tayef
12 January 2022 16:52
1
After clicking files icon it's just loading, result it's stopped opening files window.
Please see this issue if any one face this.
here is inixi -Faz output...
╭─tayef@makt in ~
╰─λ inxi -Faz
Kernel: 5.15.13-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=0416a7bf-cc96-40d8-826e-0412b715f758 rw rootflags=subvol=@
Desktop: GNOME 41.3 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.0
Type: Desktop Mobo: Gigabyte model: B365M GAMING HD v: x.x
serial: <superuser required> UEFI-[Legacy]: American Megatrends v: F1
date: 05/30/2019
Info: model: Intel Core i5-9400F bits: 64 type: MCP arch: Coffee Lake
family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xEA
desc: 1x9 MiB
Speed (MHz): avg: 4019 high: 4074 min/max: 800/4100 scaling:
driver: intel_pstate governor: performance cores: 1: 4043 2: 4000 3: 3999
4: 4001 5: 4074 6: 4002 bogomips: 34798
Type: l1tf
IBRS_FW, STIBP: disabled, RSB filling
Naman
12 January 2022 16:55
2
Hi,
your question is too vague. Please provide with type of file, size of file and the appication you are trying to open the file in.
tayef
12 January 2022 17:37
3
See on this screen shoot, When I go open files system it's not open.
See last left icon, by click on that files not open.
tayef
12 January 2022 17:45
4
╭─tayef@makt in ~ took 4ms
[🔍] × nautilus
Initializing nautilus-image-converter extension
File "/usr/share/nautilus-python/extensions/nautilus-admin.py", line 25, in <module>
from gettext import gettext, locale, bindtextdomain, textdomain
ImportError: cannot import name 'locale' from 'gettext' (/usr/lib/python3.10/gettext.py)
No module named 'PyPDF2'
Naman
12 January 2022 18:58
5
λ nautilus
GSConnect: No translation file found for domain
ImportError: cannot import name 'locale' from 'gettext' (/usr/lib/python3.9/gettext.py)
File "/usr/share/nautilus-python/extensions/nautilus-mediainfo.py", line 13, i…
Similar error.
Python 3.10 released recently. So that might be it.
And first of all, fully update your system.
tayef
12 January 2022 19:05
6
My system is fully up to date till now, I did it last night.
Naman
12 January 2022 19:15
7
okk, this might be upstream bug
Kindly wait to get it fixed.
FGD
12 January 2022 19:40
8
@tayef Just to clarify, you click on the Nautilus app icon on your bottom dock and it does not open?
mandog
13 January 2022 06:22
10
have you tried removing the icon then re adding it
tayef
13 January 2022 06:29
11
Remove means, to remove nautilus, and then again install it?
Naman
13 January 2022 07:22
12
Try removing nautilus-admin extension.
mandog
13 January 2022 09:11
13
No it does not the icon is just pinned to the dock same as using windows right click remove from favourites go to the menu right click add to daskbar. god this is so elementary i can't believe i'm writing it. Lol
filo
13 January 2022 12:11
14
Maybe try again.
I see there is now Nautilus 41.2-1 (Last Updated: 2022-01-12 18:06 UTC)
If that doesn’t work, I’d try to remove nautilus-pdf-tools or nautilus-pdf-tools-git (I don’t know which one you might have installed), e.g.:
sudo pacman -Rns nautilus-pdf-tools-git
FGD
13 January 2022 13:17
15
tayef:
yes, exactly
Perfect, I took the liberty to edit the subject of your topic to make it easier for others to find it if they search for the same problem.
Hello!
same behaviour for me. This is my output calling nautilus from the terminal:
❯ nautilus 100% 351 Mbps ─╯
(org.gnome.Nautilus:376315): Gtk-WARNING **: 19:56:42.665: Theme parsing error: gtk.css:2:103: Failed to import: Error opening file /usr/share/gnome-shell/extensions/unite@hardpixel.eu/styles/buttons-right/maximized.css: No such file or directory
Naman
27 February 2022 22:08
17
Hello,
Please open a new topic for your request and don't necro bump.
Anyway try
Sorry for the necro bumping, I found this thread useful and appropriate. Your suggestion has fixed my issue.
T H A N K S !
