vog
May 26, 2022, 5:06pm
1
Hello, I have had some issues as of late on a new install of Garuda. I am using a laptop which is connected to a larger monitor through DisplayPort. The monitor was working for the first day, and suddenly it stopped being able to connect. I have tried reinstalling drivers, replugging the monitor to and from the laptop, to no avail.
Kernel: 5.17.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=fda5fcc4-03b0-4ad9-929b-ff743a9ec896 rw rootflags=subvol=@
quiet
cryptdevice=UUID=ef0974f8-9756-4d2d-b527-aeb5c04361a3:luks-ef0974f8-9756-4d2d-b527-aeb5c04361a3
root=/dev/mapper/luks-ef0974f8-9756-4d2d-b527-aeb5c04361a3 quiet splash
resume=/dev/mapper/luks-a1e3ecc0-83d2-415b-9754-a4b26ed59fe5 loglevel=3
Type: Laptop System: Razer product: Blade v: 3.04
Mobo: Razer model: CH530 serial: <superuser required> UEFI: Razer v: 1.05
date: 09/19/2019
ID-1: BAT0 charge: 77.2 Wh (99.9%) condition: 77.3/80.2 Wh (96.4%)
volts: 17.0 min: 15.4 model: Razer Blade type: Unknown serial: <filter>
status: N/A
family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF0
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 4384 high: 4501 min/max: 800/4500 scaling:
driver: intel_pstate governor: performance cores: 1: 4304 2: 4390 3: 4400
4: 4311 5: 4400 6: 4404 7: 4401 8: 4501 9: 4298 10: 4401 11: 4401
12: 4400 bogomips: 62399
Type: l1tf
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Razer USA
driver: i915 v: kernel ports: active: eDP-1 empty: none bus-ID: 00:02.0
chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU104M [GeForce RTX 2080 Mobile] vendor: Razer USA
driver: N/A alternate: nouveau non-free: 515.xx+
status: current (as of 2022-05) arch: Turing pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1e90 class-ID: 0300
Device-3: IMC Networks Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-7:6 chip-ID: 13d3:56d5 class-ID: 0e02 serial: <filter>
Monitor-1: eDP-1 model: Sharp LQ156M1JW08 built: 2019 res: 1920x1080
hz: 240 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
v: 4.6 Mesa 22.1.0 direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Razer USA
Device-2: NVIDIA TU104 HD Audio vendor: Razer USA driver: snd_hda_intel
Device-3: Razer USA RZ19-0229 Gaming Microphone type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-3:4 chip-ID: 1532:0511
Sound Server-1: ALSA v: k5.17.9-zen1-1-zen running: yes
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB
driver: r8152 bus-ID: 6-1:2 chip-ID: 0bda:8153 class-ID: 0000
IF: enp60s0u1 state: up speed: 1000 Mbps duplex: full mac: <filter>
bus-ID: 1-5:5 chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 476.94 GiB used: 39.95 GiB (8.4%)
model: MZVLB512HAJQ-00000 size: 476.94 GiB block-size: physical: 512 B
rev: EXA7301Q temp: 48.9 C scheme: GPT
ID-1: / raw-size: 459.56 GiB size: 459.56 GiB (100.00%)
used: 39.95 GiB (8.7%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-ef0974f8-9756-4d2d-b527-aeb5c04361a3
ID-3: /home raw-size: 459.56 GiB size: 459.56 GiB (100.00%)
ID-4: /var/log raw-size: 459.56 GiB size: 459.56 GiB (100.00%)
ID-5: /var/tmp raw-size: 459.56 GiB size: 459.56 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.52 GiB used: 4.2 MiB (0.0%)
ID-2: swap-2 type: partition size: 17.07 GiB used: 0 KiB (0.0%)
mapped: luks-a1e3ecc0-83d2-415b-9754-a4b26ed59fe5
System Temperatures: cpu: 63.0 C pch: 66.0 C mobo: N/A
Processes: 305 Uptime: 13m wakeups: 1 Memory: 15.52 GiB
used: 3.35 GiB (21.6%) Init: systemd v: 251 tool: systemctl Compilers:
gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1781 lib: 513 Shell: fish
v: 3.4.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.16
Garuda (2.6.3-2):
System install date: 2022-05-25
Last full system update: 2022-05-26 ↻
vog
May 26, 2022, 5:12pm
3
By "reinstall" I mean going to the Hardware Configuration in the Garuda Settings Manager and right clicking on the optimus driver and clicking reinstall. I don't even think that actually reinstalled anything, as it gave me an error
filo
May 26, 2022, 5:13pm
4
At least a reboot is in order
TNE
5
Please post your garuda-inxi again after this.
