Missing information requested in the template may result in not receiving assistance
I need more feasible mouse for dealing things normally with the following system. I’m fan of touchpad user and accelerate mouse speed generally with libinput from systemd for x11 Tiling Managers i3 etc.
I do not have constant/stable touchpad acceleration speed with my Garuda hyperland setup. It’s getting slowing, sometimes faster enough.
Now, I’m using wayland with garuda hyperland so i’ve learned mouse speed should be changed from ~\.config/hyper/hyperland.conf file.
Just I’ve to increase mouse speed it will be just fixed.
Query: increasing mouse speed on hyperland.
the mouse section for testing accelerated speed for is there any actual response for mouse speed. but It is not. I don’t have any effect with
#touchpad {
# Enable natural scrolling
#natural_scroll = true
#scroll_factor = 3
#tap-to-click = true
#disable_while_typing = true
under input {}. I’ve played around this little but no effect at all for sake of acceleration speed (accel_speed).
I’ve learned wayland has a libinput setting management with ~/.config and libinput.conf file. I don’t have to change X11 libinput /etc/X11/xorg.conf.d/40-libinput.conf… -I do not have X11 desktop already-. Moreover single conf file for mouse and touchpad and moreover changes. that would be great. I added following configuration to the ~/.config/libinput.conf file.
Section "InputClass"
Identifier "Touchpad"
MatchIsTouchpad "on"
MatchDevicePath "/dev/input/event5"
Driver "libinput"
Option "AccelProfile" "adaptive"
Option "AccelSpeed" "0.9"
Option "Tapping" "on"
Option "TapButtonMap" "lrm"
Option "NaturalScrolling" "on"
Option "DisableWhileTyping" "on"
Option "MiddleEmulation" "on"
EndSection
Identifier "My Keyboard"
MatchIsKeyboard "on"
# Option "XkbModel" "pc105" # Omit this if unsure
Option "XkbLayout" "us,trq" # Define both layouts
Option "XkbOptions" "terminate:ctrl_alt_bksp"
EndSection
$libinput list-devices
Device: ELAN2602:00 04F3:3109 Touchpad
Kernel: /dev/input/event6
Group: 5
Seat: seat0, default
Capabilities: pointer gesture
Tap-to-click: disabled
Tap-and-drag: enabled
Tap drag lock: disabled
Left-handed: disabled
Nat.scrolling: disabled
Middle emulation: disabled
Calibration: n/a
Scroll methods: *two-finger edge
Click methods: *button-areas clickfinger
Disable-w-typing: enabled
Disable-w-trackpointing: enabled
Accel profiles: flat *adaptive custom
Rotation: n/a
Device: ELAN2602:00 04F3:3109 Mouse
Kernel: /dev/input/event5
Group: 5
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Middle emulation: n/a
Calibration: n/a
Scroll methods: *button
Click methods: none
Disable-w-typing: n/a
Disable-w-trackpointing: n/a
Rotation: n/a
After changing these, I got an effect immediatelly but something… This is not feels correct with touchpad. Mouse speed is getting slow after very comfortable speed. So, I thought I should be wrong because this is not possible. I should be wrong cause no error like so far for 7+ years in linux.
I swept this error beneath the carped. Enabled a Bluetooth mouse. It was very stable, normal and no need acceleration adjustment.
Now, I have unstable Bluetooth mouse cursor after 10 days uptime reboot.
Note: Exact hardware configuration used i3 - ofcourse X11- with manual arch linux crypt setup and there is no problem with touchpad and mouse with zen-kernel. I’m not blaming any hyperland or conf. I just want to say I’m very beginer with wayland and hyperland. Fully open any correction on my error handling.
- Search the web and forums
I’ve searched mouse and other keywors with ddgmouse unstable site::forum.garudalinux.org/in addition to internal search. - Read How to search for solutions the right way | Garuda Linux wiki
- Read FAQ and Tutorials Table of Contents
Issue still unresolved? Then:
- ONE issue per topic.
