My desktop is not starting
Greetings,
I have encountered a problem, suddenly my desktop stopped loading, I left my Pc for around 2 hours and when I came back , exited lock screen, and nothing, just a black screen.
I tried restart, I tried restarting sddm, I tried reinstalling plasma, changed between X-11 and wayland, manually starting X-11 and Wayland, changed wallpaper (i use wallpaper engine, changed it to solid color), and finally full system update, checked the help forums, youtube, and even A.I models for help, and nothing is working !!!
that is the strangest problem I faced
Edit: one more thing, after the system update, X-11 is not available anymore!! only Wayland
here is my garuda-inxi
i
Kernel: 6.15.4-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
root=UUID=bb40fee6-5116-4cd0-a372-fa94829b0712 rw rootflags=subvol=@
quiet loglevel=3 splash ibt=off
Desktop: KDE Plasma v: 6.4.2 tk: Qt v: N/A info: frameworks v: 6.15.0
Type: Desktop Mobo: Micro-Star model: MPG Z690 CARBON WIFI (MS-7D30) v: 1.0
Megatrends LLC. v: 1.C0 date: 05/30/2023
Info: model: 13th Gen Intel Core i7-13700 bits: 64 type: MST AMCP
microcode: 0x12F
Topology: cpus: 1x dies: 1 clusters: 10 cores: 16 threads: 24 mt: 8 tpc: 2
st: 8 smt: enabled cache: L1: 1.4 MiB desc: d-8x32 KiB, 8x48 KiB; i-8x32
KiB, 8x64 KiB L2: 24 MiB desc: 8x2 MiB, 2x4 MiB L3: 30 MiB desc: 1x30 MiB
Speed (MHz): avg: 800 min/max: 800/5100:5200:4100 scaling:
5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800
15: 800 16: 800 17: 800 18: 800 19: 800 20: 800 21: 800 22: 800 23: 800
24: 800 bogomips: 101376
Device-1: Intel Raptor Lake-S GT1 [UHD Graphics 770] vendor: Micro-Star MSI
built: 2020-21 ports: active: none empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2,
HDMI-A-3, HDMI-A-4 bus-ID: 00:02.0 chip-ID: 8086:a780 class-ID: 0380
Device-2: NVIDIA AD104 [GeForce RTX 4070 Ti] vendor: ASUSTeK
driver: nvidia v: 575.64 alternate: nouveau,nvidia_drm non-free: 550-570.xx+
status: current (as of 2025-04) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: none off: HDMI-A-5 empty: DP-3, DP-4, DP-5, HDMI-A-6
bus-ID: 01:00.0 chip-ID: 10de:2782 class-ID: 0300
Monitor-1: HDMI-A-5 model: Mi Monitor serial: <filter> built: 2021 res:
mode: 3440x1440 hz: 100 scale: 100% (1) dpi: 110 gamma: 1.2
size: 797x334mm (31.38x13.15") diag: 864mm (34") modes: max: 3440x1440
min: 640x480
inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 575.64
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4070 Ti/PCIe/SSE2
memory: 11.71 GiB display-ID: :1.0
API: Vulkan v: 1.4.313 layers: 15 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 4070 Ti driver: nvidia v: 575.64 device-ID: 10de:2782
surfaces: N/A device: 1 type: integrated-gpu name: Intel Graphics (RPL-S)
driver: mesa intel v: 25.1.4-arch1.2 device-ID: 8086:a780 surfaces: N/A
device: 2 type: cpu name: llvmpipe (LLVM 20.1.6 256 bits)
driver: mesa llvmpipe v: 25.1.4-arch1.2 (LLVM 20.1.6)
Device-1: Intel Alder Lake-S HD Audio vendor: Micro-Star MSI
bus-ID: 00:1f.3 chip-ID: 8086:7ad0 class-ID: 0403
Device-2: NVIDIA AD104 High Definition Audio vendor: ASUSTeK
Device-3: Micro Star USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:3
chip-ID: 0db0:005a class-ID: 0300
Device-4: Kingston HyperX Cloud Flight Wireless
lanes: 1 mode: 1.1 bus-ID: 1-7.2:9 chip-ID: 0951:1723 class-ID: 0300
API: ALSA v: k6.15.4-zen2-1-zen status: kernel-api with: aoss
Device-1: Intel Ethernet I225-V vendor: Micro-Star MSI driver: igc v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 04:00.0
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 05:00.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:14 chip-ID: 8087:0032
Report: btmgmt ID: hci0 rfk-id: 2 state: up address: N/A
Local Storage: total: 931.51 GiB used: 782.15 GiB (84.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNV2S1000G
lanes: 4 tech: SSD serial: <filter> fw-rev: SBM02103 temp: 46.9 C
ID-1: / raw-size: 195.26 GiB size: 195.26 GiB (100.00%)
used: 190.47 GiB (97.5%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
used: 26.2 MiB (27.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 195.26 GiB size: 195.26 GiB (100.00%)
ID-4: /var/log raw-size: 195.26 GiB size: 195.26 GiB (100.00%)
ID-5: /var/tmp raw-size: 195.26 GiB size: 195.26 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.12 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 40.8 C mobo: N/A
Memory: total: 32 GiB note: est. available: 31.12 GiB used: 3.18 GiB (10.2%)
Processes: 469 Power: uptime: 16m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.34 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2038 libs: 562 tools: octopi,paru Compilers:
clang: 20.1.7 gcc: 15.1.1 Shell: garuda-inxi default: fish v: 4.0.2
Garuda (2.7.3-1):
System install date:     2024-11-30
Last full system update: 2025-07-02
any help would be much appreciated
Thank you
X11 need manually action, please use forum search, problem is solved.
