My kernel is missing?
Not sure what I did here but I saw this after I did my update ):
> --> A problem with the NVIDIA drivers has been detected
> ---> Building NVIDIA DKMS module for kernel 6.12.9-arch1-1
> Module nvidia/565.77 is not installed for kernel 6.12.9-arch1-1 (x86_64). Skipping...
> Module nvidia/565.77 is not built for kernel 6.12.9-arch1-1 (x86_64). Skipping...
> Error! Your kernel headers for kernel 6.12.9-arch1-1 cannot be found at /usr/lib/modules/6.12.9-arch1-1/build or /usr/lib/modules/6.12.9-arch1-1/source.
> Please install the linux-headers-6.12.9-arch1-1 package or use the --kernelsourcedir option to tell DKMS where it's located.
> ---> Failed to build NVIDIA DKMS module for kernel 6.12.9-arch1-1
here’s my inxi :slight_smile:
> System:
> Kernel: 6.12.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
> clocksource: tsc avail: hpet,acpi_pm
> parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen
> root=UUID=be2baabb-680e-435e-a284-2cd7f35957a1 rw rootflags=subvol=@
> sysrq_always_enabled=1 brightnessctl set 50%
> Desktop: KDE Plasma v: 6.2.5 tk: Qt v: N/A info: frameworks v: 6.10.0
> wm: kwin_wayland tools: avail: gtklock vt: 1 dm: SDDM Distro: Garuda
> base: Arch Linux
> Machine:
> Type: Laptop System: HP product: OMEN Gaming Laptop 17z-db000 v: N/A
> serial: <superuser required> Chassis: type: 10 serial: <superuser required>
> Mobo: HP model: 8C74 v: 03.35 serial: <superuser required>
> part-nu: 9A9V4AV uuid: <superuser required> UEFI: AMI v: F.10
> date: 07/11/2024
> Battery:
> ID-1: BAT0 charge: 63.0 Wh (75.9%) condition: 83.0/83.0 Wh (100.0%)
> power: 40.9 W volts: 12.9 min: 11.6 model: HP Primary type: Li-ion
> serial: <filter> status: charging cycles: 16
> CPU:
> Info: model: AMD Ryzen 5 8645HS w/ Radeon 760M Graphics bits: 64
> type: MT MCP arch: Zen 4 gen: 4 level: v4 note: check built: 2022+
> process: TSMC n5 (5nm) family: 0x19 (25) model-id: 0x75 (117) stepping: 2
> microcode: 0xA705206
> Topology: cpus: 1x dies: 1 clusters: 1 cores: 6 threads: 12 tpc: 2
> smt: enabled cache: L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 6 MiB
> desc: 6x1024 KiB L3: 16 MiB desc: 1x16 MiB
> Speed (MHz): avg: 400 min/max: 400/4301 boost: disabled scaling:
> driver: amd-pstate-epp governor: performance cores: 1: 400 2: 400 3: 400
> 4: 400 5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 400
> bogomips: 103005
> Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
> Vulnerabilities: <filter>
> Graphics:
> Device-1: NVIDIA AD107M [GeForce RTX 4060 Max-Q / Mobile]
> vendor: Hewlett-Packard driver: nvidia v: 565.77
> alternate: nouveau,nvidia_drm non-free: 550.xx+
> status: current (as of 2024-09) arch: Lovelace code: AD1xx
> process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 8
> ports: active: none off: eDP-1 empty: HDMI-A-1 bus-ID: 01:00.0
> chip-ID: 10de:28a0 class-ID: 0300
> Device-2: Advanced Micro Devices [AMD/ATI] Phoenix3
> vendor: Hewlett-Packard driver: amdgpu v: kernel arch: RDNA-3 code: Phoenix
> process: TSMC n4 (4nm) built: 2023+ pcie: gen: 4 speed: 16 GT/s lanes: 16
> ports: active: none empty: DP-1, DP-2, DP-3, DP-4, DP-5, DP-6, DP-7,
> DP-8, Writeback-1, eDP-2 bus-ID: 05:00.0 chip-ID: 1002:1900 class-ID: 0300
> temp: 31.0 C
> Device-3: Quanta HP True Vision FHD Camera driver: uvcvideo type: USB
> rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 0408:548d
> class-ID: fe01 serial: <filter>
> Display: wayland server: X.org v: 1.21.1.15 with: Xwayland v: 24.1.4
