Kernel: 6.8.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=7bbfb67a-37a6-4540-bbaf-fab8447d446c rw rootflags=subvol=@
Desktop: MATE v: 1.26.2 wm: marco v: 1.26.2 with: mate-panel
tools: mate-screensaver avail: cinnamon-screensaver, xautolock, xscreensaver
vt: 7 dm: LightDM v: 1.32.0 Distro: Garuda base: Arch Linux
Type: Laptop System: Acer product: Nitro AN515-42 v: V1.13
Mobo: RR model: Freed_RRS v: V1.13 serial: <superuser required>
part-nu: 0000000000000000 uuid: <superuser required> UEFI: Insyde v: 1.13
date: 02/11/2019
ID-1: BAT1 charge: 35.4 Wh (100.0%) condition: 35.4/48.9 Wh (72.4%)
volts: 16.3 min: 15.2 model: LG 0x41,0x43,0x31,0x34,0x42,0x38,0x4B
type: Li-ion serial: <filter> status: full
Info: model: AMD Ryzen 5 2500U with Radeon Vega Mobile Gfx bits: 64
type: MT MCP arch: Zen level: v3 note: check built: 2017-19 process: GF 14nm
family: 0x17 (23) model-id: 0x11 (17) stepping: 0 microcode: 0x810100B
L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 1576 high: 1600 min/max: 1600/2000 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1600 2: 1500
3: 1600 4: 1518 5: 1600 6: 1600 7: 1597 8: 1600 bogomips: 31938
Device-1: AMD Baffin [Radeon RX 460/560D / Pro
450/455/460/555/555X/560/560X] vendor: Acer Incorporated ALI
built: 2016-20 pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 3
speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 1002:67ef class-ID: 0380
temp: 39.0 C
Device-2: AMD Raven Ridge [Radeon Vega Series / Radeon Mobile Series]
vendor: Acer Incorporated ALI driver: amdgpu v: kernel arch: GCN-5
lanes: 16 ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 04:00.0
chip-ID: 1002:15dd class-ID: 0300 temp: 47.0 C
Device-3: Quanta HD Webcam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 0408:a060
compositor: marco v: 1.26.2 driver: X: loaded: amdgpu unloaded: modesetting
Monitor-1: eDP-1 mapped: eDP model: LG Display 0x05d8 built: 2018
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
device: 1 drv: radeonsi device: 2 drv: swrast surfaceless: drv: radeonsi
x11: drv: radeonsi inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.3-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Vega 8 Graphics
(radeonsi raven LLVM 17.0.6 DRM 3.57 6.8.1-zen1-1-zen)
device-ID: 1002:15dd memory: 1000 MiB unified: no
API: Vulkan v: 1.3.279 layers: 7 device: 0 type: integrated-gpu name: AMD
Radeon Vega 8 Graphics (RADV RAVEN) driver: mesa radv v: 24.0.3-arch1.1
device-ID: 1002:15dd surfaces: xcb,xlib device: 1 type: discrete-gpu
name: AMD Radeon RX Graphics (RADV POLARIS11) driver: mesa radv
v: 24.0.3-arch1.1 device-ID: 1002:67ef surfaces: xcb,xlib device: 2
type: cpu name: llvmpipe (LLVM 17.0.6 256 bits) driver: mesa llvmpipe
v: 24.0.3-arch1.1 (LLVM 17.0.6) device-ID: 10005:0000 surfaces: xcb,xlib
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 04:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: AMD Family 17h/19h HD Audio vendor: Acer Incorporated ALI
API: ALSA v: k6.8.1-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.4 status: active with: 1: pipewire-pulse
vendor: Acer Incorporated ALI RTL8111/8168/8411 driver: r8169 v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 02:00.1
IF: enp2s0f1 state: down mac: <filter>
vendor: Lite-On driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 03:00.0 chip-ID: 168c:003e class-ID: 0280 temp: 45.0 C
Device-1: Lite-On driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-4:2 chip-ID: 04ca:3016 class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 3 state: up address: <filter> bt-v: 4.2
Local Storage: total: 1.02 TiB used: 756.31 GiB (72.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000MX500SSD1
tech: SSD serial: <filter> fw-rev: 023 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: SA400M8120G
tech: SSD serial: <filter> fw-rev: 61E1 scheme: MBR
ID-1: / raw-size: 96 GiB size: 96 GiB (100.00%) used: 33.88 GiB (35.3%)
fs: btrfs dev: /dev/sdb1 maj-min: 8:17
ID-2: /boot/efi raw-size: 100 MiB size: 98.4 MiB (98.45%)
used: 867 KiB (0.9%) fs: vfat dev: /dev/sdb2 maj-min: 8:18
ID-3: /home raw-size: 931.51 GiB size: 915.82 GiB (98.32%)
used: 722.43 GiB (78.9%) fs: ext4 dev: /dev/sda3 maj-min: 8:3
ID-4: /var/log raw-size: 96 GiB size: 96 GiB (100.00%)
used: 33.88 GiB (35.3%) fs: btrfs dev: /dev/sdb1 maj-min: 8:17
ID-5: /var/tmp raw-size: 96 GiB size: 96 GiB (100.00%)
ID-1: swap-1 type: zram size: 30.26 GiB used: 137.5 MiB (0.4%)
System Temperatures: cpu: 45.6 C mobo: N/A
GPU: device: amdgpu temp: 39.0 C watts: 6.07 device: amdgpu temp: 45.0 C
Memory: total: 32 GiB note: est. available: 30.26 GiB used: 7.44 GiB (24.6%)
Processes: 300 Power: uptime: 2d 1h 33m states: freeze,mem,disk
reboot, suspend, test_resume image: 12.09 GiB
services: mate-power-manager,upowerd Init: systemd v: 255
Packages: 1992 pm: pacman pkgs: 1979 libs: 548 tools: octopi,paru,yay
pm: flatpak pkgs: 13 Compilers: gcc: 13.2.1 Shell: garuda-inxi default: Bash
v: 5.2.26 running-in: mate-terminal inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2023-08-28
Last full system update: 2024-03-20 ↻
This doesn’t happen on my desktop, which uses MATE, only my laptop. It’s annoying when I want to scroll and have to use the scroll bars, and I use my laptop to do a radio show, so sound is important.
