This morning I did a reboot from Garuda to go into XeroLinux and the monitor shut off but the system continued to boot into Garuda.
The day before yesterday I installed Xero behind Garuda, and yesterday I installed ChachyOS and Arch using Calam installer and in all three I did the initial updates, rebooted installed my apps that run under the hood, rebooted into the bios, changed the boot order back to Gariuda, booted and got the Garuda Grub menu without issue. Today I rebooted, waited for the Garuda Grub menu so I could select Xero to finish setting it up and the monitor turned off and the system continued to boot into Gurada. Had to power off the system twice before I could get the system to boot without turning off the monitor, but still not seeing the Garuda Greub menu. There were updates that I did this morning that must have affected Grub. I’ve included the inxi, a run of update-grub, and a link to a copy of my Grub file. Thanks
I should add that all the hardware with the exception of the motherboard is new as of 3 days ago.
╭─locutus@Unimatrix in ~ took 2ms
╰─λ garuda-inxi
Kernel: 6.6.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=bdb799c2-641a-456b-8bbb-d286e94a9d63 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2
Mobo: ASUSTeK model: TUF GAMING B550-PLUS WIFI II v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 3404
date: 10/07/2023
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M325
Device-2: hidpp_battery_1 model: Logitech Wireless Keyboard K360
Info: model: AMD Ryzen 7 5700X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 2 microcode: 0xA20120E
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3447 high: 3609 min/max: 2200/4662 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3592 2: 3400
3: 3609 4: 3400 5: 3400 6: 3400 7: 3400 8: 3400 9: 3400 10: 3400 11: 3580
12: 3400 13: 3400 14: 3400 15: 3400 16: 3583 bogomips: 108594
Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate] vendor: ASUSTeK
status: current (as of 2023-10; EOL~2026-12-xx) arch: Ampere code: GAxxx
lanes: 16 ports: active: none off: HDMI-A-1 empty: DP-1,DP-2,DP-3
bus-ID: 07:00.0 chip-ID: 10de:2504 class-ID: 0300
Display: x11 server: X.Org v: 21.1.10 with: Xwayland v: 23.2.3
Screen-1: 0 s-res: 2560x1080 s-dpi: 97 s-size: 670x283mm (26.38x11.14")
s-diag: 727mm (28.63")
Monitor-1: HDMI-A-1 mapped: HDMI-0 note: disabled model: AOC Q2963
serial: <filter> built: 2016 res: 2560x1080 hz: 60 dpi: 97 gamma: 1.2
size: 673x284mm (26.5x11.18") diag: 730mm (28.8") modes: max: 2560x1080
min: 640x480
inactive: wayland,device-1
memory: 11.72 GiB
API: Vulkan v: 1.3.274 layers: 7 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3060 driver: nvidia v: 545.29.06
device-ID: 10de:2504 surfaces: xcb,xlib
bus-ID: 07:00.1 chip-ID: 10de:228e class-ID: 0403
bus-ID: 09:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.6.7-zen1-1-zen status: kernel-api with: aoss
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 06:00.0
Local Storage: total: 26.89 TiB used: 15.89 TiB (59.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000T500SSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P8CR002 temp: 26.9 C
ID-2: /dev/nvme1n1 maj-min: 259:6 vendor: Crucial model: CT500P3SSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR30A temp: 27.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: Expansion HDD
size: 10.91 TiB block-size: physical: 4096 B logical: 512 B type: USB
fw-rev: 0003 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Seagate model: Expansion HDD
fw-rev: 1801 scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST8000AS0002-1NA17Z
rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: HDD rpm: 5980
serial: <filter> scheme: GPT
ID-6: /dev/sdd maj-min: 8:48 vendor: SanDisk model: USB 3.2Gen1
size: 57.3 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.1
spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: 1.00
ID-1: / raw-size: 232.8 GiB size: 232.8 GiB (100.00%)
used: 25.88 GiB (11.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 1.4 MiB (0.5%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 232.8 GiB size: 232.8 GiB (100.00%)
ID-4: /var/log raw-size: 232.8 GiB size: 232.8 GiB (100.00%)
ID-5: /var/tmp raw-size: 232.8 GiB size: 232.8 GiB (100.00%)
ID-1: swap-1 type: zram size: 46.95 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 36.6 C mobo: N/A gpu: nvidia temp: 31 C
Processes: 480 Uptime: 2h 42m wakeups: 0 Memory: total: 48 GiB
available: 46.95 GiB used: 7.1 GiB (15.1%) Init: systemd v: 255
default: graphical tool: systemctl Compilers: gcc: 13.2.1 Packages: 2110
pm: pacman pkgs: 2098 libs: 573 tools: paru,pikaur pm: flatpak pkgs: 12
pm: snap pkgs: 0 Shell: fish v: 3.6.4 running-in: konsole inxi: 3.3.31
Garuda (2.6.21-1):
System install date: 2023-12-19
Last full system update: 2023-12-20
╭─locutus@Unimatrix in ~ took 1ms
╰─λ sudo update-grub
[sudo] password for locutus:
Found theme: /usr/share/grub/themes/garuda-dr460nized/theme.txt
Found initrd image: /boot/amd-ucode.img /boot/initramfs-linux-zen.img
Found fallback initrd image(s) in /boot: amd-ucode.img initramfs-linux-zen-fallback.img
Found XeroLinux on /dev/nvme0n1p3
Found CachyOS on /dev/nvme0n1p4
Found Arch Linux on /dev/nvme0n1p5
Adding boot menu entry for UEFI Firmware Settings ...
Detecting snapshots ...
Found snapshot: 2023-12-20 04:12:22 | @/.snapshots/240/snapshot | post | sonarr-develop |
Found snapshot: 2023-12-20 04:12:20 | @/.snapshots/239/snapshot | pre | pacman --upgrade --noconfirm -- /home/locutus/.cache/paru/clone/sonarr-d |
Found snapshot: 2023-12-20 04:12:07 | @/.snapshots/238/snapshot | post | radarr-develop |
Found snapshot: 2023-12-20 04:12:05 | @/.snapshots/237/snapshot | pre | pacman --upgrade --noconfirm -- /home/locutus/.cache/paru/clone/radarr-d |
Found snapshot: 2023-12-20 04:11:52 | @/.snapshots/236/snapshot | post | prowlarr-nightly |
Found snapshot: 2023-12-20 04:11:50 | @/.snapshots/235/snapshot | pre | pacman --upgrade --noconfirm -- /home/locutus/.cache/paru/clone/prowlarr |
Found snapshot: 2023-12-20 04:11:32 | @/.snapshots/234/snapshot | post | emby-server-beta |
Found snapshot: 2023-12-20 04:11:31 | @/.snapshots/233/snapshot | pre | pacman --upgrade --noconfirm -- /home/locutus/.cache/paru/clone/emby-ser |
Found snapshot: 2023-12-20 04:10:30 | @/.snapshots/232/snapshot | post | brave-nightly-bin discord firefox-developer-edition gst-libav gst-plugin |
Found snapshot: 2023-12-20 04:10:07 | @/.snapshots/231/snapshot | pre | pacman -Su |
Found 10 snapshot(s)
Unmount /tmp/grub-btrfs.2Ixp3HsF5u .. Success
/usr/bin/grub-probe: warning: unknown device type nvme0n1.
done
