I’m asking for help with booting into Garuda Linux, I can install it fine and everything, but when I try to boot into it, my monitor says no support, I’ve tried using different cables and I even tried a different monitor, but nothing has worked. This happens when I install Nvidia drivers, even though I have an Nvidia card, I have an rtx 3060.
If anyone could help it would be greatly appreciated
You may have forgotten or overlooked to post the terminal output from garuda-inxi, as requested in the template for your post. This output is essential for receiving assistance on this forum. Otherwise, your post will be moved to
You can do this from Live ISO. Format it as a code block by clicking the preformatted text button (</>), or put three tildes (~) above and below the output text.
