Hi!
After some time my monitor goes into power saving (I believe; Samsung blinking blue light).
But moving mouse and key presses dont exit it.
Thoughts anyone?
Thanks!!
Q
Hi!
Thoughts anyone?
Thanks!!
Q
Please provide your system specs with the output of inxi -Fza as text, formatted with 3 ~ before and after
Monitor: Samsung ultrawide S34J550WQ
System: Kernel: 5.14.0-195-tkg-bmq x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=d3a6dd9c-94ab-4529-8e4c-f5f144f32998 rw rootflags=subvol=@ quiet splash
Desktop: i3 4.19.1 info: i3bar vt: 7 dm: LightDM 1.30.0 Distro: Garuda Linux
Machine: Type: Desktop Mobo: ASUSTeK model: TUF GAMING X570-PLUS (WI-FI) v: Rev X.0x
serial: <filter> UEFI: American Megatrends v: 2607 date: 08/14/2020
CPU: Info: 6-Core model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+ family: 17 (23)
model-id: 8 stepping: 2 microcode: 800820D cache: L2: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 81519
Speed: 3518 MHz min/max: 1550/3400 MHz boost: enabled Core speeds (MHz): 1: 3518
2: 3518 3: 3518 4: 3514 5: 3506 6: 3518 7: 3533 8: 3518 9: 3509 10: 3518 11: 3519
12: 3494
Graphics: Device-1: NVIDIA GK208B [GeForce GT 710] vendor: Micro-Star MSI driver: nouveau
v: kernel bus-ID: 09:00.0 chip-ID: 10de:128b class-ID: 0300
Display: x11 server: X.Org 1.20.13 compositor: picom v: git-dac85 driver:
loaded: nouveau unloaded: modesetting alternate: fbdev,nv,vesa display-ID: :0
Screen-1: 0 s-res: 3440x1440 s-dpi: 96 s-size: 910x381mm (35.8x15.0")
s-diag: 987mm (38.8")
Monitor-1: HDMI-1 res: 3440x1440 hz: 50 dpi: 110 size: 797x333mm (31.4x13.1")
diag: 864mm (34")
OpenGL: renderer: NV106 v: 4.3 Mesa 21.2.1 direct render: Yes
Audio: Device-1: NVIDIA GK208 HDMI/DP Audio vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel bus-ID: 09:00.1 chip-ID: 10de:0e0f class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 0b:00.3 chip-ID: 1022:1457 class-ID: 0403
Sound Server-1: ALSA v: k5.14.0-195-tkg-bmq running: yes
Sound Server-4: PipeWire v: 0.3.34 running: yes
Network: Device-1: Intel Wireless-AC 9260 driver: iwlwifi v: kernel bus-ID: 04:00.0
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK
driver: r8169 v: kernel port: f000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
Bluetooth: Device-1: Intel Wireless-AC 9260 Bluetooth Adapter type: USB driver: btusb v: 0.8
bus-ID: 3-5:2 chip-ID: 8087:0025 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 0 state: down bt-service: enabled,running
rfk-block: hardware: no software: no address: <filter>
Drives: Local Storage: total: 2.74 TiB used: 69.26 GiB (2.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO Plus 1TB
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
type: SSD serial: <filter> rev: 2B2QEXM7 temp: 42.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102 size: 1.82 TiB
serial: <filter> rev: 0001 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: Kingston model: DataTraveler 2.0
size: 7.22 GiB block-size: physical: 512 B logical: 512 B type: N/A serial: <filter>
rev: 1.00
Partition: ID-1: / raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 25.85 GiB (2.8%)
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 560 KiB (0.2%)
fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 25.85 GiB (2.8%)
ID-4: /var/log raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 25.85 GiB (2.8%)
ID-5: /var/tmp raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 25.85 GiB (2.8%)
Swap: Kernel: swappiness: 133 (default 60) cache-pressure: 50 (default 100)
Sensors: System Temperatures: cpu: 58.4 C mobo: N/A gpu: nouveau temp: 39.0 C
Info: Processes: 358 Uptime: 47m wakeups: 0 Memory: 31.27 GiB used: 5.3 GiB (17.0%)
Init: systemd v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages:
pacman: 1472 lib: 361 Client: Unknown Client: garuda-assistant inxi: 3.3.06
Maybe check some settings (or just try disabling) here
https://wiki.archlinux.org/title/Display_Power_Management_Signaling
I'd also try some other kernels...
