I am trying to upgrade and failing.
sudo garuda-update
garuda is up to date
core is up to date
extra is up to date
warning: reflector-simple: local (2.0-1.1) is newer than garuda (2.0-1)
resolving dependencies...
:: installing ncurses (6.4_20230520-1) breaks dependency 'ncurses=6.4' required by lib32-ncurses
Kernel: 6.3.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=fee12699-5d85-4ddb-bae0-daf333cf53d5 rw rootflags=subvol=@
loglevel=3 quiet splash ibt=off
Desktop: KDE Plasma v: 5.27.5 tk: Qt v: 5.15.9 wm: kwin_x11 dm: SDDM
Type: Laptop System: Micro-Star product: GL65 9SE v: REV:1.0
Mobo: Micro-Star model: MS-16U5 v: REV:1.0 serial: <filter>
UEFI: American Megatrends v: E16U5IMS.102 date: 03/17/2020
ID-1: BAT1 charge: 42.4 Wh (96.4%) condition: 44.0/51.6 Wh (85.4%)
volts: 11.9 min: 10.9 model: MSI BIF0_9 type: Li-ion serial: N/A
status: not charging
Info: model: Intel Core i7-9750H socket: BGA1440 (U3E1) note: check bits: 64
type: MT MCP arch: Coffee Lake gen: core 9 level: v3 note: check built: 2018
process: Intel 14nm family: 6 model-id: 0x9E (158) stepping: 0xA (10)
microcode: 0xF2
L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 3 MiB desc: 12x256 KiB
L3: 144 MiB desc: 12x12 MiB
Speed (MHz): avg: 1550 high: 2600 min/max: 800/4500 base/boost: 2475/8300
ext-clock: 100 MHz cores: 1: 800 2: 800 3: 2600 4: 2600 5: 2600 6: 800
7: 800 8: 800 9: 800 10: 800 11: 2600 12: 2600 bogomips: 62399
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Micro-Star MSI
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:3e9b
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Micro-Star MSI
status: current (as of 2023-05) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s ports: active: none
empty: DP-1,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:1f11 class-ID: 0300
Device-3: Chicony HD Webcam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-13:3 chip-ID: 04f2:b695
class-ID: 0e02
Monitor-1: eDP-1 model: AU Optronics 0xd0ed built: 2019 res: 1920x1080
hz: 120 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 23.1.1 renderer: Mesa Intel UHD Graphics 630 (CFL
GT2) direct-render: Yes
Device-2: NVIDIA TU106 High Definition Audio vendor: Micro-Star MSI
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:10f9
API: ALSA v: k6.3.5-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.71 status: n/a (root, process) with:
vendor: Micro-Star MSI driver: r8168 v: 8.051.02-NAPI modules: r8169 pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:4
Local Storage: total: 1.38 TiB lvm-free: 1.51 GiB used: 779.21 GiB (55.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN520
SDAPNUW-512G-1032 size: 476.94 GiB block-size: physical: 512 B
logical: 512 B speed: 15.8 Gb/s lanes: 2 tech: SSD serial: <filter>
fw-rev: 20140000 temp: 36.9 C scheme: GPT
SMART: yes health: PASSED on: 300d 22h cycles: 5,292
read-units: 58,347,649 [29.8 TB] written-units: 43,230,068 [22.1 TB]
model: WD10JPVX-60JC3T0 family: Blue Mobile size: 931.51 GiB block-size:
physical: 4096 B logical: 512 B sata: 3.0 speed: 6.0 Gb/s tech: HDD
rpm: 5400 serial: <filter> fw-rev: 1A01 temp: 30 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 2y 46d 4h cycles: 9126
Old-Age: g-sense error rate: 454 write error rate: 100 threshold: 100
Pre-Fail: reallocated sector: 194 threshold: 140
ID-1: / raw-size: 146.44 GiB size: 146.44 GiB (100.00%)
used: 112.89 GiB (77.1%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
used: 576 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 146.44 GiB size: 146.44 GiB (100.00%)
maj-min: 259:2
ID-4: /var/log raw-size: 146.44 GiB size: 146.44 GiB (100.00%)
maj-min: 259:2
ID-5: /var/tmp raw-size: 146.44 GiB size: 146.44 GiB (100.00%)
maj-min: 259:2
ID-1: swap-1 type: zram size: 15.46 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 50.0 C pch: 44.0 C mobo: N/A
Processes: 369 Uptime: 3d 7h 45m wakeups: 60562 Memory: available: 15.46 GiB
used: 5.44 GiB (35.2%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1800 libs: 508 tools: octopi,paru Shell: garuda-inxi (sudo)
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.27
System install date: 2022-07-14
Last full system update: 2023-06-02
