Hello there, im newbie. please help me, i try to connect to my wifi but i cant find it on my networks list
Kernel: 5.15.10-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=270b0856-6a61-4b58-857f-8bea1cabad2b rw rootflags=subvol=@
Desktop: GNOME 41.2 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 41.0
Type: Desktop Mobo: INTEL model: H55 serial: <superuser required>
BIOS: American Megatrends v: 080015 date: 08/16/2019
Info: model: Intel Core i7 860 bits: 64 type: MT MCP arch: Nehalem
family: 6 model-id: 0x1E (30) stepping: 5 microcode: 0xA
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1197 high: 1198 min/max: 1200/2800 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1197 2: 1197
3: 1197 4: 1197 5: 1197 6: 1198 7: 1198 8: 1197 bogomips: 44692
Type: l1tf
Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode;
SMT vulnerable
Device-1: NVIDIA GK208B [GeForce GT 710] driver: nouveau v: kernel
bus-ID: 01:00.0 chip-ID: 10de:128b class-ID: 0300
Device-2: Huawei HiCamera type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 2-6:5 chip-ID: 12d1:4321 class-ID: 0102 serial: <filter>
Display: x11 server: X.Org 1.21.1.2 compositor: gnome-shell driver:
loaded: nouveau unloaded: modesetting alternate: fbdev,nv,vesa
display-ID: :1 screens: 1
s-diag: 582mm (22.9")
Monitor-1: HDMI-1 res: 1920x1080 hz: 60 dpi: 102
size: 477x268mm (18.8x10.6") diag: 547mm (21.5")
Device-1: Intel 5 Series/3400 Series High Definition Audio
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:3b56
Device-2: NVIDIA GK208 HDMI/DP Audio driver: snd_hda_intel v: kernel
bus-ID: 01:00.1 chip-ID: 10de:0e0f class-ID: 0403
Device-3: Huawei HiCamera type: USB driver: snd-usb-audio,uvcvideo
Sound Server-1: ALSA v: k5.15.10-zen1-1-zen running: yes
Device-1: Realtek RTL810xE PCI Express Fast Ethernet driver: r8169
v: kernel port: e800 bus-ID: 02:00.0 chip-ID: 10ec:8136 class-ID: 0200
IF: ens128 state: down mac: <filter>
Device-2: Realtek RTL8188FTV 802.11b/g/n 1T1R 2.4G WLAN Adapter type: USB
driver: r8188eu bus-ID: 2-5:4 chip-ID: 0bda:f179 class-ID: 0000
IF: wlp0s29f7u5 state: down mac: <filter>
IF-ID-1: enp0s26f7u4 state: unknown speed: -1 duplex: half mac: <filter>
Device-1: HMD Global TA-1032 type: USB driver: rndis_host v: kernel
bus-ID: 1-4:4 chip-ID: 2e04:c022 class-ID: 0a00 serial: <filter>
Device-2: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) type: USB
driver: btusb v: 0.8 bus-ID: 6-1:2 chip-ID: 0a12:0001 class-ID: e001
Report: ID: hci0 rfk-id: 0 state: up address: N/A
Local Storage: total: 465.76 GiB used: 12.31 GiB (2.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST3500312CS
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 5900 serial: <filter> rev: CA12 scheme: MBR
ID-1: / raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
used: 12.31 GiB (2.6%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
ID-3: /var/log raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
ID-4: /var/tmp raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.62 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 47.0 C mobo: N/A gpu: nouveau temp: 48.0 C
Processes: 270 Uptime: 18m wakeups: 0 Memory: 15.62 GiB
used: 1.37 GiB (8.7%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1072 lib: 297 Shell: fish
v: 3.3.1 default: Bash v: 5.1.12 running-in: gnome-terminal inxi: 3.3.11
