I have a decent computer with good cooling. Usually, whilst mining crypto, my gpu sits around 70degrees and I don't have any issues with browsing, using chat clients and other general tasks. Lighter games even are able to run at an ok speed- though anything heavier is not plausible.
Today I started mining, my gpu is not overclocked. And even as I am typing this there are stutters and the mouse is slow. Opening applications like Dolphin feel like my pc will crash at any point. My gpu is at a healthy temp, and my cpu cores are all but un-touched. Its not like the mining program is using everything it can- not even out of the gpu. (i have not set any bottle necks or limits)
--tl;dr--
I have mutch room left in my cpu to be used. I could also push my gpu quite a bit further for more performance also. My ram is at 50% no matter how many things I open.
what can i do to enable a more efficient use of my hardware? on paper, i can do more. In practice, I have been able to do more.
System: Kernel: 5.10.14-119-tkg-bmq x86_64 bits: 64 compiler: gcc v: 10.2.1
root=UUID=8385376e-058c-4190-b13c-0411b1ce92e4 rw [email protected] quiet splash rd.udev.log_priority=3
vt.global_cursor_default=0 systemd.unified_cgroup_hierarchy=1 resume=UUID=25f83cb9-6cfa-4fc0-9ebb-5459b0de6e09
Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM Distro: Garuda Linux
Machine: Type: Desktop Mobo: ASUSTeK model: PRIME B350-PLUS v: Rev X.0x serial: <filter> UEFI [Legacy]: American Megatrends
v: 5220 date: 09/12/2019
CPU: Info: 6-Core model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+ family: 17 (23) model-id: 8 stepping: 2
microcode: 800820D L2 cache: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 92321
Speed: 1780 MHz min/max: 1550/3850 MHz boost: enabled Core speeds (MHz): 1: 1780 2: 1750 3: 1499 4: 2066 5: 1858
6: 1586 7: 1893 8: 1589 9: 1625 10: 1476 11: 2039 12: 1599
Graphics: Device-1: NVIDIA GP104 [GeForce GTX 1060 6GB] vendor: Gigabyte driver: nvidia v: 460.39
alternate: nouveau,nvidia_drm bus ID: 09:00.0 chip ID: 10de:1b83 class ID: 0300
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: loaded: nvidia display ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1449 s-dpi: 101 s-size: 965x364mm (38.0x14.3") s-diag: 1031mm (40.6")
Monitor-1: DP-0 res: 1920x1080 dpi: 82 size: 598x336mm (23.5x13.2") diag: 686mm (27")
Monitor-2: DVI-D-1 res: 1920x1080 hz: 60 dpi: 102 size: 477x268mm (18.8x10.6") diag: 547mm (21.5")
OpenGL: renderer: GeForce GTX 1060 6GB/PCIe/SSE2 v: 4.6.0 NVIDIA 460.39 direct render: Yes
Audio: Device-1: NVIDIA GP104 High Definition Audio vendor: Gigabyte driver: snd_hda_intel v: kernel bus ID: 09:00.1
chip ID: 10de:10f0 class ID: 0403
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus ID: 0b:00.3 chip ID: 1022:1457 class ID: 0403
Device-3: Cambridge Silicon Radio FiiO BTR3K type: USB driver: snd-usb-audio bus ID: 1-2:2 chip ID: 0a12:1004
class ID: 0102 serial: <filter>
Device-4: Logitech Webcam C310 type: USB driver: snd-usb-audio,uvcvideo bus ID: 1-3:3 chip ID: 046d:081b
Sound Server: ALSA v: k5.10.14-119-tkg-bmq
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK driver: r8169 v: kernel port: f000
bus ID: 03:00.0 chip ID: 10ec:8168 class ID: 0200
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: f000 bus ID: 08:00.0 chip ID: 8086:2723
class ID: 0280
IF: wlp8s0 state: up mac: <filter>
Bluetooth: Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus ID: 1-6:5 chip ID: 8087:0029 class ID: e001
Message: Required tool hciconfig not installed. Check --recommends
Drives: Local Storage: total: 1.25 TiB used: 57.57 GiB (4.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Transcend model: TS256GSSD370S size: 238.47 GiB block size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 6KB scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD10EZEX-08WN4A0 size: 931.51 GiB block size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s rotation: 7200 rpm serial: <filter> rev: 1A02 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: SanDisk model: SSD PLUS 120GB size: 111.8 GiB block size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 00RL scheme: MBR
Partition: ID-1: / raw size: 94.61 GiB size: 94.61 GiB (100.00%) used: 57.57 GiB (60.8%) fs: btrfs dev: /dev/sdc1
maj-min: 8:33
ID-2: /home raw size: 94.61 GiB size: 94.61 GiB (100.00%) used: 57.57 GiB (60.8%) fs: btrfs dev: /dev/sdc1
maj-min: 8:33
ID-3: /var/log raw size: 94.61 GiB size: 94.61 GiB (100.00%) used: 57.57 GiB (60.8%) fs: btrfs dev: /dev/sdc1
maj-min: 8:33
ID-4: /var/tmp raw size: 94.61 GiB size: 94.61 GiB (100.00%) used: 57.57 GiB (60.8%) fs: btrfs dev: /dev/sdc1
maj-min: 8:33
ID-1: swap-1 type: partition size: 17.19 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sdc2 maj-min: 8:34
ID-2: swap-2 type: zram size: 1.3 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram0
ID-3: swap-3 type: zram size: 1.3 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram1
ID-4: swap-4 type: zram size: 1.3 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram2
ID-5: swap-5 type: zram size: 1.3 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram3
ID-6: swap-6 type: zram size: 1.3 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram4
Sensors: System Temperatures: cpu: 51.2 C mobo: N/A gpu: nvidia temp: 69 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 49%
Info: Processes: 384 Uptime: 2h 28m wakeups: 0 Memory: 15.63 GiB used: 8.49 GiB (54.3%) Init: systemd v: 247 Compilers:
gcc: 10.2.0 clang: 11.0.1 Packages: pacman: 1813 lib: 548 Shell: fish v: 3.1.2 default: Bash v: 5.1.4
running in: konsole inxi: 3.3.01
