My garuda-inxi:
[nicolo@nicolo-pc ~]$ garuda-inxi
Kernel: 5.15.77-1-lts arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=10eff176-0f05-40d0-8036-ea2504cc29cc rw rootflags=subvol=@
Desktop: Xfce v: 4.16.1 tk: Gtk v: 3.24.34 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.32.0 Distro: Garuda Linux base: Arch Linux
Type: Laptop System: SAMSUNG product: QX310/QX410/QX510/SF310/SF410/SF510
v: 05MX serial: <superuser required> Chassis: type: 9
Mobo: SAMSUNG model: QX310/QX410/QX510/SF310/SF410/SF510 v: 05MX
serial: <superuser required> BIOS: American Megatrends
v: 05MX.M008.20110525.SCY date: 05/25/2011
ID-1: BAT1 charge: 39.8 Wh (96.8%) condition: 41.1/61.0 Wh (67.3%)
volts: 12.1 min: 11.1 model: SAMSUNG Electronics type: Li-ion serial: N/A
status: N/A
Info: model: Intel Core i5 M 480 bits: 64 type: MT MCP arch: Westmere
gen: core 1 level: v2 built: 2010-11 process: Intel 32nm family: 6
model-id: 0x25 (37) stepping: 5 microcode: 0x7
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1517 high: 1779 min/max: 1199/2667 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 1307 2: 1511
3: 1779 4: 1471 bogomips: 21279
vulnerable
Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode;
SMT vulnerable
prctl and seccomp
Device-1: Intel Core Processor Integrated Graphics vendor: Samsung Co
driver: i915 v: kernel arch: Gen-5.75 process: Intel 45nm built: 2010
ports: active: LVDS-1 empty: DP-1,HDMI-A-1,VGA-1 bus-ID: 00:02.0
chip-ID: 8086:0046 class-ID: 0300
Device-2: NVIDIA GT218M [GeForce 310M] vendor: Samsung Co driver: nouveau
v: kernel non-free: series: 340.xx status: legacy (EOL) last:
release: 340.108 kernel: 5.4 xorg: 1.20 arch: Tesla process: 40-80nm
built: 2006-13 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 ports:
active: VGA-2 empty: none bus-ID: 01:00.0 chip-ID: 10de:0a70
class-ID: 0302 temp: 58.0 C
Device-3: Silicon Motion WebCam SCB-0370N type: USB driver: uvcvideo
bus-ID: 1-1.4:3 chip-ID: 2232:1001 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 compositor: xfwm v: 4.16.1 driver:
X: loaded: modesetting,nouveau alternate: fbdev,intel,nv,vesa
dri: crocus,nouveau gpu: i915,nouveau display-ID: :0.0 screens: 1
s-diag: 414mm (16.31")
Monitor-1: LVDS-1 pos: primary model: Seiko Epson 0x3355 built: 2010
res: 1366x768 hz: 60 dpi: 118 gamma: 1.2 size: 293x165mm (11.54x6.5")
diag: 336mm (13.2") ratio: 16:9 modes: 1366x768
Monitor-2: VGA-2 mapped: VGA-1-2 pos: primary res: 1024x768 hz: 60
size: N/A modes: max: 1024x768 min: 640x480
OpenGL: renderer: Mesa Intel HD Graphics (ILK) v: 2.1 Mesa 22.2.1
direct render: Yes
Device-1: Intel 5 Series/3400 Series High Definition Audio
vendor: Samsung Co driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:3b56 class-ID: 0403
Device-2: NVIDIA High Definition Audio vendor: Samsung Co
bus-ID: 01:00.1 chip-ID: 10de:0be3 class-ID: 0403
Sound API: ALSA v: k5.15.77-1-lts running: yes
Device-1: Broadcom BCM4313 802.11bgn Wireless Network Adapter vendor: Askey
bus-ID: 02:00.0 chip-ID: 14e4:4727 class-ID: 0280
IF: wlp2s0 state: dormant mac: <filter>
Device-2: Marvell Yukon Optima 88E8059 [PCIe Gigabit Ethernet with AVB]
vendor: Samsung Co driver: sky2 v: 1.30 pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: b000 bus-ID: 03:00.0 chip-ID: 11ab:4381 class-ID: 0200
IF-ID-1: enp0s26u1u2 state: unknown speed: -1 duplex: half mac: <filter>
Device-1: MediaTek moto e(7) power type: USB driver: rndis_host v: kernel
bus-ID: 1-1.2:5 chip-ID: 0e8d:2005 class-ID: 0a00 serial: <filter>
Local Storage: total: 232.89 GiB used: 65.68 GiB (28.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 750 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: SSD serial: <filter> rev: 1B6Q scheme: MBR
ID-1: / raw-size: 206.73 GiB size: 206.73 GiB (100.00%) used: 65.68 GiB
(31.8%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 206.73 GiB size: 206.73 GiB (100.00%) used: 65.68
GiB (31.8%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-3: /var/log raw-size: 206.73 GiB size: 206.73 GiB (100.00%) used: 65.68
ID-4: /var/tmp raw-size: 206.73 GiB size: 206.73 GiB (100.00%) used: 65.68
ID-1: swap-1 type: zram size: 3.62 GiB used: 6 MiB (0.2%) priority: 100
System Temperatures: cpu: 60.0 C mobo: N/A gpu: nouveau temp: 58.0 C
Processes: 250 Uptime: 8m wakeups: 1 Memory: 3.63 GiB used: 1.8 GiB (49.5%)
Init: systemd v: 251 default: graphical tool: systemctl Compilers:
gcc: 12.2.0 Packages: 1574 pm: dpkg pkgs: 0 pm: pacman pkgs: 1568 libs: 385
tools: pamac,paru,yay pm: flatpak pkgs: 6 Shell: Bash v: 5.1.16
running-in: xfce4-terminal inxi: 3.3.22
Garuda (2.6.9-1):
System install date: 2022-10-29
Last full system update: 2022-11-06
Is partially upgraded: Yes
Yesterday I updated my system and now it's recognizing my touchpad as a logitech wheel mouse, thing that, obviously, brokes all the touchpad-only features, making it unusable.
the first one is my actual mouse, and the second one is the touchpad.
