All of a sudden my bluetooth mouse seems to stop working a lot of times when my screen goes blank, I do not have auto suspend on. I am not sure if this is gnome specific but its annoying to have to reboot so often. I notice the bluelight starts blinking alot, and after the reboot when it seems to work again it goes solid for a second then light goes away.
Kernel: 6.0.0-1-mainline arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-mainline
root=UUID=ee5f72e7-75c7-4861-a5c6-9ae5039aa855 rw rootflags=subvol=@
i915.force_probe=4680
Desktop: GNOME v: 42.5 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 42.0
Type: Desktop System: Micro-Star product: MS-7D25 v: 1.0
Mobo: Micro-Star model: PRO Z690-A WIFI DDR4(MS-7D25) v: 1.0
serial: <superuser required> UEFI: American Megatrends LLC. v: 1.10
date: 12/13/2021
Device-1: hidpp_battery_0 model: Logitech MK700 serial: <filter> charge: 70%
(should be ignored) rechargeable: yes status: discharging
Device-2: hidpp_battery_1 model: Logitech G604 Wireless Gaming Mouse
Info: model: 12th Gen Intel Core i7-12700K bits: 64 type: MST AMCP
microcode: 0x22
Topology: cpus: 1x cores: 12 mt: 8 tpc: 2 st: 4 threads: 20 smt: enabled
cache: L1: 1024 KiB desc: d-4x32 KiB, 8x48 KiB; i-8x32 KiB, 4x64 KiB
L2: 12 MiB desc: 8x1.2 MiB, 1x2 MiB L3: 25 MiB desc: 1x25 MiB
Speed (MHz): avg: 3459 high: 4531 min/max: 800/6300:6400:3800 scaling:
driver: intel_pstate governor: powersave cores: 1: 813 2: 3600 3: 3600
4: 3600 5: 3600 6: 3600 7: 2972 8: 3600 9: 3600 10: 3600 11: 3283
12: 3600 13: 3600 14: 3600 15: 4531 16: 3600 17: 3600 18: 3600 19: 3600
20: 3600 bogomips: 144440
Device-1: Intel AlderLake-S GT1 vendor: Micro-Star MSI driver: i915
v: kernel ports: active: DP-1,HDMI-A-1 empty: DP-2, HDMI-A-2, HDMI-A-3,
HDMI-A-4 bus-ID: 00:02.0 chip-ID: 8086:4680 class-ID: 0300
Display: wayland server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.3
compositor: gnome-shell driver: X: loaded: intel unloaded: modesetting
alternate: fbdev,vesa dri: i965 gpu: i915 display-ID: 0
Monitor-1: DP-1 model: LG (GoldStar) Ultra HD serial: <filter>
built: 2016 res: 3840x2160 dpi: 163 gamma: 1.2
size: 600x340mm (23.62x13.39") diag: 690mm (27.2") ratio: 16:9 modes:
max: 3840x2160 min: 640x480
Monitor-2: HDMI-A-1 model: LG (GoldStar) HDR 4K serial: <filter>
built: 2019 res: 3840x2160 dpi: 163 gamma: 1.2
OpenGL: renderer: Mesa Intel Graphics (ADL-S GT1) v: 4.6 Mesa 22.1.7
direct render: Yes
Device-1: Intel Alder Lake-S HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 1-11:6 chip-ID: 0c76:161e
alternate: snd_sof_pci_intel_tgl class-ID: 0300 bus-ID: 00:1f.3
Device-2: JMTek LLC. USB PnP Audio Device type: USB
Device-3: Logitech G560 Gaming Speaker type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-5.3:9 chip-ID: 046d:0a78
Sound API: ALSA v: k6.0.0-1-mainline running: yes
Device-2: Intel Ethernet I225-V vendor: Micro-Star MSI driver: igc
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 03:00.0
bus-ID: 1-14:10 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 3.18 TiB used: 419.94 GiB (12.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 model: PCIe SSD size: 931.51 GiB
block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s lanes: 4
type: SSD serial: <filter> rev: EGFM13.2 temp: 34.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB
ID-3: /dev/sdb maj-min: 8:16 vendor: Toshiba model: HDWD120
type: HDD rpm: 7200 serial: <filter> rev: ACF0 scheme: GPT
ID-1: / raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 398.86 GiB
(42.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 576 KiB
ID-3: /home raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 398.86
GiB (42.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 398.86
ID-5: /var/tmp raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 398.86
ID-1: swap-1 type: zram size: 31.15 GiB used: 2.2 MiB (0.0%)
System Temperatures: cpu: 25.0 C mobo: N/A
Processes: 450 Uptime: 28m wakeups: 6 Memory: 31.15 GiB used: 5.18 GiB
(16.6%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 2211
libs: 496 tools: octopi,pamac,paru pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
running-in: gnome-terminal inxi: 3.3.22
Garuda (2.6.8-1):
System install date: 2022-01-18
Last full system update: 2022-10-13
Failed units: mnt-samba.mount
