HI i am having trouble with mounting my second ssd, i have tried sudo mount and many other solutions that have worked for other people but it will not have it. when i try to mount from file manager is displays this message: An error occured while accessing ‘Corsair SSD’, the system responded: The requested operation has failed: error mounting /dev/nvme0n1p2 at /run/media/(myname)/Corsair SSD: wrong fs type, bad option, bad superblock on /dev/nvmeon1p2, missing codepage or helper program, or other error
╰─λ lsblk -d
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
sda 8:0 0 223.6G 0 disk
zram0 254:0 0 15.5G 0 disk [SWAP]
nvme0n1 259:0 0 931.5G 0 disk
Kernel: 6.6.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=4f2c60df-cf74-4f8a-9979-24c84f4cb693 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2
Mobo: ASUSTeK model: ROG STRIX B550-F GAMING v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 3404
date: 10/07/2023
Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 0 microcode: 0xA20102B
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 2200 min/max: 2200/5279 boost: disabled scaling:
driver: acpi-cpufreq governor: ondemand cores: 1: 2200 2: 2200 3: 2200
4: 2200 5: 2200 6: 2200 7: 2200 8: 2200 9: 2200 10: 2200 11: 2200 12: 2200
bogomips: 100798
Device-1: NVIDIA GA104 [GeForce RTX 3060] vendor: ZOTAC driver: nvidia
(as of 2023-10; EOL~2026-12-xx) arch: Ampere code: GAxxx
lanes: 16 ports: active: none off: DP-1,HDMI-A-1 empty: DP-2,DP-3
bus-ID: 0a:00.0 chip-ID: 10de:2487 class-ID: 0300
Device-2: Generalplus GENERAL WEBCAM driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:3
chip-ID: 1b3f:1167 class-ID: 0102 serial: <filter>
alternate: fbdev,nv,vesa gpu: nvidia,nvidia-nvswitch display-ID: :0
Screen-1: 0 s-res: 3840x1080 s-dpi: 93 s-size: 1049x292mm (41.30x11.50")
s-diag: 1089mm (42.87")
Monitor-1: DP-1 mapped: DP-0 note: disabled pos: primary,left
model: MSI G24C4 serial: <filter> built: 2022 res: 1920x1080 dpi: 94
gamma: 1.2 size: 521x293mm (20.51x11.54") diag: 598mm (23.5") ratio: 16:9
Monitor-2: HDMI-A-1 mapped: HDMI-0 note: disabled pos: right
model: Samsung F24G3xTF serial: <filter> built: 2021 res: 1920x1080 dpi: 93
gamma: 1.2 size: 527x296mm (20.75x11.65") diag: 604mm (23.8") ratio: 16:9
inactive: wayland,device-1
memory: 11.72 GiB
API: Vulkan v: 1.3.269 layers: 14 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3060 driver: nvidia v: 545.29.06
device-ID: 10de:2487 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
Device-1: NVIDIA GA104 High Definition Audio vendor: ZOTAC
bus-ID: 0a:00.1 chip-ID: 10de:228b class-ID: 0403
Device-3: ASUSTek USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1:2
chip-ID: 0b05:1876 class-ID: 0300 serial: <filter>
Device-4: Generalplus GENERAL WEBCAM driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.6.4-zen1-1-zen status: kernel-api with: aoss
Device-1: Realtek driver: rtw89_8852be v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 06:00.0 chip-ID: 10ec:b852
IF: wlp6s0 state: up mac: <filter>
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 09:00.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7.4:5 chip-ID: 0bda:b85b
lmp-v: 12 status: discoverable: no pairing: no class-ID: 7c0104
Local Storage: total: 1.13 TiB used: 21.85 GiB (1.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Corsair model: MP600 CORE
lanes: 4 tech: SSD serial: <filter> fw-rev: EGFM52.3 temp: 39.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: WDC WDS240G2G0B-00EPW0
tech: SSD serial: <filter> fw-rev: 0400 scheme: GPT
used: 21.85 GiB (9.8%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 65.1 C mobo: N/A gpu: nvidia temp: 46 C
Processes: 362 Uptime: 21m wakeups: 0 Memory: total: 16 GiB
available: 15.53 GiB used: 4.15 GiB (26.7%) Init: systemd v: 254
pm: pacman pkgs: 1834 libs: 531 tools: gnome-software,octopi,paru
Shell: fish v: 3.6.2 running-in: konsole inxi: 3.3.31
Garuda (2.6.19-2):
System install date: 2023-12-07
Last full system update: 2023-12-07
the console recognises the ssd is there but im not sure what else i can do
