The 2 latest days my two monitors have a hard time being recognized after either waking the computer up from sleep or from boot.
I've had this setup working without problems for about 2 months.
So I suspect that the problems comes from the Garuda update in Octopai.
Yesterday I got it working after a lot of trial and error but never figured out why.
Today I finally got it working after removing the the secondary monitor completely,
a Samsung U28E590D using DisplayPort. My main monitor is a 328E9FJAB/00 and are now using the DisplayPort for this monitor since none of the attempts with HDMI worked today.
But until today I used the DisplayPort for the Samsung monitor and a HDMI cable for my Philips main monitor without problems. I did try another HDMI cable with the problem persisting.
I don't know if this is related but another problem that is related to this (in my opinion), but that worked out in the end every time is that one of two or three open Firefox (not the Dragonized version) windows didn't show the taskbar at the top so I could not close it, minimize it or maximize it, no matter if it was maximized or not. I suspect this is a window manager problem though.
How I solved that problem was by pulling the display cable and reattaching it. Or closing my Firefox session. The latter solution I try to avoid since I sometimes lose the last session with open tabs.
Kernel: 5.16.2-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=df24bdae-c083-4314-bce7-f49e58559361 rw [email protected]
resume=UUID=5d34b90d-33db-4d1a-bf97-eddb9e1e7da6 loglevel=3
Type: Desktop Mobo: Gigabyte model: B550 AORUS ELITE V2 v: x.x
serial: <superuser required> UEFI: American Megatrends v: F12
date: 01/18/2021
Info: model: AMD Ryzen 7 PRO 4750G with Radeon Graphics bits: 64
type: MT MCP arch: Zen 2 family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600106
L3: 8 MiB desc: 2x4 MiB
Speed (MHz): avg: 3169 high: 4147 min/max: 1400/3600 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 4138 2: 3561
3: 3047 4: 2981 5: 2995 6: 2990 7: 2989 8: 2994 9: 4147 10: 2994 11: 2960
12: 2982 13: 2964 14: 2978 15: 2995 16: 2994 bogomips: 114985
Device-1: AMD Renoir vendor: Gigabyte driver: amdgpu v: kernel
bus-ID: 0b:00.0 chip-ID: 1002:1636 class-ID: 0300
Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.7x15.0")
s-diag: 777mm (30.6")
Monitor-1: DisplayPort-0 res: 2560x1440 dpi: 93
size: 697x392mm (27.4x15.4") diag: 800mm (31.5")
v: kernel bus-ID: 0b:00.1 chip-ID: 1002:1637 class-ID: 0403
v: kernel bus-ID: 0b:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.16.2-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.43 running: yes
Device-1: Qualcomm Atheros AR9285 Wireless Network Adapter driver: ath9k
v: kernel bus-ID: 05:00.0 chip-ID: 168c:002b class-ID: 0280
port: f000 bus-ID: 08:00.0 chip-ID: 10ec:8125 class-ID: 0200
Device-3: Realtek RTL8152 Fast Ethernet Adapter type: USB driver: r8152
bus-ID: 3-2.4:4 chip-ID: 0bda:8152 class-ID: 0000 serial: <filter>
IF: enp11s0f3u2u4 state: down mac: <filter>
IF-ID-2: ipv6leakintrf0 state: unknown speed: N/A duplex: N/A
mac: <filter>
IF-ID-3: proton0 state: unknown speed: 10 Mbps duplex: full mac: N/A
Local Storage: total: 17.55 TiB used: 903.92 GiB (5.0%)
ID-1: /dev/nvme0n1 maj-min: 259:8 vendor: Corsair model: Force MP510
size: 894.25 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: ECFM22.7
temp: 28.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:2 vendor: Corsair model: Force MP510
ID-3: /dev/nvme2n1 maj-min: 259:0 vendor: Corsair model: Force MP510
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: ECFM22.6
temp: 32.9 C scheme: GPT
ID-4: /dev/nvme3n1 maj-min: 259:1 vendor: Corsair model: Force MP510
temp: 31.9 C scheme: GPT
ID-5: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 500GB
type: SSD serial: <filter> rev: 2B6Q scheme: MBR
ID-6: /dev/sdb maj-min: 8:16 vendor: Kingston model: SA400S37960G
size: 894.25 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 1103 scheme: MBR
ID-7: /dev/sdc maj-min: 8:32 model: QNAP QDA-A2AR RAID1 size: 12.73 TiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: HDD
rpm: 7200 serial: <filter> rev: 0601 scheme: GPT
ID-1: / raw-size: 825.54 GiB size: 825.54 GiB (100.00%)
used: 348.91 GiB (42.3%) fs: btrfs dev: /dev/nvme3n1p2 maj-min: 259:4
used: 576 KiB (0.2%) fs: vfat dev: /dev/nvme3n1p1 maj-min: 259:3
ID-3: /home raw-size: 825.54 GiB size: 825.54 GiB (100.00%)
ID-4: /var/log raw-size: 825.54 GiB size: 825.54 GiB (100.00%)
ID-5: /var/tmp raw-size: 825.54 GiB size: 825.54 GiB (100.00%)
ID-1: swap-1 type: zram size: 62.28 GiB used: 2.8 MiB (0.0%)
ID-2: swap-2 type: partition size: 68.42 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme3n1p3 maj-min: 259:6
System Temperatures: cpu: 29.0 C mobo: 25.0 C gpu: amdgpu temp: 25.0 C
Processes: 405 Uptime: 2h 21m wakeups: 0 Memory: 62.28 GiB
used: 8 GiB (12.8%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1588 lib: 368 Shell: fish
Garuda:
System install date: 2021-11-18
Last full system update: 2022-01-25
Using TLP: No
