hello devs, i am a newbie here and im trying to mount and unmount my partitions manually by creating 2 systemd service one for mount and another one for unmount the mount one is where the problem lies apparently it is unmounting the partitions after mounting them here is the journalctl -u mount-partitions.service -n 50
-- Boot 7d320b7d36da408980c6249bc745e19a --
May 27 19:06:11 Fameless systemd[1]: Starting Mount specified partitions...
May 27 19:06:11 Fameless sudo[782]: root : PWD=/ ; USER=root ; COMMAND=/usr/bin/mount -t ntfs-3g -o rw,user /dev/disk/by-uuid/D6428A76428A5B5F /home/fameless/Public/basicdatapartition
May 27 19:06:11 Fameless sudo[782]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=0)
May 27 19:06:11 Fameless ntfs-3g[820]: Version 2022.10.3 external FUSE 29
May 27 19:06:11 Fameless ntfs-3g[820]: Mounted /dev/nvme1n1p4 (Read-Write, label "", NTFS 3.1)
May 27 19:06:11 Fameless ntfs-3g[820]: Cmdline options: rw,user,noexec,nosuid,nodev
May 27 19:06:11 Fameless ntfs-3g[820]: Mount options: user,noexec,nosuid,nodev,allow_other,nonempty,relatime,rw,fsname=/dev/nvme1n1p4,blkdev,blksize=4096
May 27 19:06:11 Fameless ntfs-3g[820]: Ownership and permissions disabled, configuration type 7
May 27 19:06:11 Fameless sudo[782]: pam_unix(sudo:session): session closed for user root
May 27 19:06:11 Fameless sudo[822]: root : PWD=/ ; USER=root ; COMMAND=/usr/bin/mount -t ntfs-3g -o rw,user /dev/disk/by-uuid/8A5C23C75C23ACBF /home/fameless/Public/localdisk
May 27 19:06:11 Fameless sudo[822]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=0)
May 27 19:06:11 Fameless ntfs-3g[861]: Version 2022.10.3 external FUSE 29
May 27 19:06:11 Fameless ntfs-3g[861]: Mounted /dev/nvme0n1p2 (Read-Write, label "Local Disk", NTFS 3.1)
May 27 19:06:11 Fameless ntfs-3g[861]: Cmdline options: rw,user,noexec,nosuid,nodev
May 27 19:06:11 Fameless ntfs-3g[861]: Mount options: user,noexec,nosuid,nodev,allow_other,nonempty,relatime,rw,fsname=/dev/nvme0n1p2,blkdev,blksize=4096
May 27 19:06:11 Fameless ntfs-3g[861]: Ownership and permissions disabled, configuration type 7
May 27 19:06:11 Fameless sudo[822]: pam_unix(sudo:session): session closed for user root
May 27 19:06:11 Fameless ntfs-3g[861]: Unmounting /dev/nvme0n1p2 (Local Disk)
May 27 19:06:11 Fameless ntfs-3g[820]: Unmounting /dev/nvme1n1p4 ()
May 27 19:06:11 Fameless systemd[1]: mount-partitions.service: Deactivated successfully.
May 27 19:06:11 Fameless systemd[1]: Finished Mount specified partitions.
and here is my garuda-inixi
Kernel: 6.6.30-2-lts arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=7b03772c-1cf6-402a-b847-a5bc6c4628e8 rw rootflags=subvol=@
verbose resume=UUID=20aa409f-e14d-469d-bd7a-18c35a808429 loglevel=3
Desktop: KDE Plasma v: 6.0.4 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
Type: Laptop System: ASUSTeK product: ASUS TUF Gaming A15
FA506IHRB_FA506IHRB v: 1.0 serial: <filter>
Mobo: ASUSTeK model: FA506IHRB v: 1.0 serial: <filter>
uuid: c24fe503-6232-8340-8cdd-86e97147d59a UEFI: American Megatrends
v: FA506IHRB.307 date: 12/28/2022
ID-1: BAT1 charge: 43.0 Wh (57.4%) condition: 74.9/90.2 Wh (83.0%)
volts: 15.1 min: 15.9 model: ASUS A32-K55 type: Li-ion serial: N/A
Info: model: AMD Ryzen 5 4600H with Radeon Graphics socket: FP6 bits: 64
type: MT MCP arch: Zen 2 gen: 3 level: v3 note: check built: 2020-22
microcode: 0x8600106
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 613 high: 2966 min/max: 400/4006 base/boost: 3000/4000
scaling: driver: amd-pstate-epp governor: performance volts: 1.2 V
ext-clock: 100 MHz cores: 1: 400 2: 400 3: 2966 4: 400 5: 400 6: 400
7: 400 8: 400 9: 400 10: 400 11: 400 12: 400 bogomips: 71894
Device-1: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: ASUSTeK
driver: nvidia v: 550.78 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-04; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none empty: DP-1
bus-ID: 01:00.0 chip-ID: 10de:1f9d class-ID: 0300
