I see it’s solved now
I think this could be a good time to check your sudo btrfs filesystem usage /
and, if necessary, balance.
I leave you a couple of posts I bookmarked long ago to start reading how it works:
And how to do it (I suggest not to go for a full balance with the Garuda assistant):
Actually, @diehardman , you shouldn't be worried at all. This space will fill, only upto 5 snapshots by default. Then on, there won't be any crazy filling of space.
So, just take a deep breath and keep calm. You should be concerned only if 3 to 4 GB is left.
it usually devolves to filling with 5 or 6 gb left in the end, i deleted my last garuda dragonized system due to this reason, its perfect distro for me as i spend 5 hours setting up my os and customizing it.
No screenshot, please, just text, formatted with 3 ~ before and after.
In my opinion, it's high time to balance ("compare the difference between "unallocated" and "free", and "allocated" and "used"").
