Back when I installed Garuda on August 2021, I followed this video tutorial. I ended up with a separate btrfs partition for /home.
I would like to get rid of the mentioned partition and move /home to a @home subvolume, the way is default in a straight forward Garuda installation, without having to reinstall the whole system. I want to do this because of the way subvolumes manage space dinamically.
Any lead on where to look or the kind of operation needed will be appreciated.
I append the output of cat /etc/fstab, btrfs subvolume list / and garuda-inxi.
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=5065-8560 /boot/efi vfat umask=0077 0 2
UUID=65b1555e-e8e7-41cb-84a2-63265cdbd7db swap swap defaults,noatime 0 0
UUID=543c6354-5d39-4703-bb64-407600dc772d / btrfs subvol=/@,defaults,noatime,noautodefrag,compress=zstd 0 0
UUID=543c6354-5d39-4703-bb64-407600dc772d /root btrfs subvol=/@root,defaults,noatime,noautodefrag,compress=zstd 0 0
UUID=543c6354-5d39-4703-bb64-407600dc772d /srv btrfs subvol=/@srv,defaults,noatime,noautodefrag,compress=zstd 0 0
UUID=543c6354-5d39-4703-bb64-407600dc772d /var/cache btrfs subvol=/@cache,defaults,noatime,noautodefrag,compress=zstd 0 0
UUID=543c6354-5d39-4703-bb64-407600dc772d /var/log btrfs subvol=/@log,defaults,noatime,noautodefrag,compress=zstd 0 0
UUID=543c6354-5d39-4703-bb64-407600dc772d /var/tmp btrfs subvol=/@tmp,defaults,noatime,noautodefrag,compress=zstd 0 0
UUID=2e159e97-2728-4e48-9ef8-9fe16862426c /home btrfs defaults,noatime,noautodefrag,compress=zstd 0 0
ID 257 gen 287690 top level 5 path @root
ID 258 gen 238310 top level 5 path @srv
ID 259 gen 288102 top level 5 path @cache
ID 260 gen 288302 top level 5 path @log
ID 261 gen 288300 top level 5 path @tmp
ID 935 gen 288300 top level 5 path @
ID 1698 gen 288114 top level 935 path .snapshots
ID 1730 gen 287668 top level 1698 path .snapshots/21/snapshot
ID 1731 gen 287670 top level 1698 path .snapshots/22/snapshot
ID 1732 gen 287745 top level 1698 path .snapshots/23/snapshot
ID 1733 gen 287746 top level 1698 path .snapshots/24/snapshot
ID 1734 gen 287751 top level 1698 path .snapshots/25/snapshot
ID 1735 gen 287752 top level 1698 path .snapshots/26/snapshot
ID 1736 gen 287960 top level 1698 path .snapshots/27/snapshot
ID 1737 gen 287962 top level 1698 path .snapshots/28/snapshot
ID 1738 gen 288086 top level 1698 path .snapshots/29/snapshot
ID 1739 gen 288088 top level 1698 path .snapshots/30/snapshot
Kernel: 6.1.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=543c6354-5d39-4703-bb64-407600dc772d rw rootflags=subvol=@
resume=UUID=65b1555e-e8e7-41cb-84a2-63265cdbd7db loglevel=3
Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Mobo: ASUSTeK model: TUF GAMING B550M-PLUS (WI-FI) v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 2423
date: 08/10/2021
Device-1: hidpp_battery_0 model: Logitech MX Keys Wireless Keyboard
serial: <filter> charge: 10% (should be ignored) rechargeable: yes
Device-2: hidpp_battery_1 model: Logitech Wireless Mouse M325
Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3 gen: 4
level: v3 note: check built: 2021-22 process: TSMC n7 (7nm)
family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3654 high: 3700 min/max: 2200/4650 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3700 2: 3700
3: 3632 4: 3627 5: 3590 6: 3700 7: 3614 8: 3600 9: 3596 10: 3700 11: 3700
12: 3700 bogomips: 88801
Device-1: NVIDIA GP108 [GeForce GT 1030] vendor: ASUSTeK driver: nvidia
v: 525.85.05 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2022-12) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 4
bus-ID: 07:00.0 chip-ID: 10de:1d01 class-ID: 0300
Device-2: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 3-2:3 chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
compositor: kwin_x11 driver: N/A display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 81 s-size: 602x343mm (23.70x13.50")
s-diag: 693mm (27.28")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 82
API: OpenGL v: 4.6.0 NVIDIA 525.85.05 renderer: NVIDIA GeForce GT
1030/PCIe/SSE2 direct render: Yes
Device-1: NVIDIA GP108 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel bus-ID: 1-9:7 v: kernel chip-ID: 0499:1509 pcie:
gen: 3 class-ID: ff00 speed: 8 GT/s lanes: 4 bus-ID: 07:00.1
chip-ID: 10de:0fb8 class-ID: 0403
bus-ID: 09:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Yamaha Steinberg UR22 type: USB driver: snd-usb-audio
Device-4: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
Sound API: ALSA v: k6.1.9-zen1-1-zen running: yes
speed: 5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 8086:2723 class-ID: 0280
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 06:00.0
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-5:2
chip-ID: 8087:0029 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 1 state: down
address: N/A
Local Storage: total: 1.14 TiB used: 837.48 GiB (71.9%)
model: WDS250G3X0C-00SJG0 size: 232.89 GiB block-size: physical: 512 B
rev: 111110WD temp: 40.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Seagate
model: ST1000LM035-1RK172 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B type: HDD rpm: 5400 serial: <filter> rev: 1053 scheme: MBR
ID-1: / raw-size: 100 GiB size: 100 GiB (100.00%) used: 38.22 GiB (38.2%)
used: 592 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 128.59 GiB size: 128.59 GiB (100.00%)
used: 43.56 GiB (33.9%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
ID-4: /var/log raw-size: 100 GiB size: 100 GiB (100.00%)
used: 38.22 GiB (38.2%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
ID-5: /var/tmp raw-size: 100 GiB size: 100 GiB (100.00%)
ID-2: swap-2 type: partition size: 4 GiB used: 0 KiB (0.0%) priority: -2
System Temperatures: cpu: 38.5 C mobo: 37.0 C gpu: nvidia temp: 42 C
Fan Speeds (RPM): fan-1: 1047 fan-2: 1390 fan-3: 1088 fan-7: 0
Processes: 334 Uptime: 2h 48m wakeups: 23 Memory: 15.53 GiB
used: 4.45 GiB (28.6%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: 1877
pm: nix-default pkgs: 0 pm: nix-sys pkgs: 0 pm: nix-usr pkgs: 2 pm: pacman
pkgs: 1875 libs: 442 tools: aura,paru Shell: fish v: 3.6.0 default: Bash
v: 5.1.16 running-in: yakuake inxi: 3.3.24
Garuda (2.6.14-1):
System install date: 2022-10-23
Last full system update: 2023-02-05
