Mystery permission issue
I have been trying to use LocalSend to send my roommate “That Girl (1966)” and I keep getting “NO PERMISSION You have not granted the necessary permissions. Please grant them in the settings.”. When I got That Girl all I did was copy it to TV Series, Rename the parent folder, rename the subfolders, and then use RenameMyTVSeries to rename the episodes cause once in TV Series ownership should of reverted to the active user myself. Any idea why I should be seeing the permissions being different?
EDIT:
This is not a port issue. I attempt to send any other folder and there is no issue. It is a file permission issue. As one can see the permissions for the season folders for That Girl are drwxr-sr-x and should be drwxrwsr. The episodes for That Girl are -rw-r–r-- instead of -rw-rw-r–+ like they should be. As for RenameMyTVSeries it does not change ANY permissions, just simply changes the files name and metadata.
~  garuda-inxi         ✔  04:36:58 AM
Kernel: 6.14.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=5d6e39dd-31e5-4e2c-8ea6-251eb13348a1 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.3.4 tk: Qt v: N/A info: frameworks v: 6.12.0
Type: Desktop Mobo: Gigabyte model: X670 AORUS ELITE AX v: x.x
Megatrends LLC. v: FB1 date: 05/22/2024
Info: model: AMD Ryzen 7 7700X bits: 64 type: MT MCP arch: Zen 4 gen: 4
desc: 8x1024 KiB L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3619 min/max: 545/5575 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 3619 2: 3619 3: 3619
4: 3619 5: 3619 6: 3619 7: 3619 8: 3619 9: 3619 10: 3619 11: 3619 12: 3619
13: 3619 14: 3619 15: 3619 16: 3619 bogomips: 143720
Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate] vendor: ASUSTeK
driver: nvidia v: 570.133.07 alternate: nouveau,nvidia_drm
gen: 4 speed: 16 GT/s lanes: 16 ports: active: none off: HDMI-A-1
empty: DP-1,DP-2,DP-3 bus-ID: 01:00.0 chip-ID: 10de:2504 class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Raphael vendor: Gigabyte
empty: DP-4, DP-5, DP-6, HDMI-A-2, Writeback-1 bus-ID: 17:00.0
chip-ID: 1002:164e class-ID: 0300 temp: 40.0 C
Monitor-1: HDMI-A-1 model: Dell S3221QS serial: <filter> built: 2024 res:
mode: 3840x2160 hz: 60 scale: 150% (1.5) to: 2560x1440 dpi: 139 gamma: 1.2
size: 697x392mm (27.44x15.43") diag: 806mm (31.7") ratio: 16:9 modes:
max: 3840x2160 min: 640x480
API: EGL v: 1.5 hw: drv: nvidia nouveau drv: nvidia drv: amd radeonsi
platforms: device: 0 drv: nvidia device: 1 drv: radeonsi device: 2
drv: nouveau device: 3 drv: swrast gbm: drv: radeonsi surfaceless:
drv: nvidia wayland: drv: nvidia x11: drv: nvidia
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 570.133.07
API: Vulkan v: 1.4.309 layers: 10 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3060 driver: N/A device-ID: 10de:2504
surfaces: xcb,xlib,wayland device: 1 type: integrated-gpu name: AMD
Radeon Graphics (RADV RAPHAEL_MENDOCINO) driver: N/A device-ID: 1002:164e
Device-2: Creative Labs CA0108/CA10300 [Sound Blaster Audigy Series]
driver: snd_emu10k1 v: kernel bus-ID: 0d:00.0 chip-ID: 1102:0008
class-ID: 0401
Device-3: Advanced Micro Devices [AMD/ATI] Rembrandt Radeon High
speed: 16 GT/s lanes: 16 bus-ID: 17:00.1 chip-ID: 1002:1640 class-ID: 0403
lanes: 16 bus-ID: 17:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.14.2-zen1-1-zen status: kernel-api with: aoss
Device-1: Realtek RTL8852CE PCIe 802.11ax Wireless Network vendor: AzureWave
port: c000 bus-ID: 0e:00.0 chip-ID: 10ec:c852 class-ID: 0280
IF: wlp14s0 state: up mac: <filter>
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: b000 bus-ID: 0f:00.0
IF: enp15s0 state: down mac: <filter>
rev: 1.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-7:4 chip-ID: 13d3:3586
Local Storage: total: 36.38 TiB used: 20.74 TiB (57.0%)
ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Samsung model: SSD 990 EVO 2TB
