I don't know why but wifi is not connecting and Kde daemon asking for password again and again. But previously it was fine.
System: Kernel: 5.12.1-zen2-1-zen x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=55a11460-701e-495c-887b-ddead1586312
systemd.unified_cgroup_hierarchy=1 resume=UUID=b8b297b0-6b81-43d9-8d71-88eb175e498f loglevel=3
Desktop: KDE Plasma 5.21.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Desktop Mobo: Micro-Star model: A320M-A PRO MAX (MS-7C52) v: 1.0 serial: <filter>
UEFI: American Megatrends v: 2.60 date: 06/10/2020
CPU: Info: Quad Core model: AMD Ryzen 5 3400G with Radeon Vega Graphics bits: 64 type: MT MCP
arch: Zen/Zen+ note: check family: 17 (23) model-id: 18 (24) stepping: 1 microcode: 8108109
cache: L2: 2 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 59201
Speed: 3700 MHz min/max: N/A Core speeds (MHz): 1: 3700 2: 3700 3: 3700 4: 3700 5: 3700 6: 3700
7: 1312 8: 3700
Graphics: Device-1: AMD Picasso vendor: Micro-Star MSI driver: amdgpu v: kernel bus-ID: 29:00.0
chip-ID: 1002:15d8 class-ID: 0300
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: amdgpu,ati
Monitor-1: HDMI-A-0 res: 1366x768 hz: 60 dpi: 81 size: 430x255mm (16.9x10.0")
diag: 500mm (19.7")
OpenGL: renderer: AMD Radeon Vega 11 Graphics (RAVEN DRM 3.40.0 5.12.1-zen2-1-zen LLVM 11.1.0)
v: 4.6 Mesa 21.0.3 direct render: Yes
Audio: Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel v: kernel
bus-ID: 29:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
bus-ID: 29:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.12.1-zen2-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.26 running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI
driver: r8169 v: kernel port: f000 bus-ID: 25:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp37s0 state: down mac: <filter>
Device-2: TP-Link AC600 wireless Realtek RTL8811AU [Archer T2U Nano] type: USB
driver: rtl88XXau bus-ID: 1-9:3 chip-ID: 2357:011e class-ID: 0000 serial: <filter>
IF: wlp18s0f0u9 state: dormant mac: <filter>
IF-ID-1: enp18s0f0u3 state: unknown speed: N/A duplex: N/A mac: <filter>
Drives: Local Storage: total: 447.13 GiB used: 13.75 GiB (3.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37480G size: 447.13 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 0102
Partition: ID-1: / raw-size: 432.03 GiB size: 432.03 GiB (100.00%) used: 13.75 GiB (3.2%) fs: btrfs
dev: /dev/sda3 maj-min: 8:3
ID-2: /boot/efi raw-size: 100 MiB size: 98.4 MiB (98.42%) used: 546 KiB (0.5%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 432.03 GiB size: 432.03 GiB (100.00%) used: 13.75 GiB (3.2%) fs: btrfs
ID-4: /var/log raw-size: 432.03 GiB size: 432.03 GiB (100.00%) used: 13.75 GiB (3.2%) fs: btrfs
ID-5: /var/tmp raw-size: 432.03 GiB size: 432.03 GiB (100.00%) used: 13.75 GiB (3.2%) fs: btrfs
ID-1: swap-1 type: partition size: 15 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda2
maj-min: 8:2
ID-2: swap-2 type: zram size: 1.71 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram0
ID-3: swap-3 type: zram size: 1.71 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram1
ID-4: swap-4 type: zram size: 1.71 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram2
ID-5: swap-5 type: zram size: 1.71 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram3
ID-6: swap-6 type: zram size: 1.71 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram4
ID-7: swap-7 type: zram size: 1.71 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram5
ID-8: swap-8 type: zram size: 1.71 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram6
ID-9: swap-9 type: zram size: 1.71 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram7
Sensors: System Temperatures: cpu: 49.1 C mobo: 0 C gpu: amdgpu temp: 49.0 C
Info: Processes: 297 Uptime: 9m wakeups: 0 Memory: 13.66 GiB used: 2.76 GiB (20.2%) Init: systemd
v: 248 tool: systemctl Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: pacman: 1230 lib: 291
Shell: fish v: 3.2.1 running-in: konsole inxi: 3.3.04
