My system is partially upgraded, can't upgrade it fully
I have searched many times in this forum to find my solution, finally determined to post here.
please see the command output....
(14/30) Install DKMS modules
==> dkms install --no-depmod rtl88xxau/r1174.3a6402e -k 5.16.0-zen1-1-zen
Deprecated feature: REMAKE_INITRD
==> dkms install --no-depmod rtl88x2ce/5.7.3_35403 -k 5.16.0-zen1-1-zen
Error! Bad return status for module build on kernel: 5.16.0-zen1-1-zen (x86_64)
Consult /var/lib/dkms/rtl88x2ce/5.7.3_35403/build/make.log for more information.
==> WARNING: `dkms install --no-depmod rtl88x2ce/5.7.3_35403 -k 5.16.0-zen1-1-zen' exited 10
==> dkms install --no-depmod 8188fu/r101.e7f2fcc -k 5.16.0-zen1-1-zen
==> dkms install --no-depmod 8192eu/128.b7faffd -k 5.16.0-zen1-1-zen
every time after rebooting , I got a message that your system is partially upgraded.
here some picture
Here is my inxi -Faz out put
Kernel: 5.15.12-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=e09c5da2-adc2-4b65-8f63-e58d4cdf3578 rw rootflags=subvol=@
Type: Desktop Mobo: Gigabyte model: B365M GAMING HD v: x.x
serial: <superuser required> UEFI-[Legacy]: American Megatrends v: F1
date: 05/30/2019
Info: model: Intel Core i5-9400F bits: 64 type: MCP arch: Coffee Lake
family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xEA
desc: 1x9 MiB
Speed (MHz): avg: 1882 high: 3709 min/max: 800/4100 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 1199
4: 3709 5: 2615 6: 2172 bogomips: 34798
Type: l1tf
IBRS_FW, STIBP: disabled, RSB filling
vendor: Sapphire Limited driver: amdgpu v: kernel bus-ID: 01:00.0
s-diag: 582mm (22.9")
Monitor-1: HDMI-A-1 res: 1920x1080 hz: 60 dpi: 102
size: 476x268mm (18.7x10.6") diag: 546mm (21.5")
Device-1: Intel 200 Series PCH HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a2f0
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: Sapphire Limited driver: snd_hda_intel v: kernel bus-ID: 01:00.1
chip-ID: 1002:aaf0 class-ID: 0403
Sound Server-1: ALSA v: k5.15.12-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.43 running: yes
vendor: Gigabyte driver: r8169 v: kernel port: d000 bus-ID: 07:00.0
Device-2: Qualcomm Atheros AR9271 802.11n type: USB driver: ath9k_htc
bus-ID: 1-3:3 chip-ID: 0cf3:9271 class-ID: ff00 serial: <filter>
IF: wlp0s20f0u3 state: up mac: <filter>
driver: btusb v: 0.8 bus-ID: 1-9:6 chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 1.13 TiB used: 32.82 GiB (2.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: TEUTONS model: PLATIUM SSD 240GB
type: SSD serial: <filter> rev: 0817 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Western Digital
model: WD10 SPZX-24Z10T0 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> scheme: MBR
ID-1: / raw-size: 223.57 GiB size: 223.57 GiB (100.00%)
used: 32.82 GiB (14.7%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 223.57 GiB size: 223.57 GiB (100.00%)
ID-3: /var/log raw-size: 223.57 GiB size: 223.57 GiB (100.00%)
ID-4: /var/tmp raw-size: 223.57 GiB size: 223.57 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.57 GiB used: 96.2 MiB (0.6%)
System Temperatures: cpu: 49.0 C mobo: 16.8 C gpu: amdgpu temp: 49.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 758
Processes: 313 Uptime: 27m wakeups: 0 Memory: 15.57 GiB
used: 2.7 GiB (17.3%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1804 lib: 334 Shell: fish
v: 3.3.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.11
here is output of pacman -Qi garuda-system-maintenance
tayef@makt in ~ took 1s
λ pacman -Qi garuda-system-maintenance
Version         : 1.5.0-1
Description     : Automated Garuda system maintenance tool
Architecture    : x86_64
URL             : https://gitlab.com/garuda-linux/applications/garuda-system-maintenance
Licenses        : GPL
Groups          : None
Provides        : None
Depends On      : qt5-base  garuda-hotfixes  knotifications  garuda-libs
Optional Deps   : None
Required By     : None
Optional For    : None
Conflicts With  : None
Replaces        : garuda-settings-manager-knotifier-git  garuda-settings-manager-notifier-git
Installed Size  : 140.99 KiB
Packager        : Chaotic-AUR Wild Bear Node <wildbear.node@chaotic.cx>
Build Date      : Mon 06 Dec 2021 03:38:07 AM +06
Install Date    : Sat 01 Jan 2022 11:29:38 PM +06
Install Reason  : Explicitly installed
Install Script  : No
Validated By    : Signature
This looks good to me, are you sure the notification isn't gone? I don't see the Garuda System Maintenance icon in your tray.
