Hello, I’ve been having some issues trying to set up Garuda as my main OS since I switched from Windows 10. 2 out of the 3 monitors i used no longer detect at all. They both did when i installed Garuda but after trying to fix other problems I’ve been having I managed to cause these monitors to stop working. I am using a desktop with a Huion Kamvas Pro 13 connected through displayport (the only working monitor at the moment,) an Acer monitor connected through HDMI, and a Vizio TV connected through a HDMI-DVI cable. I’ve tried reinstalling drivers, replugging both monitors to and from the computer, and rebooting several times, and nohing seemed to fix the problem.
Kernel: 6.9.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=05c7f548-497b-4b19-b836-cc613b9bbda1 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.1.2 tk: Qt v: N/A info: frameworks v: 6.4.0
Type: Desktop Mobo: ASUSTeK model: TUF GAMING X570-PLUS (WI-FI) v: Rev X.0x
UEFI: American Megatrends v: 1407 date: 04/01/2020
Info: model: AMD Ryzen 5 2600X bits: 64 type: MT MCP arch: Zen+ gen: 2
model-id: 8 stepping: 2 microcode: 0x800820D
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 3634 high: 4015 min/max: 2200/3600 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3600 2: 3600
3: 3600 4: 3600 5: 3600 6: 3600 7: 3600 8: 3600 9: 4015 10: 3600 11: 3600
12: 3600 bogomips: 86224
Device-1: NVIDIA GP104 [GeForce GTX 1070] driver: N/A alternate: nouveau
non-free: 545.xx+ status: current (as of 2024-06; EOL~2026-12-xx)
speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 08:00.0
chip-ID: 10de:1b81 class-ID: 0300
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.1
compositor: kwin_x11 driver: X: loaded: modesetting,nouveau
alternate: fbdev,nv,vesa gpu: N/A display-ID: :0 screens: 1
Monitor-1: Unknown-1 mapped: None-1 res: 1920x1080 hz: 60 size: N/A
modes: 1920x1080
API: EGL v: 1.5 platforms: device: 0 drv: swrast gbm: drv: kms_swrast
surfaceless: drv: swrast x11: drv: swrast inactive: wayland
API: OpenGL v: 4.5 vendor: mesa v: 24.1.3-arch1.1 glx-v: 1.4
direct-render: yes renderer: llvmpipe (LLVM 18.1.8 256 bits)
device-ID: ffffffff:ffffffff memory: 15.17 GiB unified: yes
API: Vulkan v: 1.3.279 layers: 8 device: 0 type: cpu name: llvmpipe (LLVM
18.1.8 256 bits) driver: mesa llvmpipe v: 24.1.3-arch1.1 (LLVM 18.1.8)
Device-1: NVIDIA GP104 High Definition Audio driver: snd_hda_intel v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s
bus-ID: 08:00.1 chip-ID: 10de:10f0 class-ID: 0403
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0a:00.3
API: ALSA v: k6.9.10-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.1 status: active with: 1: pipewire-pulse
Device-1: Intel Wi-Fi 5 Wireless-AC 9x6x [Thunder Peak] driver: iwlwifi
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 03:00.0
vendor: ASUSTeK driver: r8168 v: 8.053.00-NAPI modules: r8169 pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-5:2
Local Storage: total: 465.76 GiB used: 17.41 GiB (3.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB
used: 17.41 GiB (3.7%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 66.6 C mobo: N/A
Memory: total: 16 GiB available: 15.54 GiB used: 2.51 GiB (16.1%)
Processes: 321 Power: uptime: 1m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.2 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1433 libs: 414 tools: octopi,paru Compilers:
gcc: 14.1.1 Shell: garuda-inxi default: fish v: 3.7.1 running-in: konsole
inxi: 3.3.35
System install date: 2024-07-18
Last full system update: 2024-07-19
