Mouse doesnt Works more OpenTabletDriver
Hello, I have a problem with this driver that I installed OpenTabletDriver, I downloaded it from the official repository, the thing is that I have a Vinsa 1060 PLUS graphic tablet, the driver practically detects it and everything is correct but when I connect the graphic tablet the mouse stops to work, it is practically impossible to click, I already deactivated the KDE tablet with tactic screen that was how I detected it before, but it is impossible only the keyboard works, in fact it was difficult to do the Garuda-Inxi
Garuda Inxi:
  Kernel: 6.3.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    root=UUID=931ef10b-10a4-449c-a3b8-14866859d086 rw rootflags=subvol=@
    loglevel=3 ibt=off
  Desktop: KDE Plasma v: 5.27.6 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 1
  Type: Laptop System: Dell product: G3 3579 v: N/A
  Mobo: Dell model: 05K0D2 v: A00 serial: <superuser required> UEFI: Dell
    v: 1.25.0 date: 04/12/2023
  ID-1: BAT0 charge: 37.0 Wh (100.0%) condition: 37.0/56.0 Wh (66.1%)
    volts: 16.6 min: 15.2 model: Samsung SDI DELL W7NKD8C type: Li-ion
    serial: <filter> status: full
  Info: model: Intel Core i5-8300H bits: 64 type: MT MCP arch: Coffee Lake
    model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF2
    L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 1550 high: 2300 min/max: 800/4000 scaling:
    driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 800 4: 2300
    5: 800 6: 2300 7: 2300 8: 2300 bogomips: 36799
    ports: active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2
    bus-ID: 0000:00:02.0 chip-ID: 8086:3e9b class-ID: 0300
  Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Dell
    driver: nvidia v: 535.54.03 alternate: nouveau,nvidia_drm non-free: 530.xx+
    status: current (as of 2023-05) arch: Pascal code: GP10x
    process: TSMC 16nm built: 2016-21 bus-ID: 0000:01:00.0 chip-ID: 10de:1c8d
    class-ID: 0302
  Device-3: Sunplus Innovation Integrated_Webcam_HD driver: uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:4
    chip-ID: 1bcf:28c1 class-ID: 0e02
  Monitor-1: eDP-1 model: BOE Display 0x07b0 built: 2018 res: 1920x1080
    hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
    ratio: 16:9 modes: 1920x1080
  API: OpenGL v: 4.6 Mesa 23.1.2 renderer: Mesa Intel UHD Graphics 630 (CFL
    GT2) direct-render: Yes
    v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 0000:00:1f.3
  Device-2: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel
    v: kernel bus-ID: 0000:01:00.1 chip-ID: 10de:0fb9 class-ID: 0403
  Device-3: Logitech G733 Gaming Headset
    lanes: 1 mode: 1.1 bus-ID: 1-3:3 chip-ID: 046d:0ab5 class-ID: 0300
  API: ALSA v: k6.3.9-zen1-1-zen status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.71 status: active with: 1: pipewire-pulse
    bus-ID: 0000:00:14.3 chip-ID: 8086:a370 class-ID: 0280
    vendor: Dell driver: r8169 v: kernel port: 3000 bus-ID: 0000:02:00.0
    v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:6
    address: <filter>
    driver: intel_nvme_remap v: N/A port: 5060 bus-ID: 0000:00:17.0
    chip-ID: 8086:282a rev: N/A class-ID: 0104
  Local Storage: total: 1.84 TiB used: 27.72 GiB (1.5%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Seagate
    model: XPG GAMMIX S11 Pro size: 953.87 GiB block-size: physical: 512 B
    logical: 512 B tech: SSD serial: <filter> fw-rev: 42B2S7JA temp: 35.9 C
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
    tech: HDD rpm: 5400 serial: <filter> fw-rev: SDM3 scheme: GPT
  ID-1: / raw-size: 48.83 GiB size: 48.83 GiB (100.00%)
    used: 27.67 GiB (56.7%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
    used: 51.9 MiB (54.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw-size: 48.83 GiB size: 48.83 GiB (100.00%)
  ID-4: /var/log raw-size: 48.83 GiB size: 48.83 GiB (100.00%)
  ID-5: /var/tmp raw-size: 48.83 GiB size: 48.83 GiB (100.00%)
  ID-1: swap-1 type: zram size: 15.48 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: 61.0 C pch: 53.0 C mobo: N/A
  Processes: 256 Uptime: 7m wakeups: 680 Memory: available: 15.48 GiB
  used: 2.41 GiB (15.6%) Init: systemd v: 253 default: graphical
  tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: pm: pacman
  pkgs: 1984 libs: 543 tools: gnome-software,octopi,pamac,paru Shell: fish
  v: 3.6.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.27
  System install date:     2023-06-10
  Last full system update: 2023-06-22
Official Page: Linux Installation Guide - OpenTabletDriver
PD: The mouse only works with reboot idk is i need put another command for it
It could be this open bug, which seems to be anyway applicable to your model:
No this doesnt works, my problems is with the OpenTablerDriver, when i plug the tablet in usb, the mouse is off only reboot fix it, i mean all clicks are broken, left and right so i cant use another thing only keyboard mmm is hard to describe
This video for example
