I am trying to install mycroft with pipewire.
Garuda-Inxi
Kernel: 5.16.15-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=00b33177-335b-466d-8a5b-e5bad5669f19 rw rootflags=subvol=@
Type: Laptop System: Micro-Star product: GL65 9SE v: REV:1.0
Mobo: Micro-Star model: MS-16U5 v: REV:1.0 serial: <superuser required>
UEFI: American Megatrends v: E16U5IMS.102 date: 03/17/2020
ID-1: BAT1 charge: 27.2 Wh (60.0%) condition: 45.3/51.6 Wh (87.9%)
volts: 11.0 min: 10.9 model: MSI BIF0_9 type: Li-ion serial: N/A
status: N/A
family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xEC
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 2589 high: 2601 min/max: 800/4500 scaling:
driver: intel_pstate governor: performance cores: 1: 2548 2: 2573 3: 2601
4: 2600 5: 2600 6: 2601 7: 2600 8: 2600 9: 2600 10: 2601 11: 2549
12: 2600 bogomips: 62399
Type: l1tf
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Micro-Star MSI
driver: i915 v: kernel ports: active: eDP-1 empty: none bus-ID: 00:02.0
chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Micro-Star MSI
driver: nvidia v: 510.54 alternate: nouveau,nvidia_drm pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1f11 class-ID: 0300
Device-3: Chicony HD Webcam type: USB driver: uvcvideo bus-ID: 1-13:5
chip-ID: 04f2:b695 class-ID: 0e02
loaded: intel,nvidia unloaded: modesetting,nouveau alternate: fbdev,nv,vesa
s-diag: 582mm (22.9")
Monitor-1: eDP1 mapped: eDP-1 model: AU Optronics built: 2019
res: 1920x1080 hz: 120 dpi: 143 gamma: 1.2 size: 340x190mm (13.4x7.5")
Sound Server-1: ALSA v: k5.16.15-zen1-1-zen running: yes
driver: btusb v: 0.8 bus-ID: 1-14:6 chip-ID: 8087:0aaa class-ID: e001
address: <filter>
Local Storage: total: 1.38 TiB used: 550.8 GiB (39.1%)
model: PC SN520 SDAPNUW-512G-1032 size: 476.94 GiB block-size:
physical: 512 B logical: 512 B speed: 15.8 Gb/s lanes: 2 type: SSD
serial: <filter> rev: 20140000 temp: 50.9 C scheme: GPT
model: WD10JPVX-60JC3T0 size: 931.51 GiB block-size: physical: 4096 B
rev: 1A01 scheme: GPT
ID-1: / raw-size: 146.48 GiB size: 146.48 GiB (100.00%)
used: 56.57 GiB (38.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 256 MiB size: 252 MiB (98.46%)
used: 557 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 146.48 GiB size: 146.48 GiB (100.00%)
ID-4: /var/log raw-size: 146.48 GiB size: 146.48 GiB (100.00%)
ID-5: /var/tmp raw-size: 146.48 GiB size: 146.48 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.47 GiB used: 1.9 MiB (0.0%)
System Temperatures: cpu: 49.0 C pch: 59.0 C mobo: N/A
Processes: 368 Uptime: 6h 0m wakeups: 1 Memory: 15.47 GiB
used: 3.22 GiB (20.8%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1824 lib: 550 Shell: fish
v: 3.3.1 running-in: konsole inxi: 3.3.13
Garuda (2.5.6-2):
System install date: 2022-01-25
Last full system update: 2022-03-14
Command: sudo pacman -Syu mycroft-core plasma5-applets-mycroft-git mimic mycroft-gui-git
I have found this link in the aur. The link describes where to put a conf file for pipewire and how to edit this. I have edited this file and placed in /etc/pipewire/pipewire-pulse.conf for system wide changes.
