Hi all,
Manjaro has an icon in tray which confirms when USB disk is mounted, with options to unmount.
I can't see this in Garuda tray or in applets list to add.
Can you please guide on how to add this.
Many thanks.
Hi all,
Many thanks.
First of all, tell us your DE.
Edit: oh, is it Xfce? As you posted in Xfce?
Have you read xfce user manual?
You may mean a panel widget. Right-click on panel and add widget (or however they are called). Find one with relevant name (drives, mount, etc.).
Hi,
DE is XFCE.
Sorry, when I referred to applets list, I meant the panel items/widgets.
I've looked in there already and although there is a rudimentary 'mount disks' item, its not the one used by Manjaro xfce which is much better.
Was just wondering if there was a way to add the one they use, as can't see it in the panel items/widgets list.
thanks
Easy, use Manjaro ![]()
Look better. I don’t remember Manjaro having created an xfce4 applet, unless it is so recent.
You have to add, so you can see what’s available.
