Hey, after a update my mouse stops working after about 3 seconds of inactivity and only comes back to life if i press a button, is there something i could do to prevent such an waste of time? Also already looked into energy settings etc. but i found nothing that could be the problem in there
inxi:
  Kernel: 5.19.15-hardened2-1-hardened arch: x86_64 bits: 64 compiler: gcc
    v: 12.2.0 parameters: pti=on page_alloc.shuffle=1
    BOOT_IMAGE=/@/boot/vmlinuz-linux-hardened
    root=UUID=d16ddc96-5d12-402f-bbcb-9fa585484f0b rw rootflags=subvol=@
    cryptdevice=UUID=3c647ba3-56c7-43a5-bafc-5f6213b05312:luks-3c647ba3-56c7-43a5-bafc-5f6213b05312
    root=/dev/mapper/luks-3c647ba3-56c7-43a5-bafc-5f6213b05312
  Desktop: KDE Plasma v: 5.26.0 tk: Qt v: 5.15.6 info: latte-dock
  Type: Laptop System: LENOVO product: 82C7 v: Lenovo V15-ADA
    serial: <superuser required> Chassis: type: 10 v: Lenovo V15-ADA
  Mobo: LENOVO model: LNVNB161216 v: No DPK serial: <superuser required>
    UEFI: LENOVO v: E8CN30WW date: 07/28/2021
  ID-1: BAT0 charge: 34.5 Wh (99.4%) condition: 34.7/35.3 Wh (98.2%)
    volts: 8.6 min: 7.6 model: CPT-COS L16C2PB1 type: Li-poly serial: <filter>
    status: not charging cycles: 68
  Info: model: AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx bits: 64
    L3: 4 MiB desc: 1x4 MiB
  Speed (MHz): avg: 2361 high: 2762 min/max: 1400/2100 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2743 2: 2761
    3: 2762 4: 2754 5: 1400 6: 1231 7: 2477 8: 2761 bogomips: 33550
    vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5 code: Vega
    ports: active: HDMI-A-1,eDP-1 empty: none bus-ID: 03:00.0
    chip-ID: 1002:15d8 class-ID: 0300 temp: 40.0 C
  Device-2: WCM_USB WEB CAM type: USB driver: snd-usb-audio,uvcvideo
    bus-ID: 1-3.3:11 chip-ID: 1c3f:2002 class-ID: 0102
  Device-3: IMC Networks Integrated Camera type: USB driver: uvcvideo
    bus-ID: 3-1:2 chip-ID: 13d3:5a08 class-ID: 0e02 serial: <filter>
    s-diag: 1055mm (41.54")
  Monitor-1: HDMI-A-1 mapped: HDMI-A-0 pos: primary,left
    model: Samsung C24F390 serial: <filter> built: 2019 res: 1920x1080 hz: 60
    dpi: 94 gamma: 1.2 size: 521x293mm (20.51x11.54") diag: 598mm (23.5")
  Monitor-2: eDP-1 mapped: eDP pos: right model: BOE Display 0x0812
    built: 2018 res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2
    max: 1920x1080 min: 640x480
  OpenGL: renderer: AMD Radeon Vega 8 Graphics (raven LLVM 14.0.6 DRM 3.47
    5.19.15-hardened2-1-hardened) v: 4.6 Mesa 22.2.1 direct render: Yes
  Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Lenovo
    driver: snd_hda_intel v: kernel bus-ID: 1-3.3:11 pcie: chip-ID: 1c3f:2002
    gen: 3 class-ID: 0102 speed: 8 GT/s lanes: 16 bus-ID: 03:00.1
    driver: snd_pci_acp3x v: kernel
    alternate: snd_rn_pci_acp3x,snd_pci_acp5x,snd_pci_acp6x,snd_acp_pci,snd_sof_amd_renoir
    pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 03:00.5 chip-ID: 1022:15e2
    class-ID: 0480
  Device-4: WCM_USB WEB CAM type: USB driver: snd-usb-audio,uvcvideo
  Device-5: JMTek LLC. USB PnP Audio Device type: USB
    driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-3.4.2:8
    chip-ID: 0c76:161e class-ID: 0300
  Sound API: ALSA v: k5.19.15-hardened2-1-hardened running: yes
  Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
    vendor: Lenovo driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 bus-ID: 02:00.0 chip-ID: 168c:003e class-ID: 0280
  Device-2: ASIX AX88179 Gigabit Ethernet type: USB driver: ax88179_178a
    bus-ID: 2-3.4.3:5 chip-ID: 0b95:1790 class-ID: ff00 serial: <filter>
  IF: enp3s0f3u3u4u3 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-1: Qualcomm Atheros QCA61x4 Bluetooth 4.0 type: USB driver: btusb
    v: 0.8 bus-ID: 3-2:3 chip-ID: 0cf3:e300 class-ID: e001
    address: <filter>
  Local Storage: total: 1.38 TiB used: 280.25 GiB (19.9%)
    model: MZALQ512HALU-000L2 size: 476.94 GiB block-size: physical: 512 B
    rev: BL2QFXV7 temp: 24.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000BX500SSD1
    type: SSD serial: <filter> rev: 054
  ID-1: / raw-size: 467.84 GiB size: 467.84 GiB (100.00%) used: 280.25 GiB
    (59.9%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-3c647ba3-56c7-43a5-bafc-5f6213b05312
  ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 736 KiB
  ID-3: /home raw-size: 467.84 GiB size: 467.84 GiB (100.00%) used: 280.25
    GiB (59.9%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
  ID-4: /var/log raw-size: 467.84 GiB size: 467.84 GiB (100.00%) used: 280.25
  ID-5: /var/tmp raw-size: 467.84 GiB size: 467.84 GiB (100.00%) used: 280.25
  ID-1: swap-1 type: zram size: 17.45 GiB used: 0 KiB (0.0%) priority: 100
    mapped: luks-48d04c79-6793-4578-a7bd-b7f3baa922dc
  System Temperatures: cpu: 40.5 C mobo: N/A gpu: amdgpu temp: 40.0 C
  Processes: 295 Uptime: 1h 11m wakeups: 71 Memory: 17.45 GiB used: 4.86 GiB
  (27.9%) Init: systemd v: 251 default: graphical tool: systemctl
  Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 1477
  libs: 375 tools: octopi,paru Shell: Bash v: 5.1.16 running-in: konsole
  inxi: 3.3.22
e[1;34mGaruda (2.6.8-1):e[0m
e[1;34m  System install date:e[0m     2022-06-18
e[1;34m  Last full system update:e[0m 2022-10-14 e[1;31m↻
e[1;34m  Is partially upgraded:  e[0m No
e[1;34m  Relevant software:      e[0m NetworkManager
e[1;34m  Windows dual boot:      e[0m Probably (Run as root to verify)
e[1;34m  Snapshots:              e[0m Snapper
e[1;34m  Failed units:           e[0m
