Hi, I’m a relative noob to Linux, though I’ve messed with it a few times over the last few decades, it’s only now that I am actually trying to make it my primary operating system. So I have some experience, but not a lot. At first I tried Mint but when I couldn’t get SteamPlay working right on it, I looked into an alternative, and settled upon Garuda Dr460nized Gaming. That works pretty well; the only thing I haven’t yet gotten sorted out is Battle.net games, but that’s a separate topic for another day if I can’t figure that one out.
Anyway, the issue that brings me here today is the behavior of my mouse cursor after the PC resumes from sleep mode. It is garbled and corrupted. It still works, it changes the pointer based on context in the little square that it needs, but it has a huge (256x256, I’d guess) “flag” of partially-transparent (mostly not) white/red garbage trailing to the right and bottom. It gets in the way of tooltips (and everything else) being visible and is highly annoying. I think logging out and back in might fix it though I’m not sure and I’m not going to try that at this moment while I’m trying to post. Certainly a reboot fixes everything, but that’s not a solution.
I’m amendable to disabling or limiting sleep modes for the GPU in order to fix this issue; I just don’t know how. I’ve looked through the settings and didn’t see anything that looked like it would help.
Something that the garuda-inxi did not mention that I think I should, is the fact that my GTX 1050 is a bit of an odd duck; it has 4GB of VRAM (like a 1050Ti) instead of the usual 2GB. I don’t know if that could cause an issue with memory being cleared or whatever.
Kernel: 6.8.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=823c0f2f-a027-4365-bde5-08ba70813ea9 rw rootflags=subvol=@
wm: kwin_x11 with: krunner vt: 2 dm: SDDM Distro: Garuda base: Arch Linux
Type: Desktop System: Dell product: OptiPlex 3020 v: 00
serial: <superuser required> Chassis: type: 15 serial: <superuser required>
Mobo: Dell model: 0WMJ54 v: A01 serial: <superuser required> part-nu: 0612
uuid: <superuser required> UEFI: Dell v: A20 date: 05/27/2019
Info: model: Intel Core i5-4590 bits: 64 type: MCP arch: Haswell gen: core 4
level: v3 note: check built: 2013-15 process: Intel 22nm family: 6
model-id: 0x3C (60) stepping: 3 microcode: 0x28
desc: 1x6 MiB
Speed (MHz): avg: 3293 min/max: 800/3700 scaling: driver: intel_cpufreq
governor: performance cores: 1: 3293 2: 3293 3: 3293 4: 3293 bogomips: 26340
Device-1: NVIDIA GP107 [GeForce GTX 1050] driver: nvidia v: 550.76
2024-04; EOL~2026-12-xx) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-2021 pcie: gen: 2 speed: 5 GT/s lanes: 16 ports: active: none
off: HDMI-A-1 empty: DP-1,DVI-D-1 bus-ID: 01:00.0 chip-ID: 10de:1c81
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 23.2.6
Screen-1: 0 s-res: 1920x1080 s-dpi: 90 s-size: 542x301mm (21.34x11.85")
s-diag: 620mm (24.41")
Monitor-1: HDMI-A-1 mapped: HDMI-0 note: disabled model: Acer XF251Q
serial: <filter> built: 2019 res: 1920x1080 hz: 60 dpi: 90 gamma: 1.2
size: 544x303mm (21.42x11.93") diag: 623mm (24.5") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.76
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1050/PCIe/SSE2
memory: 3.91 GiB
API: Vulkan v: 1.3.279 layers: 11 device: 0 type: discrete-gpu
name: NVIDIA GeForce GTX 1050 driver: nvidia v: 550.76 device-ID: 10de:1c81
surfaces: xcb,xlib
Device-1: Intel 8 Series/C220 Series High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
Device-2: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:0fb9 class-ID: 0403
API: ALSA v: k6.8.7-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.5 status: active with: 1: pipewire-pulse
vendor: Dell driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: c000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Edimax EW-7822ULC 802.11ac Wireless Adapter [Realtek RTL8812AU]
driver: rtw_8822bu type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0
bus-ID: 3-5:2 chip-ID: 7392:b822 class-ID: 0000 serial: <filter>
IF: wlp0s20u5 state: up mac: <filter>
Local Storage: total: 4.79 TiB used: 4.32 TiB (90.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: KLEVV model: NEO N610 SSD 1TB
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 7D scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST4000DM005-2DP166
size: 3.64 TiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 5980 serial: <filter> fw-rev: 0001 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: TeamGroup model: T-FORCE 240GB
size: 223.57 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.1 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: SSD serial: <filter>
ID-1: / raw-size: 30 GiB size: 30 GiB (100.00%) used: 19.83 GiB (66.1%)
fs: btrfs dev: /dev/sdc4 maj-min: 8:36
ID-2: /boot/efi raw-size: 513 MiB size: 512 MiB (99.80%)
used: 584 KiB (0.1%) fs: vfat dev: /dev/sdc2 maj-min: 8:34
ID-3: /home raw-size: 193.07 GiB size: 189.85 GiB (98.34%)
used: 143.79 GiB (75.7%) fs: ext4 dev: /dev/sdc3 maj-min: 8:35
ID-4: /var/log raw-size: 30 GiB size: 30 GiB (100.00%)
used: 19.83 GiB (66.1%) fs: btrfs dev: /dev/sdc4 maj-min: 8:36
ID-5: /var/tmp raw-size: 30 GiB size: 30 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.57 GiB used: 1.18 GiB (7.6%)
System Temperatures: cpu: 51.0 C mobo: N/A gpu: nvidia temp: 45 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 20%
Memory: total: 16 GiB available: 15.57 GiB used: 6.48 GiB (41.6%)
Processes: 313 Power: uptime: 21h 59m states: freeze,mem,disk
suspend: deep avail: s2idle wakeups: 1 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 6.19 GiB services: org_kde_powerdevil,
Packages: 2092 pm: pacman pkgs: 2081 libs: 563 tools: octopi,paru
pm: flatpak pkgs: 11 Compilers: clang: 17.0.6 gcc: 13.2.1 Shell: garuda-inxi
default: fish v: 3.7.1 running-in: konsole inxi: 3.3.34
System install date: 2024-04-22
Last full system update: 2024-04-25
