how can i recover my data
Do you use Garuda?
yes dragonized version
Without your inxi -Faz
output how do I know you are not a closet Ubuntu user?
Generally Garuda users know that output is required for assistance on our forum.
Kernel: 5.15.12-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=6728fa15-4e0e-4baf-b17c-cdc4a0c19e74 rw rootflags=subvol=@
resume=UUID=3b44cfad-4af0-42cb-a877-0f4fdc8ffeb4 loglevel=3
Type: Laptop System: Hewlett-Packard product: HP ProBook 4510s v: F.14
Mobo: Hewlett-Packard model: 3072 v: KBC Version 24.0E
serial: <superuser required> BIOS: Hewlett-Packard v: 68PZI Ver. F.14
date: 12/30/2009
Info: model: Intel Core2 Duo P8700 bits: 64 type: MCP arch: Core Penryn
family: 6 model-id: 0x17 (23) stepping: 0xA (10) microcode: 0xA0B
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 128 KiB
desc: d-2x32 KiB; i-2x32 KiB L2: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1838 high: 2005 min/max: 800/2534 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2005 2: 1671
bogomips: 10108
Flags: ht lm nx pae sse sse2 sse3 sse4_1 ssse3
Type: mds
status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT disabled
mitigation: Full generic retpoline, STIBP: disabled, RSB filling
Device-1: Intel Mobile 4 Series Integrated Graphics vendor: Hewlett-Packard
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:2a42 class-ID: 0300
loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :0
s-diag: 414mm (16.3")
Monitor-1: LVDS1 res: 1366x768 hz: 60 dpi: 102
size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
Device-1: Intel 82801I HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:293e
Sound Server-1: ALSA v: k5.15.12-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.42 running: yes
Device-1: Marvell 88E8072 PCI-E Gigabit Ethernet vendor: Hewlett-Packard
driver: sky2 v: 1.30 port: 2000 bus-ID: 84:00.0 chip-ID: 11ab:436c
IF: ens5 state: down mac: <filter>
Device-2: Ralink MT7601U Wireless Adapter type: USB driver: mt7601u
bus-ID: 2-2:3 chip-ID: 148f:7601 class-ID: 0000 serial: <filter>
IF: wlp0s29f7u2 state: up mac: <filter>
Local Storage: total: 156.51 GiB used: 18.86 GiB (12.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST9160412AS
size: 149.05 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: HPM1 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: SanDisk
model: Cruzer Blade size: 7.45 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: 1.26 scheme: GPT
ID-1: / raw-size: 140.83 GiB size: 140.83 GiB (100.00%)
used: 16.68 GiB (11.8%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 140.83 GiB size: 140.83 GiB (100.00%)
ID-3: /var/log raw-size: 140.83 GiB size: 140.83 GiB (100.00%)
ID-4: /var/tmp raw-size: 140.83 GiB size: 140.83 GiB (100.00%)
ID-1: swap-1 type: zram size: 3.73 GiB used: 22.5 MiB (0.6%)
ID-2: swap-2 type: partition size: 8.21 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 60.0 C mobo: 16.0 C
Processes: 190 Uptime: 19m wakeups: 1 Memory: 3.73 GiB
used: 1.77 GiB (47.3%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1178 lib: 317 Shell: fish
v: 3.3.1 default: Bash v: 5.1.12 running-in: konsole inxi: 3.3.11
This is not a data recovery forum, but if you post more information about what is happening perhaps someone can help you.
What is the file system on this drive?
How old is the drive?
What types of files are you wanting to recover?
How long does the drive mount for before it unmounts?
Perhaps you could install some software to help you recover the files such as ddrescue.
filesystem is fat32
its more than 7 year old
it took arount 10 seconds before unmounting
there are jpeg file in pendrive
Have you checked what your journal and dmesg show about your USB?
e.g.
journalctl -b | grep usb
You also may want to consider a lighter edition (although this shouldn’t be related to the USB problem), since I see your HW is quite old and barely reaching the minimum requirements:
PS: I edited your inxi specs post adding ~~~ before and after the text block for raw formatting. Please consider this in the future
Do you have another computer you could try mounting the drive in?
Have you tested this drive on other USB ports?
Do you have another disk with a live boot on it?
If you do, see if it will mount properly from the live environment?
How long have you had Garuda installed for?
Has this been like this since you installed, or did this just start happening?
Are other flash drives mounting correctly?
Further questions:
- How often is the drive used? When it's used is it only read from, or are files being written to it too?
-- Has the drive been in a drawer for 7 years? Or rather, has the drive been dormant for an extended period of time? - What USB technology? 2? 3? Likely 2 if you said it's 7 years old.
- Are you connecting to a usb port that is directly attached to the motherboard, or are you attaching to say a USB hub, etc?
- Has this drive become intermittently operational only when using Garuda? If you were to plug it into say a Windows OS computer, does it exhibit the same intermittent mount/dismount issues?
-- Furthermore, if you plug the drive into a Windows computer, does it state something along the lines of the drive needs to be 'repaired' or 'filesystem checked'?
e: dang it, so sorry mods, for some reason old threads will pop up in my 'suggested threads' underneath current posts, apologies for re-bumping an old post.
No worries, nothing wrong with reading old threads but try to make a habit of checking the date before you jump in.
I think sometimes the "suggested" threads discuss topics which appear to be similar or related to whatever you are currently reading. You are right: sometimes the suggestions are old.
I'll close this one down.
