Hello
When I use HDMI to connect to a different display and extend the screen, nothing appears on the second screen, the first screen turns black, and all I can see is the mouse cursor.
Nevertheless, I can utilize the second screen with a lot of lag and poor quality if I adjust the second screen's resolution before extending the screen.
The same thing occurs when connecting with a USB-C connector.
Yet, everything functions normally when connected using a different USB-C connection.
Connecting with all ports, function properly on Windows 11.
Although I'm assuming it's a graphic card issue, I have no idea how to identify the issue or fix it.
Kernel: 6.2.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=aa1d7b5b-5483-4661-a1b7-231f1690c27a rw rootflags=subvol=@
loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.8 wm: kwin_x11 dm: SDDM
Type: Laptop System: ASUSTeK product: ROG Zephyrus G15 GA503RW_GA503RW
v: 1.0 serial: <filter>
Mobo: ASUSTeK model: GA503RW v: 1.0 serial: <filter> UEFI: American
Megatrends LLC. v: GA503RW.313 date: 01/17/2023
ID-1: BAT1 charge: 91.8 Wh (100.0%) condition: 91.8/90.2 Wh (101.7%)
volts: 17.3 min: 15.9 model: ASUS A32-K55 type: Li-ion serial: N/A
status: full
Info: model: AMD Ryzen 7 6800HS with Radeon Graphics socket: FP7 bits: 64
type: MT MCP arch: Zen 3+ gen: 4 level: v3 note: check built: 2022
process: TSMC n6 (7nm) family: 0x19 (25) model-id: 0x44 (68) stepping: 1
microcode: 0xA404101
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1700 high: 3200 min/max: 1600/4784 boost: enabled
base/boost: 3200/4750 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.2 V ext-clock: 100 MHz cores: 1: 3200 2: 1600 3: 1600 4: 1600
5: 1600 6: 1600 7: 1600 8: 1600 9: 1600 10: 1600 11: 1600 12: 1600
13: 1600 14: 1600 15: 1600 16: 1600 bogomips: 102208
Device-1: NVIDIA GA104 [Geforce RTX 3070 Ti Laptop GPU] vendor: ASUSTeK
status: current (as of 2023-03) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 1 speed: 2.5 GT/s
lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
off: HDMI-A-1 empty: DP-1,eDP-1 bus-ID: 01:00.0 chip-ID: 10de:24a0
Device-2: AMD Rembrandt [Radeon 680M] vendor: ASUSTeK driver: amdgpu
pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-2 empty: DP-2,
DP-3, DP-4, DP-5, DP-6, DP-7, DP-8, DP-9 bus-ID: 06:00.0
chip-ID: 1002:1681 class-ID: 0300 temp: 58.0 C
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 4-1:2 chip-ID: 13d3:56eb class-ID: fe01 serial: <filter>
gpu: amdgpu,nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x2520 s-dpi: 96 s-size: 677x666mm (26.65x26.22")
s-diag: 950mm (37.39")
Monitor-1: HDMI-A-1 mapped: HDMI-1-0 note: disabled pos: top
model: LG (GoldStar) ULTRAWIDE serial: <filter> built: 2017 res: 2560x1080
hz: 60 dpi: 81 gamma: 1.2 size: 798x334mm (31.42x13.15")
diag: 869mm (34.2") modes: max: 2560x1080 min: 640x480
Monitor-2: eDP-2 mapped: eDP-1 pos: primary,bottom
model: BOE Display 0x0a55 built: 2021 res: 2560x1440 hz: 240 dpi: 189
gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9
modes: max: 2560x1440 min: 640x480
API: OpenGL v: 4.6 Mesa 23.0.2 renderer: AMD Radeon Graphics (rembrandt
LLVM 15.0.7 DRM 3.49 6.2.10-zen1-1-zen) direct-render: Yes
Device-1: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 8
Device-2: AMD Rembrandt Radeon High Definition Audio vendor: ASUSTeK
bus-ID: 06:00.1 chip-ID: 1002:1640 class-ID: 0403
snd_sof_amd_renoir, snd_sof_amd_rembrandt pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 06:00.5 chip-ID: 1022:15e2 class-ID: 0480
bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.2.10-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.68 status: n/a (root, process) with:
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 02:00.0
Device-2: MEDIATEK vendor: AzureWave driver: mt7921e v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 03:00.0 chip-ID: 14c3:7922
Device-1: IMC Networks Wireless_Device type: USB driver: btusb v: 0.8
bus-ID: 2-3:2 chip-ID: 13d3:3568 class-ID: e001 serial: <filter>
Local Storage: total: 953.87 GiB used: 10.95 GiB (1.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WD PC
SN735 SDBPNHH-1T00-1002 size: 953.87 GiB block-size: physical: 512 B
rev: 70626000 temp: 45.9 C scheme: GPT
SMART: yes health: PASSED on: 8 hrs cycles: 89
read-units: 347,063 [177 GB] written-units: 468,536 [239 GB]
ID-1: / raw-size: 88 GiB size: 88 GiB (100.00%) used: 10.8 GiB (12.3%)
fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p8 maj-min: 259:8
used: 608 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p6
maj-min: 259:6
ID-3: /home raw-size: 265.37 GiB size: 265.37 GiB (100.00%)
used: 144.1 MiB (0.1%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p7
maj-min: 259:7
ID-4: /var/log raw-size: 88 GiB size: 88 GiB (100.00%)
used: 10.8 GiB (12.3%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p8
maj-min: 259:8
ID-5: /var/tmp raw-size: 88 GiB size: 88 GiB (100.00%)
maj-min: 259:8
ID-1: swap-1 type: zram size: 14.87 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 60.6 C mobo: N/A gpu: amdgpu temp: 61.0 C
Fan Speeds (RPM): cpu: 2600
Processes: 372 Uptime: 49m wakeups: 6 Memory: 14.87 GiB
used: 3.93 GiB (26.4%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1200
libs: 318 tools: octopi,paru Shell: garuda-inxi (sudo) default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.26
System install date: 2023-04-11
Last full system update: 2023-04-11
Windows dual boot: Yes
Can any one help me through this issue?
