Read
The day after Garuda System Maintenance was released I did a reboot and noticed two instances in the systray. I left it and did a log off figuring it might just be a one off and would revert to just one after logging back in, but to my surprise I then had three instances. Today I did the same routine a reboot and a logoff and logon and it's still the same. I checked System Monitor and Autostart and under Monitor thre instances list and under Autostart I hadn't added it there. I have no idea where to look to correct this or see what might be causing the issue. Any guidance on addressing the issue would be appreciated.
╭─jigsaw@NSAFieldStation in ~
╰─λ inxi -Fza
System: Kernel: 5.12.15-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=78688345-46c9-46e1-9ff4-63d70dd964a1
Desktop: KDE Plasma 5.22.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM Distro: Garuda Linux
Machine: Type: Desktop System: ASUS product: N/A v: N/A serial: <filter>
Mobo: ASUSTeK model: ROG STRIX B550-F GAMING v: Rev X.0x serial: <filter>
UEFI: American Megatrends v: 2403 date: 06/16/2021
Battery: Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M325 serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: Discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Keyboard K360 serial: <filter>
CPU: Info: 6-Core model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2 family: 17 (23)
model-id: 71 (113) stepping: 0 microcode: 8701021 cache: L2: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 86242
Speed: 3593 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz): 1: 3593 2: 3803
3: 3589 4: 3594 5: 3591 6: 3587 7: 3595 8: 3591 9: 4041 10: 3760 11: 3353 12: 3592
mitigation: Full AMD retpoline, IBPB: conditional, STIBP: conditional, RSB filling
Graphics: Device-1: NVIDIA TU116 [GeForce GTX 1650 SUPER] vendor: eVga.com. driver: nvidia v: 465.31
alternate: nouveau,nvidia_drm bus-ID: 08:00.0 chip-ID: 10de:2187 class-ID: 0300
Display: x11 server: X.Org 1.20.12 compositor: kwin_x11 driver: loaded: nvidia display-ID: :0
Screen-1: 0 s-res: 2560x1080 s-dpi: 97 s-size: 670x283mm (26.4x11.1") s-diag: 727mm (28.6")
Monitor-1: HDMI-0 res: 2560x1080 hz: 60 dpi: 97 size: 673x284mm (26.5x11.2")
diag: 730mm (28.8")
OpenGL: renderer: NVIDIA GeForce GTX 1650 SUPER/PCIe/SSE2 v: 4.6.0 NVIDIA 465.31
direct render: Yes
Audio: Device-1: NVIDIA TU116 High Definition Audio vendor: eVga.com. driver: snd_hda_intel v: kernel
bus-ID: 08:00.1 chip-ID: 10de:1aeb class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 0a:00.4 chip-ID: 1022:1487 class-ID: 0403
Sound Server-1: ALSA v: k5.12.15-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.31 running: yes
Network: Device-1: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel port: N/A bus-ID: 07:00.0
Drives: Local Storage: total: 20.71 TiB used: 9.5 TiB (45.9%)
ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Seagate model: XPG GAMMIX S11 Pro size: 476.94 GiB
block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD
serial: <filter> rev: 32B3T8EB scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Patriot model: Viper M.2 VPN100 size: 238.47 GiB
serial: <filter> rev: ECFM22.6 scheme: GPT
ID-3: /dev/sda maj-min: 8:0 type: USB vendor: Seagate model: ST8000AS0002-1NA17Z size: 7.28 TiB
block-size: physical: 4096 B logical: 512 B rotation: 5980 rpm serial: <filter> scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 type: USB vendor: Seagate model: Expansion HDD size: 7.28 TiB
block-size: physical: 4096 B logical: 512 B serial: <filter> rev: 1801 scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 type: USB vendor: Seagate model: ST330006 51NS size: 2.73 TiB
block-size: physical: 4096 B logical: 512 B serial: <filter> rev: 7101 scheme: GPT
ID-6: /dev/sdd maj-min: 8:48 type: USB vendor: Seagate model: ST3000DM 001-1E6166
size: 2.73 TiB block-size: physical: 4096 B logical: 512 B serial: <filter> rev: 7101
Partition: ID-1: / raw-size: 476.68 GiB size: 476.68 GiB (100.00%) used: 56.33 GiB (11.8%) fs: btrfs
dev: /dev/nvme0n1p2 maj-min: 259:5
ID-2: /boot/efi raw-size: 256 MiB size: 252 MiB (98.46%) used: 546 KiB (0.2%) fs: vfat
dev: /dev/nvme0n1p1 maj-min: 259:4
ID-3: /home raw-size: 476.68 GiB size: 476.68 GiB (100.00%) used: 56.33 GiB (11.8%) fs: btrfs
ID-4: /var/log raw-size: 476.68 GiB size: 476.68 GiB (100.00%) used: 56.33 GiB (11.8%)
fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:5
ID-5: /var/tmp raw-size: 476.68 GiB size: 476.68 GiB (100.00%) used: 56.33 GiB (11.8%)
ID-1: swap-1 type: zram size: 31.33 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 43.9 C mobo: N/A gpu: nvidia temp: 47 C
Info: Processes: 422 Uptime: 11m wakeups: 6 Memory: 31.33 GiB used: 6.95 GiB (22.2%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 1988 pacman: 1955
lib: 553 flatpak: 22 snap: 11 Shell: fish v: 3.3.1 default: Zsh v: 5.8 running-in: konsole
inxi: 3.3.05
╭─jigsaw@NSAFieldStation in ~ took 1s
╰─λ