- Describe your issue in detail. The more we know, the better we can help
- Show us the results of your searches, and what you’ve tried
garuda-inxiin the body of the post (not linked externally, or collapsed with the “hide details” feature) - Format terminal output (including your
garuda-inxi) as a code block by clicking the preformatted text button (</>) , or put three tildes (~) above and below the text
$garuda-inxi
Kernel: 6.12.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=eb7f3c46-63dd-46dd-84c9-6326b668a72f rw rootflags=subvol=@
quiet resume=UUID=838da5b5-6474-433c-8430-f3640f3e0e0c loglevel=3 ibt=off
Desktop: Hyprland v: 0.47.0 with: waybar tools: avail: swayidle,swaylock
vt: 1 dm: SDDM Distro: Garuda base: Arch Linux
Type: Laptop System: HUAWEI product: HN-WX9X v: M1060
Mobo: HUAWEI model: HN-WX9X-PCB v: M1060 serial: <superuser required>
part-nu: C331 uuid: <superuser required> UEFI: HUAWEI v: 1.17
date: 03/10/2022
ID-1: BAT0 charge: 36.1 Wh (99.4%) condition: 36.3/41.2 Wh (88.2%)
volts: 12.3 min: 11.4 model: DYNAPACK HB4593J6ECW type: Li-ion
serial: <filter> status: not charging cycles: 490
Info: model: AMD Ryzen 7 3700U with Radeon Vega Mobile Gfx bits: 64
Topology: cpus: 1x dies: 1 clusters: 1 cores: 4 threads: 8 tpc: 2
smt: enabled cache: L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB
desc: 4x512 KiB L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 2941 min/max: 1400/2300 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 2941 2: 2941 3: 2941
4: 2941 5: 2941 6: 2941 7: 2941 8: 2941 bogomips: 36731
Device-1: Advanced Micro Devices [AMD/ATI] Picasso/Raven 2 [Radeon Vega
Series / Radeon Mobile Series] vendor: Huawei driver: amdgpu v: kernel
speed: 8 GT/s lanes: 16 ports: active: eDP-1 empty: DP-1 bus-ID: 03:00.0
chip-ID: 1002:15d8 class-ID: 0300 temp: 56.0 C
Device-2: IMC Networks HD Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2:3 chip-ID: 13d3:5482
compositor: Hyprland v: 0.47.0 driver: X: loaded: amdgpu
unloaded: modesetting alternate: fbdev,vesa dri: radeonsi gpu: amdgpu
display-ID: 1
Monitor-1: eDP-1 model: ChiMei InnoLux P130ZFA-BA1 built: 2018 res:
mode: 2160x1440 hz: 60 scale: 100% (1) dpi: 200 gamma: 1.2
size: 275x183mm (10.83x7.2") diag: 330mm (13") ratio: 3:2 modes:
max: 2160x1440 min: 640x480
API: Vulkan v: 1.4.303 layers: 9 device: 0 type: integrated-gpu name: AMD
Radeon Vega 10 Graphics (RADV RAVEN) driver: N/A device-ID: 1002:15d8
Info: Tools: api: vulkaninfo wl: kanshi, wdisplays, wlr-randr
x11: xprop,xrandr
Device-1: Advanced Micro Devices [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP
Audio vendor: Huawei driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:15de class-ID: 0403
vendor: Huawei driver: snd_pci_acp3x v: kernel alternate: snd_rn_pci_acp3x,
vendor: Huawei driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.12.10-zen1-1-zen status: kernel-api tools: N/A
vendor: & Tele RSH driver: rtw_8822ce v: N/A modules: rtw88_8822ce pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 01:00.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1:2 chip-ID: 1358:c123
Local Storage: total: 1.15 TiB used: 342.17 GiB (29.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN530
SDBPNPZ-512G-1027 size: 476.94 GiB block-size: physical: 512 B
fw-rev: 21117000 temp: 35.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: ST750LM022 HN-M750MBB
size: 698.64 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: HDD rpm: 5400
serial: <filter> fw-rev: 0409 scheme: GPT
ID-1: / raw-size: 460.61 GiB size: 460.61 GiB (100.00%)
used: 342.17 GiB (74.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 460.61 GiB size: 460.61 GiB (100.00%)
ID-4: /var/log raw-size: 460.61 GiB size: 460.61 GiB (100.00%)
ID-5: /var/tmp raw-size: 460.61 GiB size: 460.61 GiB (100.00%)
ID-1: swap-1 type: zram size: 14.57 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 16.03 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 56.0 C mobo: N/A gpu: amdgpu temp: 56.0 C
Memory: total: 16 GiB note: est. available: 14.57 GiB used: 5.27 GiB (36.1%)
Processes: 276 Power: uptime: 1h 40m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 5.82 GiB services: upowerd Init: systemd
v: 257 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1731 libs: 444 tools: pacseek,paru Compilers:
clang: 19.1.7 gcc: 14.2.1 Shell: garuda-inxi default: fish v: 3.7.1
running-in: alacritty inxi: 3.3.37
Garuda (2.6.26-1.1):
System install date: 2024-12-27
Last full system update: 2025-01-29