Device-2: AMD Renoir [Radeon RX Vega 6 ] vendor: ASUSTeK driver: amdgpu
v: kernel arch: GCN-5 code: Vega process: GF 14nm built: 2017-20 pcie:
active: eDP-1 empty: HDMI-A-1 bus-ID: 06:00.0 chip-ID: 1002:1636
class-ID: 0300 temp: 42.0 C
Device-3: Sonix USB2.0 HD UVC WebCam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:2 chip-ID: 322e:202c
class-ID: 0e02
Display: server: X.Org v: 23.2.6 with: Xwayland v: 23.2.6
gpu: amdgpu display-ID: :1 screens: 1
s-diag: 583mm (22.95")
Monitor-1: eDP-1 model: Najing CEC Panda 0x004d built: 2019 res: 1920x1080
hz: 144 dpi: 143 gamma: 1.2 size: 340x190mm (13.39x7.48")
surfaceless: drv: nvidia x11: drv: radeonsi inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 24.0.7-arch1.3
renoir LLVM 17.0.6 DRM 3.54 6.6.30-2-lts) device-ID: 1002:1636
memory: 500 MiB unified: no
API: Vulkan v: 1.3.279 layers: 6 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 24.0.7-arch1.3
device-ID: 1002:1636 surfaces: xcb,xlib device: 1 type: discrete-gpu
name: NVIDIA GeForce GTX 1650 driver: nvidia v: 550.78
device-ID: 10de:1f9d surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
(LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.7-arch1.3 (LLVM
gen: 3 speed: 8 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.1 chip-ID: 1002:1637
Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: N/A
snd_sof_amd_rembrandt, snd_sof_amd_vangogh pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.5
API: ALSA v: k6.6.30-2-lts status: kernel-api tools: N/A
Server-1: PipeWire v: 1.0.6 status: n/a (root, process) with:
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:2 chip-ID: 13d3:3563
Local Storage: total: 942.7 GiB used: 103.9 GiB (11.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT500P3SSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR30A temp: 44.9 C
SMART: yes health: PASSED on: 76d 22h cycles: 2,369
read-units: 32,823,532 [16.8 TB] written-units: 16,357,961 [8.37 TB]
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Samsung
fw-rev: FXM7201Q temp: 43.9 C scheme: GPT
SMART: yes health: PASSED on: 25d 3h cycles: 2,283
read-units: 24,568,650 [12.5 TB] written-units: 18,917,235 [9.68 TB]
ID-1: / raw-size: 184.69 GiB size: 184.69 GiB (100.00%)
used: 103.88 GiB (56.2%) fs: btrfs block-size: 4096 B dev: /dev/nvme1n1p8
maj-min: 259:12
used: 30 MiB (11.7%) fs: vfat block-size: 512 B dev: /dev/nvme1n1p1
maj-min: 259:5
ID-3: /home raw-size: 184.69 GiB size: 184.69 GiB (100.00%)
maj-min: 259:12
ID-4: /var/log raw-size: 184.69 GiB size: 184.69 GiB (100.00%)
maj-min: 259:12
ID-5: /var/tmp raw-size: 184.69 GiB size: 184.69 GiB (100.00%)
maj-min: 259:12
ID-1: swap-1 type: partition size: 16 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme1n1p3 maj-min: 259:7
ID-2: swap-2 type: zram size: 15.05 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 51.6 C mobo: 48.0 C gpu: amdgpu temp: 42.0 C
Fan Speeds (rpm): cpu: 3200
Memory: total: 16 GiB note: est. available: 15.05 GiB used: 3.85 GiB (25.6%)
Processes: 363 Power: uptime: 10m states: freeze,mem,disk suspend: s2idle
image: 5.98 GiB services: org_kde_powerdevil, power-profiles-daemon,
upowerd Init: systemd v: 255 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1690 libs: 431 tools: octopi,pamac,paru
Compilers: clang: 17.0.6 gcc: 14.1.1 Shell: garuda-inxi (sudo) default: Bash
v: 5.2.26 running-in: konsole inxi: 3.3.34
System install date: 2024-03-28
Last full system update: 2024-05-27
Windows dual boot: Yes
can anybody tell me why the service is doing so and any solutions to fix this up
here is the service
[Unit]
Description=Mount specified partitions
[Service]
Type=oneshot
ExecStart=/usr/bin/fish -c 'sudo mount -t ntfs-3g -o rw,user /dev/disk/by-uuid/D6428A76428A5B5F /home/fameless/Public/basicdatapartition; and sudo mount -t ntfs-3g -o rw,user /dev/disk/by-uuid/8A5C23C75C23ACBF /home/fameless/Public/localdisk'>
StandardOutput=journal
StandardError=journal
[Install]
WantedBy=multi-user.target