> compositor: kwin_wayland driver: X: loaded: amdgpu,nvidia
> unloaded: modesetting,nouveau alternate: fbdev,nv,vesa dri: radeonsi
> gpu: nvidia,amdgpu display-ID: 0
> Monitor-1: eDP-1 res: 1920x1080 size: N/A modes: N/A
> API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia gbm:
> drv: nvidia surfaceless: drv: nvidia wayland: drv: nvidia x11: drv: nvidia
> API: OpenGL v: 4.6.0 vendor: nvidia v: 565.77 glx-v: 1.4
> direct-render: yes renderer: NVIDIA GeForce RTX 4060 Laptop GPU/PCIe/SSE2
> memory: 7.81 GiB display-ID: :1.0
> API: Vulkan v: 1.4.303 layers: 5 device: 0 type: discrete-gpu name: NVIDIA
> GeForce RTX 4060 Laptop GPU driver: N/A device-ID: 10de:28a0
> surfaces: xcb,xlib,wayland device: 1 type: integrated-gpu name: AMD
> Radeon Graphics (RADV GFX1103_R1) driver: N/A device-ID: 1002:1900
> surfaces: xcb,xlib,wayland device: 2 type: cpu name: llvmpipe (LLVM
> 18.1.8 256 bits) driver: N/A device-ID: 10005:0000
> Audio:
> Device-1: NVIDIA AD107 High Definition Audio vendor: Hewlett-Packard
> driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 8
> bus-ID: 01:00.1 chip-ID: 10de:22be class-ID: 0403
> Device-2: Advanced Micro Devices [AMD/ATI] Rembrandt Radeon High
> Definition Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
> pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 05:00.1 chip-ID: 1002:1640
> class-ID: 0403
> Device-3: Advanced Micro Devices [AMD] ACP/ACP3X/ACP6x Audio Coprocessor
> vendor: Hewlett-Packard driver: snd_pci_ps v: kernel
> alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x,
> snd_acp_pci, snd_rpl_pci_acp6x, snd_sof_amd_renoir,
> snd_sof_amd_rembrandt, snd_sof_amd_vangogh, snd_sof_amd_acp63,
> snd_sof_amd_acp70 pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 05:00.5
> chip-ID: 1022:15e2 class-ID: 0480
> Device-4: Advanced Micro Devices [AMD] Family 17h/19h/1ah HD Audio
> vendor: Hewlett-Packard driver: snd_hda_intel v: kernel pcie: gen: 4
> speed: 16 GT/s lanes: 16 bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
> API: ALSA v: k6.12.8-zen1-1-zen status: kernel-api with: aoss
> type: oss-emulator tools: alsactl,alsamixer,amixer
> Server-1: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
> status: active 2: wireplumber status: active 3: pipewire-alsa type: plugin
> 4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
> Network:
> Device-1: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
> vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
> lanes: 1 port: e000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
> IF: eno1 state: down mac: <filter>
> Device-2: Realtek RTL8852BE PCIe 802.11ax Wireless Network
> vendor: Hewlett-Packard driver: rtw89_8852be v: kernel pcie: gen: 1
> speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 04:00.0 chip-ID: 10ec:b852
> class-ID: 0280
> IF: wlo1 state: up mac: <filter>
> Info: services: NetworkManager, smbd, systemd-timesyncd, wpa_supplicant
> Bluetooth:
> Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
> speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:3 chip-ID: 0bda:b85c
> class-ID: e001 serial: <filter>
> Report: btmgmt ID: hci0 rfk-id: 0 state: down bt-service: enabled,running
> rfk-block: hardware: no software: no address: <filter> bt-v: 5.2 lmp-v: 11
> status: discoverable: no pairing: no
> Drives:
> Local Storage: total: 953.87 GiB used: 107.61 GiB (11.3%)
> SMART Message: Unable to run smartctl. Root privileges required.
> ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: KIOXIA model: N/A
> size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
> lanes: 4 tech: SSD serial: <filter> fw-rev: HP01AP40 temp: 30.9 C
> scheme: GPT
> Partition:
> ID-1: / raw-size: 953.57 GiB size: 953.57 GiB (100.00%)
> used: 107.61 GiB (11.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
> ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%)
> used: 584 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
> ID-3: /home raw-size: 953.57 GiB size: 953.57 GiB (100.00%)
> ID-4: /var/log raw-size: 953.57 GiB size: 953.57 GiB (100.00%)
> ID-5: /var/tmp raw-size: 953.57 GiB size: 953.57 GiB (100.00%)
> Swap:
> Kernel: swappiness: 133 (default 60) cache-pressure: 100 (default) zswap: no
> ID-1: swap-1 type: zram size: 30.61 GiB used: 0 KiB (0.0%) priority: 100
> comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 12
> dev: /dev/zram0
> Sensors:
> System Temperatures: cpu: 41.0 C mobo: N/A gpu: amdgpu temp: 31.0 C
> Fan Speeds (rpm): cpu: 2124 fan-2: 1889
> Info:
> Memory: total: 32 GiB note: est. available: 30.61 GiB used: 4.11 GiB (13.4%)
> Processes: 370 Power: uptime: 50m states: freeze,mem,disk suspend: s2idle
> wakeups: 0 hibernate: platform avail: shutdown, reboot, suspend, test_resume
> image: 12.19 GiB services: org_kde_powerdevil,upowerd Init: systemd v: 257
> default: graphical tool: systemctl
> Packages: pm: pacman pkgs: 2043 libs: 449 tools: octopi,paru Compilers:
> clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi default: fish v: 3.7.1
> running-in: konsole inxi: 3.3.36
> Garuda (2.6.26-1.1):
> System install date:     2025-01-03
> Last full system update: 2025-01-12 ↻
> Is partially upgraded:   No
> Relevant software:       snapper NetworkManager dracut nvidia-dkms
> Windows dual boot:       Probably (Run as root to verify)
> Failed units:            grub-btrfs-snapper.service
Reboot and check garuda-inxi
> System:
> Kernel: 6.12.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
> base: Arch Linux
> Machine:
> date: 07/11/2024
> Battery:
> ID-1: BAT0 charge: 78.5 Wh (94.6%) condition: 83.0/83.0 Wh (100.0%)
> power: 9.9 W volts: 13.2 min: 11.6 model: HP Primary type: Li-ion
> CPU:
> Speed (MHz): avg: 3991 min/max: 400/5015 boost: enabled scaling:
> driver: amd-pstate-epp governor: performance cores: 1: 3991 2: 3991 3: 3991
> 4: 3991 5: 3991 6: 3991 7: 3991 8: 3991 9: 3991 10: 3991 11: 3991 12: 3991
> bogomips: 103011
> Graphics:
> ports: active: none empty: HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:28a0
> class-ID: 0300
> ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, DP-5, DP-6, DP-7,
> DP-8, Writeback-1 bus-ID: 05:00.0 chip-ID: 1002:1900 class-ID: 0300
> temp: 40.0 C
> API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
> drv: nvidia gbm: drv: nvidia surfaceless: drv: nvidia wayland: drv: radeonsi
> x11: drv: radeonsi
> API: OpenGL v: 4.6.0 compat-v: 4.6 vendor: amd mesa v: 24.3.3-arch1.1
> glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (radeonsi
> gfx1103_r1 LLVM 18.1.8 DRM 3.59 6.12.9-zen1-1-zen) device-ID: 1002:1900
> memory: 500 MiB unified: no display-ID: :1.0
> API: Vulkan v: 1.4.303 layers: 5 device: 0 type: integrated-gpu name: AMD
> surfaces: xcb,xlib,wayland device: 1 type: discrete-gpu name: NVIDIA
> Audio:
> class-ID: 0403
> API: ALSA v: k6.12.9-zen1-1-zen status: kernel-api with: aoss
> Network:
> class-ID: 0280
> Bluetooth:
> Drives:
> Local Storage: total: 953.87 GiB used: 107.93 GiB (11.3%)
> lanes: 4 tech: SSD serial: <filter> fw-rev: HP01AP40 temp: 34.9 C
> scheme: GPT
> Partition:
> used: 107.93 GiB (11.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
> Swap:
> dev: /dev/zram0
> Sensors:
> System Temperatures: cpu: 39.2 C mobo: N/A gpu: amdgpu temp: 41.0 C
> Fan Speeds (rpm): cpu: 0 fan-2: 0
> Info:
> Memory: total: 32 GiB note: est. available: 30.61 GiB used: 2.61 GiB (8.5%)
> Processes: 502 Power: uptime: 0m states: freeze,mem,disk suspend: s2idle
> Failed units:
perhaps it’s fixed now???
Use
sudo pacman -S linux-headers
You use
not the linux-kernel
You can check with
 mhwd-kernel -li
your installed kernel.
when I ran mhwd-kernel -li this was my result
Currently running: 6.12.9-zen1-1-zen (linux-zen)
The following kernels are installed in your system:
local/linux-clear 6.12.6-1
local/linux 6.12.9.arch1-1
local/linux-hardened 6.12.9.hardened1-1
local/linux-zen 6.12.9.zen1-1
local/linux-lts 6.6.70-1
I was able to install the headers successfully
Cool, always install kernel and headers.