This is the file as I have edited.
pipewire-pulse.conf
# Copy and edit this file in /etc/pipewire for system-wide changes
# or in ~/.config/pipewire for local changes.
# It is also possible to place a file with an updated section in
# /etc/pipewire/pipewire-pulse.conf.d/ for system-wide changes or in
# ~/.config/pipewire/pipewire-pulse.conf.d/ for local changes.
context.properties = {
## Configure properties in the system.
#mem.warn-mlock = false
#mem.allow-mlock = true
#mem.mlock-all = false
#log.level = 2
#default.clock.quantum-limit = 8192
context.spa-libs = {
audio.convert.* = audioconvert/libspa-audioconvert
support.* = support/libspa-support
context.modules = [
{ name = libpipewire-module-rt
args = {
nice.level = -11
#rt.prio = 88
#rt.time.soft = -1
#rt.time.hard = -1
flags = [ ifexists nofail ]
{ name = libpipewire-module-protocol-native }
{ name = libpipewire-module-client-node }
{ name = libpipewire-module-adapter }
{ name = libpipewire-module-metadata }
{ name = libpipewire-module-protocol-pulse
args = {
# the addresses this server listens on
server.address = [
"unix:native"
#"unix:/tmp/something" # absolute paths may be used
#"tcp:4713" # IPv4 and IPv6 on all addresses
#"tcp:[::]:9999" # IPv6 on all addresses
#"tcp:127.0.0.1:8888" # IPv4 on a single address
#{ address = "tcp:4713" # address
# max-clients = 64 # maximum number of clients
# listen-backlog = 32 # backlog in the server listen queue
# client.access = "restricted" # permissions for clients
{ address = "tcp:127.0.0.1:4713"
client.access = "allowed" # permissions for clients
#pulse.min.req = 256/48000 # 5ms
#pulse.default.req = 960/48000 # 20 milliseconds
#pulse.min.frag = 256/48000 # 5ms
#pulse.default.frag = 96000/48000 # 2 seconds
#pulse.default.tlength = 96000/48000 # 2 seconds
#pulse.min.quantum = 256/48000 # 5ms
#pulse.default.format = F32
#pulse.default.position = [ FL FR ]
# These overrides are only applied when running in a vm.
vm.overrides = {
pulse.min.quantum = 1024/48000 # 22ms
# Extra modules can be loaded here. Setup in default.pa can be moved here
context.exec = [
{ path = "pactl" args = "load-module module-always-sink" }
#{ path = "pactl" args = "load-module module-switch-on-connect" }
#{ path = "/usr/bin/sh" args = "~/.config/pipewire/default.pw" }
stream.properties = {
#node.latency = 1024/48000
#node.autoconnect = true
#resample.quality = 4
#channelmix.normalize = true
#channelmix.mix-lfe = false
#channelmix.upmix = false
#channelmix.lfe-cutoff = 0
#channelmix.fc-cutoff = 0
#channelmix.rear-delay = 12.0
#channelmix.stereo-widen = 0.0
#channelmix.hilbert-taps = 0
# client/stream specific properties
pulse.rules = [
matches = [
# all keys must match the value. ~ starts regex.
#client.name = "Firefox"
#application.process.binary = "teams"
#application.name = "~speech-dispatcher.*"
actions = {
update-props = {
#node.latency = 512/48000
# Possible quirks:"
# force-s16-info forces sink and source info as S16 format
# remove-capture-dont-move removes the capture DONT_MOVE flag
#quirks = [ ]
# skype does not want to use devices that don't have an S16 sample format.
matches = [
{ application.process.binary = "teams" }
{ application.process.binary = "skypeforlinux" }
actions = { quirks = [ force-s16-info ] }
# firefox marks the capture streams as don't move and then they
# can't be moved with pavucontrol or other tools.
matches = [ { application.process.binary = "firefox" } ]
actions = { quirks = [ remove-capture-dont-move ] }
# speech dispatcher asks for too small latency and then underruns.
matches = [ { application.name = "~speech-dispatcher*" } ]
actions = {
update-props = {
pulse.min.req = 1024/48000 # 21ms
pulse.min.quantum = 1024/48000 # 21ms
Mycroft will not start. I am not sure where to go from here. Does the above look correct?
EDIT: When I run ./dev_setup.sh It says that pulseaudio and pipewire are in conflict. I would really like to keep pipewire.
