I notice that after 45 mins which is what I have it set to, it will attempt to go to sleep but then wake up immediately afterwards. So something is causing the wake up. Its a MSI Optix 342CQRV 34" UW. Using a HDMI cable which is what this monitor "prefers" as the DisplayPort cable doesn't even work with my build.
Ironically with my similar issue of the keyboard and mouse not being able to wake up the PC (and then once the power button is pushed those two still are asleep), when I'm on the sddm splash screen there is some timeout where then my monitor WILL actually go to sleep! Yeah it only works on the lockout screen which reminds me maybe that's what I need to do to get it to shut off if all else fails but I rather not.
What I've tried:
xset +dpms
xset dpms 30 45 60
What happens with that is the screen will go off but then on again, followed by another 15-40 seconds before it does that again. Then there is a pattern of the screen going off and on repeatedly 3 times where you get less than a second between black screens. Another 1 min and the cycle repeats itself. From:
https://bbs.archlinux.org/viewtopic.php?id=230068
```text
System: Kernel: 5.14.16-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=b3313c80-ab52-480d-9e9a-0f5523dc311a rw [email protected] quiet splash
resume=UUID=edae4f59-58e7-43b3-ae50-453efb741e26 loglevel=3
Desktop: KDE Plasma 5.23.3 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Desktop Mobo: Micro-Star model: B550-A PRO (MS-7C56) v: 1.0 serial: <filter>
UEFI: American Megatrends LLC. v: A.50 date: 01/15/2021
CPU: Info: 8-Core model: AMD Ryzen 7 5700G with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 family: 19 (25) model-id: 50 (80) stepping: 0 microcode: A50000B cache:
L2: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 121375
Speed: 4232 MHz min/max: 1400/3800 MHz boost: enabled Core speeds (MHz): 1: 4232
2: 4467 3: 4424 4: 4226 5: 4547 6: 4119 7: 3852 8: 4306 9: 4415 10: 4408 11: 4490
12: 4143 13: 4203 14: 4297 15: 3863 16: 3947
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW, STIBP:
always-on, RSB filling
Graphics: Device-1: AMD Cezanne driver: amdgpu v: kernel bus-ID: 30:00.0 chip-ID: 1002:1638
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver: loaded: amdgpu,ati
Screen-1: 0 s-res: 3440x1440 s-dpi: 96 s-size: 910x381mm (35.8x15.0")
s-diag: 987mm (38.8")
Monitor-1: HDMI-A-0 res: 3440x1440 dpi: 110 size: 797x333mm (31.4x13.1")
diag: 864mm (34")
OpenGL: renderer: AMD RENOIR (DRM 3.42.0 5.14.16-zen1-1-zen LLVM 12.0.1)
v: 4.6 Mesa 21.2.4 direct render: Yes
Audio: Device-1: AMD driver: snd_hda_intel v: kernel bus-ID: 30:00.1 chip-ID: 1002:1637
Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel bus-ID: 30:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.14.16-zen1-1-zen running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI
driver: r8169 v: kernel port: f000 bus-ID: 2a:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp42s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Drives: Local Storage: total: 950.15 GiB used: 182.08 GiB (19.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Corsair model: Corsair MP600 CORE
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s lanes: 4
type: SSD serial: <filter> rev: EGFM52.3 temp: 31.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Lexar model: USB Flash Drive
size: 14.91 GiB block-size: physical: 512 B logical: 512 B type: SSD serial: <filter>
rev: 1100 scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: SanDisk model: Cruzer Glide
size: 3.73 GiB block-size: physical: 512 B logical: 512 B type: N/A serial: <filter>
rev: 2.01 scheme: MBR
Partition: ID-1: / raw-size: 78.12 GiB size: 78.12 GiB (100.00%) used: 21.18 GiB (27.1%) fs: btrfs
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 576 KiB (0.2%)
fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 818.91 GiB size: 818.91 GiB (100.00%) used: 160.9 GiB (19.6%)
fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
ID-4: /var/log raw-size: 78.12 GiB size: 78.12 GiB (100.00%) used: 21.18 GiB (27.1%)
ID-5: /var/tmp raw-size: 78.12 GiB size: 78.12 GiB (100.00%) used: 21.18 GiB (27.1%)
ID-1: swap-1 type: partition size: 34.18 GiB used: 0 KiB (0.0%) priority: -2
ID-2: swap-2 type: zram size: 29.29 GiB used: 2.2 MiB (0.0%) priority: 100
Sensors: System Temperatures: cpu: 33.5 C mobo: N/A gpu: amdgpu temp: 25.0 C
Info: Processes: 472 Uptime: 1d 11h 48m wakeups: 1 Memory: 29.29 GiB used: 12.25 GiB (41.8%)
Init: systemd v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages:
pacman: 1861 lib: 525 Client: Unknown Client: garuda-assistant inxi: 3.3.08