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 126 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 0B2QKXJ7 temp: 38.9 C
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Crucial model: CT1000T500SSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P8CR002 temp: 32.9 C
ID-3: /dev/nvme2n1 maj-min: 259:8 vendor: Crucial model: CT1000P3SSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR313 temp: 32.9 C
ID-4: /dev/sda maj-min: 8:0 vendor: Seagate model: Expansion HDD
fw-rev: 1801 scheme: GPT
ID-5: /dev/sdb maj-min: 8:16 vendor: Seagate model: Expansion HDD
size: 10.91 TiB block-size: physical: 4096 B logical: 512 B type: USB
fw-rev: 0003 scheme: GPT
ID-6: /dev/sdc maj-min: 8:32 vendor: Seagate model: Expansion HDD
size: 14.55 TiB block-size: physical: 4096 B logical: 512 B type: USB
ID-1: / raw-size: 349.26 GiB size: 349.26 GiB (100.00%)
used: 31.95 GiB (9.1%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:4
used: 2.6 MiB (0.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:2
ID-3: /home raw-size: 349.26 GiB size: 349.26 GiB (100.00%)
ID-4: /var/log raw-size: 349.26 GiB size: 349.26 GiB (100.00%)
ID-5: /var/tmp raw-size: 349.26 GiB size: 349.26 GiB (100.00%)
ID-1: swap-1 type: zram size: 61.76 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 44.6 C mobo: 32.0 C gpu: amdgpu temp: 40.0 C
Memory: total: 64 GiB note: est. available: 61.76 GiB
used: 10.01 GiB (16.2%)
Processes: 514 Power: uptime: 22m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 24.64 GiB services: org_kde_powerdevil,
Packages: 2139 pm: pacman pkgs: 2127 libs: 587
tools: pacseek,paru,pikaur,yay pm: flatpak pkgs: 8 pm: snap pkgs: 4
Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: garuda-inxi default: Zsh
v: 5.8 running-in: konsole inxi: 3.3.37
System install date:     2025-04-09
Last full system update: 2025-04-14
Season Folders
/mnt/My Files II/TV Series/American Horror Story (2011)  ls -l                                             ✔  04:38:44 AM total 48
drwxrwsr-x 2 cccp autologin 4096 Jun 12  2022 'American Horror Story Season 10 (Double Feature)' drwxrwsr-x 2 cccp autologin 4096 Nov 17  2022 'American Horror Story Season 11 (AHS:NYC)'
drwxrwsr-x 2 cccp autologin 4096 Apr 25  2024 'American Horror Story Season 12 (delicate)'
drwxrwsr-x 2 cccp autologin 4096 Jun 12  2022 'American Horror Story Season 1 (Murder House)'
drwxrwsr-x 2 cccp autologin 4096 Jun 12  2022 'American Horror Story Season 2 (Asylum)'
drwxrwsr-x 2 cccp autologin 4096 Jun 12  2022 'American Horror Story Season 3 (Coven)'
drwxrwsr-x 2 cccp autologin 4096 Jun 12  2022 'American Horror Story Season 4 (Freak Show)'
drwxrwsr-x 2 cccp autologin 4096 Jun 12  2022 'American Horror Story Season 5 (Hotel)'
drwxrwsr-x 2 cccp autologin 4096 Jun 12  2022 'American Horror Story Season 6 (Roanoke)'
drwxrwsr-x 2 cccp autologin 4096 Jun 12  2022 'American Horror Story Season 7 (Cult)'
drwxrwsr-x 2 cccp autologin 4096 Jun 12  2022 'American Horror Story Season 8 (Apocalypse)'
drwxrwsr-x 2 cccp autologin 4096 Jun 12  2022 'American Horror Story Season 9 (1984)'
Episodes
/mnt/My Files II/TV Se/American Horror Story/American Horror Story Season 1 (Murder House)  ls -l          ✔  04:43:58 AM
total 1835684
-rw-rw-r--+ 1 cccp autologin 189778122 Oct  5  2011 'American Horror Story (2011) S01E01 Pilot.mkv'
-rw-rw-r--+ 1 cccp autologin 147542915 Oct 12  2011 'American Horror Story (2011) S01E02 Home Invasion.mkv'
-rw-rw-r--+ 1 cccp autologin 147325791 Oct 19  2011 'American Horror Story (2011) S01E03 Murder House.mkv'
-rw-rw-r--+ 1 cccp autologin 145703638 Oct 26  2011 'American Horror Story (2011) S01E04 Halloween (1).mkv'
-rw-rw-r--+ 1 cccp autologin 148180786 Nov  2  2011 'American Horror Story (2011) S01E05 Halloween (2).mkv'
-rw-rw-r--+ 1 cccp autologin 147063779 Nov  9  2011 'American Horror Story (2011) S01E06 Piggy, Piggy.mkv'
-rw-rw-r--+ 1 cccp autologin 147100586 Nov 16  2011 'American Horror Story (2011) S01E07 Open House.mkv'
