So there was this stupid update pushed very recently which is creating scaling issues for everyone.
I have tried what people on internet suggested like editing the /etc/sddm.conf
and setting dpi as 96 (in my case 120 looks better), but this only fixed the sddm login screen for me.
All the KDE apps ie Qt apps are still being scaled large and it's creating Huge icons and text, and in many cases blurry thumbnails and previews. GTK apps like chromium, gimp are being scaled properly.
Look at this for example : https://imgur.com/a/ghH8D2g
It's present in Dolphin, Gwenview, RSIBreak, flameshot and pretty much all Qt apps.
Now, honestly I kind of like the slightly bigger text this bug has introduced since I have a small laptop screen. But the image previews being so low resolution is annoying.
For instance, RSIBreak displays fullscreen images after the patience timer runs out. These images I have selected are 1080p and 1440p images which used to look clear before, now look like some 360p or 480p images stretched to entire display.
I tried the command xrandr --dpi 120
and relogged, didn't have any effect too.
So yeah, the editing of sddm.conf and forcing font dpi in system settings hasn't solved the problem for me. Could you guys please provide additional help?
Background : I have a 14 inch 1080p display and 125% global scaling.
ā°āĪ» inxi -Faz
System: Kernel: 5.14.15-arch1-g14-1 x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: pm_debug_messages amd_pmc.enable_stb=1 amd_pmc.dyndbg="+p" acpi.dyndbg="file
drivers/acpi/x86/s2idle.c +p" BOOT_IMAGE=/@/boot/vmlinuz-linux-g14
root=UUID=a12edf4b-f91d-4792-a992-2baac1ce3438 rw rootflags=subvol=@ quiet
cryptdevice=UUID=1f19efd7-c4e6-4eaf-accf-83d0acf1403e:luks-1f19efd7-c4e6-4eaf-accf-83d0acf1403e
root=/dev/mapper/luks-1f19efd7-c4e6-4eaf-accf-83d0acf1403e rd.udev.log_priority=3
vt.global_cursor_default=0 systemd.unified_cgroup_hierarchy=1 loglevel=3 splash
Desktop: KDE Plasma 5.23.3 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: ASUSTeK product: ROG Zephyrus G14 GA401II_GA401II v: 1.0 serial: <filter>
Mobo: ASUSTeK model: GA401II v: 1.0 serial: <filter> UEFI: American Megatrends v: GA401II.219
date: 12/30/2020
Battery: ID-1: BAT0 charge: 58.2 Wh (79.6%) condition: 73.1/76.0 Wh (96.2%) volts: 15.8 min: 15.8
model: ASUSTeK ASUS Battery type: Li-ion serial: N/A status: Not charging
Device-1: hidpp_battery_0 model: Logitech G304 Lightspeed Wireless Gaming Mouse
serial: <filter> charge: 100% (should be ignored) rechargeable: yes status: Discharging
CPU: Info: 6-Core model: AMD Ryzen 5 4600HS with Radeon Graphics bits: 64 type: MT MCP arch: Zen 2
family: 17 (23) model-id: 60 (96) stepping: 1 microcode: 8600104 cache: L2: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 71899
Speed: 3987 MHz min/max: 1400/3000 MHz boost: enabled Core speeds (MHz): 1: 3987 2: 3639
3: 3298 4: 3774 5: 2841 6: 3132 7: 2258 8: 1774 9: 3408 10: 3745 11: 3560 12: 2645
mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics: Device-1: AMD Renoir vendor: ASUSTeK driver: amdgpu v: kernel bus-ID: 04:00.0
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver: loaded: amdgpu,ati
Screen-1: 0 s-res: 1920x1080 s-dpi: 120 s-size: 406x228mm (16.0x9.0") s-diag: 466mm (18.3")
Monitor-1: eDP res: 1920x1080 hz: 120 dpi: 158 size: 309x174mm (12.2x6.9") diag: 355mm (14")
OpenGL: renderer: AMD RENOIR (DRM 3.42.0 5.14.15-arch1-g14-1 LLVM 12.0.1) v: 4.6 Mesa 21.2.4
direct render: Yes
Audio: Device-1: AMD driver: snd_hda_intel v: kernel bus-ID: 04:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: ASUSTeK driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
Sound Server-1: ALSA v: k5.14.15-arch1-g14-1 running: yes
Network: Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 02:00.0 chip-ID: 8086:2723
Bluetooth: Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 5-4:3 chip-ID: 8087:0029
Report: bt-adapter ID: hci0 rfk-id: 0 state: down bt-service: enabled,running rfk-block:
Drives: Local Storage: total: 953.87 GiB used: 262.51 GiB (27.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW010T8 size: 953.87 GiB
rev: 004C temp: 32.9 C scheme: GPT
Partition: ID-1: / raw-size: 953.61 GiB size: 953.61 GiB (100.00%) used: 262.5 GiB (27.5%) fs: btrfs
dev: /dev/dm-0 maj-min: 254:0 mapped: luks-1f19efd7-c4e6-4eaf-accf-83d0acf1403e
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 706 KiB (0.3%) fs: vfat
ID-3: /home raw-size: 953.61 GiB size: 953.61 GiB (100.00%) used: 262.5 GiB (27.5%) fs: btrfs
ID-4: /var/log raw-size: 953.61 GiB size: 953.61 GiB (100.00%) used: 262.5 GiB (27.5%)
fs: btrfs dev: /dev/dm-0 maj-min: 254:0 mapped: luks-1f19efd7-c4e6-4eaf-accf-83d0acf1403e
ID-5: /var/tmp raw-size: 953.61 GiB size: 953.61 GiB (100.00%) used: 262.5 GiB (27.5%)
ID-1: swap-1 type: zram size: 15.05 GiB used: 1024 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 51.2 C mobo: 49.0 C gpu: amdgpu temp: 46.0 C
Fan Speeds (RPM): cpu: 2800
Info: Processes: 360 Uptime: 37m wakeups: 5 Memory: 15.05 GiB used: 2.94 GiB (19.5%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1448 lib: 361
Shell: fish v: 3.3.1 default: Zsh v: 5.8 running-in: konsole inxi: 3.3.08