Can you send the output of ls /var/lib/garuda/ please?
After applying this command sudo pacman -Syu
And performing upgradation then I reboot my pc...
Here is condition now...
See picture...
After that I booted from my past snapshot...
Then I have been sent an prompt about ...
See picture..
Then log back into pc ...
This prompt again shows...
Can you boot back into an old snapshot from before the update? You should probably clean up your kernel modules a bit, which is gonna be easier from inside an actual install.
Just press OK on that prompt.
here is the output of ls /var/lib/garuda/
tayef@makt in ~
λ ls /var/lib/garuda/
.rw-r--r-- 0 root 14 Jan 15:39  last_update
.rw-r--r-- 0 root 14 Jan 16:20  partial_upgrade
tayef@makt in ~ took 6ms
λ
You should restore this snapshot before you do anything else. And then boot back into your non snapshot system.
Then after that consider uninstalling your -dkms packages that you don't need anymore.
I restored past snapshot already.
but system still partially upgraded.
Yeah, of course, you restored a snapshot so you're back to a pre update system state.
Something about the update prevented your system from booting, if you can find what that is and fix it it'll be fine after the update. Try removing some of the DKMS modules you don't need anymore.
Here is dkms status...
tayef@makt in ~
λ dkms status
8188eu/5.3.9.r145.6146193: added
8188fu/r101.e7f2fcc, 5.15.12-zen1-1-zen, x86_64: installedDeprecated feature: REMAKE_INITRD
8192eu/128.b7faffd: added
rtl8192cu-fixes-git/r117.0f12fc0, 5.15.12-zen1-1-zen, x86_64: installedDeprecated feature: REMAKE_INITRD
rtl8814au/r94.bdf80b5: added
rtl88x2bu/5.13.1.r153.aea996c, 5.15.12-zen1-1-zen, x86_64: installedDeprecated feature: REMAKE_INITRD
rtl88x2ce/5.7.3_35403: added
rtl88xxau/r1174.3a6402e, 5.15.12-zen1-1-zen, x86_64: installedDeprecated feature: REMAKE_INITRD
out of them how can I understand which one is necessary must have it, and which are unnecessary.
i'd just remove all of them and see if youre fine. You can always restore the snapshot again if something goes wrong.
Remove them with pacman, reboot, update your system with the update command, reboot again.
After I remove all dkms and then upgrade the system and reboot my pc and back again same issue facing... See picture ...
It's mean I have to boot from my restore snapshot. If I do so, again I will get this command like partially upgraded..
Like I said before...
I don't know why this is happening.
How can I escape from that?...
Your issue isnt the partial upgrade, your issue is that your upgrades break your system. The partial upgrade message can be ignored for now, your issue is why you can't boot after updating.
Some service is probably failing to start, you should try booting multi-user.target after you did the update. Then you can view systemctl list-units --state=failed and also your journalctl logs.
Add systemd.target=multi-user.target to the end of your linux cmdline in grub.
After you did that you should grab your failed systemd units, post them here and then try to run systemctl isolate graphical.target
so what steps I should go on to login successfully after upgrading and rebooting the system without any snapshot restoration.
and how I could put my system upgradation in effects without any breaking
I’m sorry, I can’t give you magic steps to make stuff work suddenly.
Okay tell me, where i should do that
In your grub menu, after applying a system update, press e on the top most entry and add systemd.target=multi-user.target to the end of the line that begins with "linux".
Please see this..
core                                  136.7 KiB  43.8 KiB/s 00:03 [------------------------------------] 100%
extra                                1557.3 KiB   306 KiB/s 00:05 [------------------------------------] 100%
community                               6.0 MiB   912 KiB/s 00:07 [------------------------------------] 100%
multilib is up to date
chaotic-aur                          1715.8 KiB  35.2 KiB/s 00:49 [------------------------------------] 100%
blackarch is up to date
warning: garuda-update-1.6.1-1 is up to date -- skipping
there is nothing to do
why this warning comes?
You can just ignore this...
That warning is there because the garuda update script is already up to date.
