I just went to update and I get mwhd-garuda-git wants to update, but it can’t because mwhd-garuda is already install. When I go to manually install it I get the expected conflict and am asked if I want to replace mwhd-garua with the git version and it errors out leaving the non-git version. Is there a fix or fix in the works for this? Thanks
╭─locutus@Unimatrix in ~
╰─λ upd
[sudo] password for locutus:
garuda is up to date
herecura is up to date
core is up to date
extra 8.3 MiB 14.5 MiB/s 00:01 [------------------------------------] 100%
multilib is up to date
chaotic-aur 2.6 MiB 3.00 MiB/s 00:01 [------------------------------------] 100%
arcolinux_repo 145.0 KiB 1151 KiB/s 00:00 [------------------------------------] 100%
arcolinux_repo_3party 362.2 KiB 2.06 MiB/s 00:00 [------------------------------------] 100%
arcolinux_repo_xlarge 40.4 KiB 358 KiB/s 00:00 [------------------------------------] 100%
nemesis_repo is up to date
endeavouros is up to date
Reborn-OS is up to date
cachyos-v3 123.5 KiB 94.4 KiB/s 00:01 [------------------------------------] 100%
cachyos-core-v3 129.2 KiB 99.7 KiB/s 00:01 [------------------------------------] 100%
cachyos-extra-v3 3.7 MiB 1605 KiB/s 00:02 [------------------------------------] 100%
cachyos is up to date
garuda downloading...
herecura downloading...
core downloading...
extra downloading...
multilib downloading...
chaotic-aur downloading...
arcolinux_repo downloading...
arcolinux_repo_3party downloading...
arcolinux_repo_xlarge downloading...
nemesis_repo downloading...
endeavouros downloading...
Reborn-OS downloading...
cachyos-v3 downloading...
cachyos-core-v3 downloading...
cachyos-extra-v3 downloading...
cachyos downloading...
:: Replace mhwd-garuda-git with garuda/mhwd-garuda? [Y/n] y
warning: pacman: local (6.0.2-14) is newer than core (6.0.2-8)
warning: stacer: local (1.1.0-1.4) is newer than arcolinux_repo_3party (1.1.0-1)
resolving dependencies...
Package (2) Old Version New Version Net Change
garuda/mhwd-garuda 1.1.4-1 0.27 MiB
mhwd-garuda-git r25.3a28734-1 -0.27 MiB
Total Installed Size: 0.27 MiB
Net Upgrade Size: 0.00 MiB
(1/1) checking keys in keyring [------------------------------------] 100%
(1/1) checking package integrity [------------------------------------] 100%
(1/1) loading package files [------------------------------------] 100%
(1/1) checking for file conflicts [------------------------------------] 100%
(2/2) checking available disk space [------------------------------------] 100%
==> root: 492
(1/1) removing mhwd-garuda-git [------------------------------------] 100%
/tmp/alpm_lhjwjE/.INSTALL: line 27: mhwd-gpu: command not found
(1/1) installing mhwd-garuda [------------------------------------] 100%
(1/7) Arming ConditionNeedsUpdate...
(2/7) Updating linux initcpios...
(3/7) Foreign/AUR package notification
aur-check-updates-bin 1.0.10-1
bauh-staging 0.10.7.RC-3
emby-server-beta 4.8.0.67-1
flaresolverr-bin 3.3.12-1
freefilesync-bin 13.3-1
kf5-servicemenus-rootactions-git r16.cdfe53f-3
komga 1.10.1-1
libretro-duckstation 2105-2
plasma5-applets-tiledmenu 42-2
plasma5-applets-volumewin7mixer 26-1
prowlarr-nightly 1.12.2.4209-1
radarr-develop 5.3.1.8438-1
renamemytvseries-qt-bin 2.1.8-1
searchmonkey-gtk 0.8.3-2
sharik-bin 3.1-4
sonarr-develop 4.0.0.836-1
(4/7) Orphaned package notification...
kdsoap-ws-discovery-client 0.3.0-2
libinput-gestures-qt 0.4-1
python-build 1.0.3-1
python-installer 0.7.0-3
python-wheel 0.42.0-1
wayland-protocols 1.32-1
(5/7) Checking for .pacnew and .pacsave files...