-rw-rw-r--+ 1 cccp autologin 157581832 Nov 23  2011 'American Horror Story (2011) S01E08 Rubber Man.mkv'
-rw-rw-r--+ 1 cccp autologin 146648008 Nov 30  2011 'American Horror Story (2011) S01E09 Spooky Little Girl.mkv'
-rw-rw-r--+ 1 cccp autologin 146412894 Dec  7  2011 'American Horror Story (2011) S01E10 Smoldering Children.mkv'
-rw-rw-r--+ 1 cccp autologin 146064381 Dec 14  2011 'American Horror Story (2011) S01E11 Birth.mkv'
-rw-rw-r--+ 1 cccp autologin 210307737 Dec 21  2011 'American Horror Story (2011) S01E12 Afterbirth.mkv'
/mnt/My Files II/TV Se/American Horror Story/American Horror Story Season 1 (Murder House)                 ✔  04:44:04 AM
Season Folders
 /mnt/My Files II/TV Series/That Girl (1966)  ls -l                                                         ✔  04:47:41 AM
total 20
drwxr-sr-x 2 cccp autologin 4096 Apr 12 10:16 'Season 1'
drwxr-sr-x 2 cccp autologin 4096 Apr 12 10:19 'Season 2'
drwxr-sr-x 2 cccp autologin 4096 Apr 12 10:25 'Season 3'
drwxr-sr-x 2 cccp autologin 4096 Apr 12 10:30 'Season 4'
drwxr-sr-x 2 cccp autologin 4096 Apr 12 10:32 'Season 5'
 /mnt/My Files II/TV Se/That Girl (1966)          ✔  04:47:45 AM
Episode List
 /mnt/My Files II/TV Series/That Girl (1966)/Season 1  ls -l                                                ✔  04:50:13 AM
total 6566328
-rw-r--r-- 1 cccp autologin 237166012 Sep  8  1966 'That Girl (1966) S01E01 Don`t Just Do Something, Stand There.mkv'
-rw-r--r-- 1 cccp autologin 242242748 Sep 15  1966 'That Girl (1966) S01E02 Goodbye, Hello, Goodbye.mkv'
-rw-r--r-- 1 cccp autologin 187361972 Sep 22  1966 'That Girl (1966) S01E03 Never Change a Diaper on Opening Night.mkv'
-rw-r--r-- 1 cccp autologin 198204404 Sep 29  1966 'That Girl (1966) S01E04 I`ll Be Suing You.mkv'
-rw-r--r-- 1 cccp autologin 241947365 Oct  6  1966 'That Girl (1966) S01E05 Anatomy of a Blunder.mkv'
-rw-r--r-- 1 cccp autologin 223387986 Oct 13  1966 'That Girl (1966) S01E06 Rich Little Rich Kid.mkv'
-rw-r--r-- 1 cccp autologin 199270902 Oct 20  1966 'That Girl (1966) S01E07 Help Wanted.mkv'
-rw-r--r-- 1 cccp autologin 202450921 Oct 27  1966 'That Girl (1966) S01E08 Little Auction Annie.mkv'
-rw-r--r-- 1 cccp autologin 234255931 Nov  3  1966 'That Girl (1966) S01E09 Time for Arrest.mkv'
-rw-r--r-- 1 cccp autologin 231631994 Nov 10  1966 'That Girl (1966) S01E10 Break a Leg.mkv'
-rw-r--r-- 1 cccp autologin 235981424 Nov 17  1966 'That Girl (1966) S01E11 What`s in a Name.mkv'
-rw-r--r-- 1 cccp autologin 239126739 Nov 24  1966 'That Girl (1966) S01E12 Soap Gets in Your Eyes.mkv'
-rw-r--r-- 1 cccp autologin 238682120 Dec  1  1966 'That Girl (1966) S01E13 All About Ann.mkv'
-rw-r--r-- 1 cccp autologin 241790529 Dec  8  1966 'That Girl (1966) S01E14 Phantom of the Horse Opera.mkv'
-rw-r--r-- 1 cccp autologin 211042441 Dec 15  1966 'That Girl (1966) S01E15 Beware of Actors Bearing Gifts.mkv'
-rw-r--r-- 1 cccp autologin 215432628 Dec 22  1966 'That Girl (1966) S01E16 Christmas and the Hard-Luck Kid.mkv'
-rw-r--r-- 1 cccp autologin 213219836 Jan  5  1967 'That Girl (1966) S01E17 Among My Souvenirs.mkv'
-rw-r--r-- 1 cccp autologin 211942418 Jan 12  1967 'That Girl (1966) S01E18 These Boots Weren`t Made for Walking.mkv'
-rw-r--r-- 1 cccp autologin 222880482 Jan 19  1967 'That Girl (1966) S01E19 Kimomo My House.mkv'
-rw-r--r-- 1 cccp autologin 239431548 Jan 26  1967 'That Girl (1966) S01E20 Gone with the Breeze.mkv'
-rw-r--r-- 1 cccp autologin 210248207 Feb  2  1967 'That Girl (1966) S01E21 Rain, Snow and Rice.mkv'
-rw-r--r-- 1 cccp autologin 213042390 Feb  9  1967 'That Girl (1966) S01E22 Paper Hats and Everything.mkv'
-rw-r--r-- 1 cccp autologin 221184931 Feb 16  1967 'That Girl (1966) S01E23 What are Your Intentions.mkv'
-rw-r--r-- 1 cccp autologin 244958773 Feb 23  1967 'That Girl (1966) S01E24 A Tenor`s Loving Care.mkv'
-rw-r--r-- 1 cccp autologin 271911895 Mar  2  1967 'That Girl (1966) S01E25 Leaving the Nest is for the Birds.mkv'
