monitor-2: HDMI-A-1 mapped: HDMI-0 note: disabled pos: right
    model: Huawei AD80HW built: 2021 res: 1920x1080 hz: 75 dpi: 93 gamma: 1.2
    max: 1920x1080 min: 640x480
    inactive: wayland,device-1
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 2060/PCIe/SSE2
    memory: 5.86 GiB
  API: Vulkan v: 1.3.279 layers: 5 device: 0 type: discrete-gpu
    name: NVIDIA GeForce RTX 2060 driver: nvidia v: 555.58.02
    device-ID: 10de:1f08 surfaces: xcb,xlib
  Device-1: NVIDIA TU106 High Definition Audio vendor: eVga.com.
    bus-ID: 26:00.1 chip-ID: 10de:10f9 class-ID: 0403
    bus-ID: 28:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: Logitech Webcam C270 driver: snd-usb-audio,uvcvideo type: USB
  API: ALSA v: k6.10.5-zen1-1-zen status: kernel-api tools: N/A
  Server-1: PipeWire v: 1.2.2 status: active with: 1: pipewire-pulse
  Local Storage: total: 2.31 TiB used: 498.69 GiB (21.1%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data model: SX8200PNP
    lanes: 4 tech: SSD serial: <filter> fw-rev: 42BEU1TB temp: 36.9 C
  ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000MX500SSD1
    tech: SSD serial: <filter> fw-rev: 032 scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 840 PRO Series
    tech: SSD serial: <filter> fw-rev: 5B0Q scheme: GPT
  ID-1: / raw-size: 913.37 GiB size: 913.37 GiB (100.00%)
    used: 15.95 GiB (1.7%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
  ID-2: /boot/efi raw-size: 600 MiB size: 598.8 MiB (99.80%)
    used: 584 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
  ID-3: /home raw-size: 953.87 GiB size: 953.87 GiB (100.00%)
    used: 482.74 GiB (50.6%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-4: /var/log raw-size: 913.37 GiB size: 913.37 GiB (100.00%)
  ID-5: /var/tmp raw-size: 913.37 GiB size: 913.37 GiB (100.00%)
  ID-1: swap-1 type: zram size: 47 GiB used: 0 KiB (0.0%) priority: 100
  ID-2: swap-2 type: partition size: 17.56 GiB used: 0 KiB (0.0%)
  System Temperatures: cpu: 55.1 C mobo: N/A gpu: nvidia temp: 38 C
  Fan Speeds (rpm): N/A gpu: nvidia fan: 33%
  Memory: total: 48 GiB available: 47 GiB used: 8.07 GiB (17.2%)
  Processes: 404 Power: uptime: 2h 54m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 18.76 GiB services: gsd-power,
  Packages: pm: pacman pkgs: 1588 libs: 472 tools: pamac,paru,yay Compilers:
    gcc: 14.2.1 Shell: garuda-inxi default: Bash v: 5.2.32
    running-in: gnome-terminal inxi: 3.3.35
  System install date:     2024-04-14
  Last full system update: 2024-08-20 ↻
Have you tried this (despite the name it seems to have the same id)?
that’s the way. Thanks
I did
sudo systemctl enable xboxdrv.service
sudo systemctl start xboxdrv.service
and my controler is coming back :slight_smile:
