Hey good people.
I've been using Garuda exclusively for almost 6 months, and I'd like to air some of the things I have been having a problem with. But first some story.
I started my journey in LInux in 2001. When I installed Debian on a school pc. Soon that ended up in me testing Slackware, then RedHat, SuSe, and then Gentoo. At this time getting my graphics card to function properly was a hassle, and I reluctantly reverted back to Windows. I ever so often tried diffrent new versions of Linux as there was new ones. And during the last few years Ubuntu and Kubuntu has been my tests. But never really felt at home. Arch fixed this, and Garuda is by far the best I have tried so far.
I am by no means a super user. I manage to get some problems fixed, whilst other I have no clue on how to get around. And I'd like to mention some of the problems I have and maybe get someone to fill my heads on what to search for. I will be posting my garuda-inix at the end.
- Terminal resolution. And by terminal I am not talking about the terminal of witch my window manager use. I am talking about the tty's. The text there is rather small. Too small for someone to effectively use it. But you have the Window Manager... yes and sometimes you don't.
Been trying to fix this by going into the grub configs and manually changing the resolution, but this keeps failing me.
Sddm is also really small. seems my resolution is 3840x2160 and whilst I in KDE can set up a scale that makes everything readable, this tends to fail in Sddm. I've tried installing gdm instead, and this scales up, but the resolution cant be changed.
My resolution on the desktop cant be changed anymore. I say anymore because I cannot change it anymore since some update in January. I cannot say what went wrong, but I have been trying everything I can thionk of to be able to change it again. I'd really like to be able to set it to 1080p. Mostly because I play an old windows Game(Anarchy Online) that has got no way of scaling the GUI (to my knowledge) and reading stuff in game is straining on the eyes.
For this I have tried downgrading driver (nvidia), Ive tried setting resolution with xredr. I've tried adding modes, deleting modes. I've tried installing the system all over again. I've tried using another DM (gdm)... When using gdm the screen still goes black, BUT I can see the mousepointer, and it can only move in the top left side of the screen suggesting to me that... I dont know... THis makes me afraid of trying to sett the resolution in any other capasity. I need the TTY to get back after things blackout.. Been thinking it might be something with the display. That it is somehow not configured properly. But my expertise is far from there.
Other than theese things I really have nothing bothersome that I can point to. Good Job!!!
garuda-inix:
[🔍] × sudo garuda-inxi
[sudo] password for aia:
Kernel: 5.16.10-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=7a1a328c-6a99-45ff-973a-08bb2de00f48 rw [email protected]
resume=UUID=9d11bc5e-9535-457a-86a0-41eb16d4ca92 loglevel=3
Console: pty pts/1 wm: kwin_x11 DM: GDM 41.3, SDDM Distro: Garuda Linux
Type: Laptop System: LENOVO product: 20378 v: Lenovo Y50-70
serial: <filter> Chassis: type: 10 v: Lenovo Y50-70 serial: <filter>
Mobo: LENOVO model: Lenovo Y50-70 v: 31900058WIN serial: <filter>
UEFI: LENOVO v: 9ECN36WW(V2.00) date: 01/12/2015
ID-1: BAT1 charge: 37.2 Wh (100.0%) condition: 37.2/54.8 Wh (67.9%)
volts: 8.0 min: 7.4 model: LENOVO PABAS0241231 type: Li-ion
serial: <filter> status: Full
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard K270
status: Discharging
Info: model: Intel Core i7-4720HQ socket: LGA1150 (U3E1) note: check
bits: 64 type: MT MCP arch: Haswell family: 6 model-id: 0x3C (60)
stepping: 3 microcode: 0x28
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 2595 high: 2597 min/max: 800/3600 base/boost: 2600/2600
scaling: driver: intel_cpufreq governor: performance volts: 0.8 V
ext-clock: 100 MHz cores: 1: 2594 2: 2595 3: 2595 4: 2597 5: 2595 6: 2596
7: 2594 8: 2597 bogomips: 41507
Type: l1tf
Device-1: Intel 4th Gen Core Processor Integrated Graphics vendor: Lenovo
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0416 class-ID: 0300
Device-2: NVIDIA GM107M [GeForce GTX 960M] vendor: Lenovo driver: nvidia
v: 510.54 alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:139b
class-ID: 0302
Device-3: Acer Lenovo EasyCamera type: USB driver: uvcvideo bus-ID: 3-6:3
chip-ID: 5986:055e class-ID: 0e02 serial: <filter>
Display: server: X.Org 1.21.1.3 compositor: kwin_x11 driver:
loaded: modesetting,nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x2160 s-dpi: 96 s-size: 1016x571mm (40.0x22.5")
s-diag: 1165mm (45.9")
Monitor-1: eDP-1-1 res: 3840x2160 hz: 48 dpi: 284
OpenGL: renderer: NVIDIA GeForce GTX 960M/PCIe/SSE2
v: 4.6.0 NVIDIA 510.54 direct render: Yes
vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 00:03.0
Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
Sound Server-1: ALSA v: k5.16.10-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.47 running: yes
Device-1: Intel Wireless 3160 driver: iwlwifi v: kernel bus-ID: 08:00.0
chip-ID: 8086:08b4 class-ID: 0280
IF: wlp8s0 state: up mac: <filter>
vendor: Lenovo driver: r8169 v: kernel port: 3000 bus-ID: 09:00.0
bus-ID: 3-7:5 chip-ID: 8087:07dc class-ID: e001
Local Storage: total: 476.94 GiB used: 34.74 GiB (7.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: MZ7TE512HMHP-000L2
family: based SSDs size: 476.94 GiB block-size: physical: 512 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: SSD serial: <filter>
rev: 6L0Q temp: 29 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 6y 101d 10h cycles: 1595
ID-1: / raw-size: 459.55 GiB size: 459.55 GiB (100.00%)
used: 34.74 GiB (7.6%) fs: btrfs block-size: 4096 B dev: /dev/sda2
maj-min: 8:2
used: 576 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 459.55 GiB size: 459.55 GiB (100.00%)
maj-min: 8:2
ID-4: /var/log raw-size: 459.55 GiB size: 459.55 GiB (100.00%)
maj-min: 8:2
ID-5: /var/tmp raw-size: 459.55 GiB size: 459.55 GiB (100.00%)
maj-min: 8:2
ID-1: swap-1 type: partition size: 17.09 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 15.54 GiB used: 1.8 MiB (0.0%)
System Temperatures: cpu: 56.0 C mobo: N/A gpu: nvidia temp: 47 C
Processes: 303 Uptime: 3h 40m wakeups: 13 Memory: 15.54 GiB
used: 3.54 GiB (22.8%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 2050 lib: 584
inxi: 3.3.12
Garuda (2.5.5-1):
System install date: 2022-02-21
Last full system update: 2022-02-21
Failed units: nmb.service
╭─[email protected] in ~ as 🧙 took 4s