vog
May 26, 2022, 5:16pm
6
quiet
date: 09/19/2019
status: N/A
Speed (MHz): avg: 4369 high: 4470 min/max: 800/4500 scaling:
driver: intel_pstate governor: performance cores: 1: 4296 2: 4295 3: 4470
4: 4357 5: 4311 6: 4441 7: 4402 8: 4388 9: 4421 10: 4354 11: 4342
12: 4355 bogomips: 62399
Type: l1tf
Local Storage: total: 476.94 GiB used: 39.96 GiB (8.4%)
rev: EXA7301Q temp: 50.9 C scheme: GPT
used: 39.96 GiB (8.7%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
ID-1: swap-1 type: zram size: 15.52 GiB used: 2.2 MiB (0.0%)
System Temperatures: cpu: 65.0 C pch: 67.0 C mobo: N/A
Processes: 329 Uptime: 0m wakeups: 1 Memory: 15.52 GiB
used: 2.68 GiB (17.3%) Init: systemd v: 251 tool: systemctl Compilers:
Garuda (2.6.3-2):
I have rebooted several times
TNE
May 26, 2022, 5:19pm
7
What's the output of
sudo modprobe -a nvidia
dkms status
vog
May 26, 2022, 5:20pm
8
modprobe: WARNING: Module nvidia not found in directory /lib/modules/5.17.9-zen1-1-zen
acpi_call/1.2.2: added
bbswitch/0.8: added
nvidia/515.43.04: added
TNE
May 26, 2022, 5:22pm
9
sudo pacman -S nvidia-dkms
vog
May 26, 2022, 5:25pm
10
Downloaded nvidia-dkms successfully
modprobe -a nvidia returned nothing
TNE
May 26, 2022, 5:26pm
11
Reboot, post garuda-inxi
and while you're at it, try using your monitor again. Should work now.
TNE:
Hmmm…
I started having troubles (NVIDIA driver does not load) after updating today. Could be related.
And yes, I rebooted many times.
EDIT: I forgot the testing repos on
TNE
May 26, 2022, 5:28pm
13
Please make your own thread.
vog
May 26, 2022, 5:29pm
14
quiet
date: 09/19/2019
status: N/A
Speed (MHz): avg: 4222 high: 4401 min/max: 800/4500 scaling:
driver: intel_pstate governor: performance cores: 1: 4252 2: 4283 3: 4401
4: 4375 5: 4397 6: 4251 7: 4141 8: 4296 9: 4263 10: 3279 11: 4330
Type: l1tf
driver: nvidia v: 515.43.04 alternate: nouveau,nvidia_drm non-free: 515.xx+
lanes: 16 ports: active: none empty: DP-1, DP-2, DP-3, HDMI-A-1
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia gpu: i915
Local Storage: total: 476.94 GiB used: 39.85 GiB (8.4%)
rev: EXA7301Q temp: 57.9 C scheme: GPT
used: 39.85 GiB (8.7%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
System Temperatures: cpu: 71.0 C pch: 75.0 C mobo: N/A
Processes: 334 Uptime: 1m wakeups: 1 Memory: 15.52 GiB
used: 2.67 GiB (17.2%) Init: systemd v: 251 tool: systemctl Compilers:
Garuda (2.6.3-2):
I tried plugging in the monitor after booting. That didn't work, so I will try to plug in before I reboot.
Edit: Didn't work
vog
May 26, 2022, 5:36pm
15
It started working for me now. Thank you!
system
Closed
May 28, 2022, 5:36pm
16