(6/7) Performing snapper post snapshots for the following configurations...
==> root: 493
(7/7) Syncing all file systems...
The non-git one is supposed to replace the -git version, which will be removed soon. Ongoing efforts of moving all packages to properly tagged releases.
On my test system here, these two packages appear to be stuck in a strange cycle of replacing each other. If I update over and over, they just keep switching from one to the other with each update.
❯ garuda-update
core is up to date
extra is up to date
chaotic-aur is up to date
:: Replace mhwd-garuda with garuda/mhwd-garuda-git? [Y/n] y
mhwd-garuda 1.1.4-1 -0.27 MiB
garuda/mhwd-garuda-git r25.3a28734-1 0.27 MiB
(1/1) checking keys in keyring [-------------------------------------------------------------------] 100%
(1/1) checking package integrity [-------------------------------------------------------------------] 100%
(1/1) loading package files [-------------------------------------------------------------------] 100%
(1/1) checking for file conflicts [-------------------------------------------------------------------] 100%
(2/2) checking available disk space [-------------------------------------------------------------------] 100%
==> root: 45
(1/1) removing mhwd-garuda [-------------------------------------------------------------------] 100%
/tmp/alpm_3hvP1M/.INSTALL: line 27: mhwd-gpu: command not found
(1/1) installing mhwd-garuda-git [-------------------------------------------------------------------] 100%
(1/8) Arming ConditionNeedsUpdate...
(2/8) Updating linux initcpios...
(3/8) Foreign/AUR package notification
light 1.2.2-3
(4/8) Orphaned package notification...
libical 3.0.17-2
(5/8) Checking for .pacnew and .pacsave files...
(6/8) Keep the last cache and the currently installed.
==> no candidate packages found for pruning
(7/8) Performing snapper post snapshots for the following configurations...
==> root: 46
(8/8) Syncing all file systems...
System updated! 🐧
~ took 10m5s
❯ garuda-update
core is up to date
extra is up to date
chaotic-aur 2.6 MiB 4.09 MiB/s 00:01 [-------------------------------------------------------------------] 100%
==> root: 47
(1/1) removing mhwd-garuda-git [-------------------------------------------------------------------] 100%
/tmp/alpm_ZF935B/.INSTALL: line 27: mhwd-gpu: command not found
(1/1) installing mhwd-garuda [-------------------------------------------------------------------] 100%
light 1.2.2-3
libical 3.0.17-2
==> root: 48
System updated! 🐧
~ took 3s
❯ garuda-update
core is up to date
extra is up to date
==> root: 49
/tmp/alpm_adYvIA/.INSTALL: line 27: mhwd-gpu: command not found
light 1.2.2-3
libical 3.0.17-2
==> root: 50
System updated! 🐧
~ took 3s
❯ garuda-update
core is up to date
extra is up to date
==> root: 51
/tmp/alpm_YVSj3o/.INSTALL: line 27: mhwd-gpu: command not found
light 1.2.2-3
libical 3.0.17-2
==> root: 52
System updated! 🐧
The update took a little longer due to insufficient connectivity.
All is well.
╭─bima@bima in ~
╰─λ upd
[sudo] Passwort für bima:
:: Paketdatenbanken werden synchronisiert …
garuda ist aktuell
core ist aktuell
extra ist aktuell
multilib ist aktuell
chaotic-aur 2,6 MiB 631 KiB/s 00:04 [------------------------------------] 100%
garuda wird heruntergeladen …
core wird heruntergeladen …
extra wird heruntergeladen …
multilib wird heruntergeladen …
chaotic-aur wird heruntergeladen …
there is nothing to do
System updated! 🐧
╭─bima@bima in ~ as 🧙 took 34s
╰─λ