-rw-r--r-- 1 cccp autologin 192321647 Mar  9  1967 'That Girl (1966) S01E26 You Have to Know Someone to Be Unknown.mkv'
-rw-r--r-- 1 cccp autologin 249693996 Mar 16  1967 'That Girl (1966) S01E27 The Honeymoon Apartment.mkv'
-rw-r--r-- 1 cccp autologin 251057306 Mar 23  1967 'That Girl (1966) S01E28 This Little Piggy Had a Ball.mkv'
-rw-r--r-- 1 cccp autologin 205177172 Mar 30  1967 'That Girl (1966) S01E29 Author, Author.mkv'
-rw-r--r-- 1 cccp autologin 196696862 Apr  6  1967 'That Girl (1966) S01E30 The Mating Game.mkv'
 /mnt/My Files II/TV Se/Tha/Season 1 
Hope i understand it right, you can´t send or ?
Tested on my metal (dragon)–> sent / received to host.2 + phone (android) → no probs, but i insert the correct firewall rule before metal host + host.2
Incoming TCP, UDP 53317 Allow
Which os is running there ?
From which source ?
Of course, “RenameMy…” set the right attributes,
if it see a .mkv file with rw-rw (that´s not default)
Edited my first post.
EDIT:
I found the below and now have the That Girl (1966) folder and it’s subfolders fixed. What I need now is to know how to use chmod --reference=source_file target_file so the command will do all files in That Girl all at once instead of one by one.
https://linuxconfig.org/how-to-clone-permissions-from-another-file-or-directory-on-linux
ok..
i use a filemanager to do this: mc (midnight-commander)
or… for a file
open console → /mnt/My Files…
chmod --reference=source_file target_file mean
chmod --reference=(your file) (your file) (think on the different folder if the files are not in the same folder)
chmod --reference=/mnt/My Files II/TV Se/../xxx.mkv /mnt/My Files II/TVSeries/xxx/xxx.mkv
but better is here for all of the content (folder + files)
chmod -R --reference=source_directory target_directory
wired and interesting i use Localsend too between the Phone and Pc. i was thinking maybe a drm security but this not affect the mkv files. i converted my series and movies all to mp4 and didnt had issues like you :wink:
That was also my thinking..special M$ MediaDRM + shared folders/files
My question was from which source…
yes i had some folder where had drm from mdoof but i got a decoder on mdoof and converted all to get rid of those bullsh..t. other thinking was when he used a other profile name and after a other system install permissions problems. I also found someone had this as a bug in the 1.1 version but i think its 1.17 now =)
lol.. and inside Kodi (linux based)..found …nothing.. i know
I’m thinking something changed my permission structure sometime in March, cause after fixing the That Girl folder and it’s subfolders I decided to look at other shows that are still running their current season. In one the files from March 6th forward are like the That Girl files. I’m now thinking I need to change the permissions from the from the Top level of each of the drives. Correct me if I’m wrong but since all 3 drives are ext4 and all I do is mount them under /mnt and take ownership with root actions should all parent folders and sub folders be the same permission set and all files regardless of type be the same permission set?
The permission structures have dependencies which user + source. (of course some more)
If all works well, you don’t need to change anything.
Important for you is only now ..the source. (my mind)
If you “feel” better, then change that.
Something changed the permission was (my mind) your source and
the “new” os. The isos from last year to this year are more then a little bit different.
I would write the same as gampel. I had also some issue on ext 4 drives so i formated them in btrfs also. I had the experiance that if i used the root actions to get access didnt changed some files :wink:
Will the below fix all the files on the drive to be -rw-rw-r–+ versus -rw-r–r–?
find "/mnt/My Files II" -type f -exec chmod 664 {} +
