Hey there;
lately i face various minor problems that really annoys me at my daily use cause i always have to manually overwrite it on a daily basis that’s no big deal but it starts adding up with multiple issues, so i now address the first one here. First of i use a old installation of Garuda KDE Dragonized as my daily computer and never touched this recommended setting.
It’s about adjusting the monitor brightness, i first removed redshift as autostart, than i uninstall redshift completly and i now really don’t know which program keep adjusting my brightness. I only know it have something to do with a mini programm that calls “Nachtlicht” (as icon in the tray) in german which translate to something like “Nightlight” but that`s problem not the english name cause you often can’t translate 1:1. I have my monitor directly via hardware control on 30% and this mini app is always on 10% sometimes even on 5% and i always have to change the bar via this software back to 30% or i readjust it directly via my monitor controls. But even when i have set it on 30%via software it’s only active during the session and never survives a restart or even a inactivity lock screen (first of my monitor boots with 30% but after i log in and the program launches it’s again on max. 10%). How can i overwrite it or get rid of this mini-program i really don’t need it cause my monitor memorize the previous hardware settings and i have a monitor control as well. And my problem center around brightness not how warm or cold the light is like in some nightmodes and the issue happens every time and not only e.g. during night.
Thanks for the help!
Kernel: 6.14.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/vmlinuz-linux-zen root=/dev/mapper/vglinux-garuda
rw rootflags=subvol=@ quiet rd.udev.log_priority=3
vt.global_cursor_default=0 loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.3.4 tk: Qt v: N/A info: frameworks v: 6.12.0
Type: Desktop System: Gigabyte product: X570 AORUS ELITE v: -CF
Mobo: Gigabyte model: X570 AORUS ELITE v: x.x serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: F36
date: 01/04/2022
Info: model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2 gen: 2
desc: 6x512 KiB L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 4005 min/max: 550/4208 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 4005 2: 4005 3: 4005
4: 4005 5: 4005 6: 4005 7: 4005 8: 4005 9: 4005 10: 4005 11: 4005 12: 4005
bogomips: 86236
Device-1: Advanced Micro Devices [AMD/ATI] Navi 10 [Radeon RX 5600 OEM/5600
XT / 5700/5700 XT] vendor: XFX Pine driver: amdgpu v: kernel arch: RDNA-1
code: Navi-1x process: TSMC n7 (7nm) built: 2019-20 pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: HDMI-A-1 empty: DP-1,DP-2,DP-3
bus-ID: 0c:00.0 chip-ID: 1002:731f class-ID: 0300
gpu: amdgpu display-ID: 0
Monitor-1: HDMI-A-1 model: EIZO NANAO FS2333 serial: <filter> built: 2012
res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 96 gamma: 1.2
size: 510x287mm (20.08x11.3") diag: 585mm (23") ratio: 16:9 modes:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.0.3-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 5700 XT (radeonsi
navi10 LLVM 19.1.7 DRM 3.61 6.14.2-zen1-1-zen) device-ID: 1002:731f
API: Vulkan v: 1.4.309 layers: 14 device: 0 type: discrete-gpu name: AMD
Radeon RX 5700 XT (RADV NAVI10) driver: N/A device-ID: 1002:731f
Device-1: Advanced Micro Devices [AMD/ATI] Navi 10 HDMI Audio
bus-ID: 0c:00.1 chip-ID: 1002:ab38 class-ID: 0403
lanes: 16 bus-ID: 0e:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.14.2-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.1 status: active with: 1: pipewire-pulse
Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 05:00.0
IF: enp5s0 state: up speed: 100 Mbps duplex: full mac: <filter>
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 06:00.0
IF: wlp6s0 state: up mac: <filter>
IF-ID-1: wg0 state: unknown speed: N/A duplex: N/A mac: N/A
Info: services: NetworkManager, smbd, systemd-networkd,
systemd-timesyncd, wpa_supplicant
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-6.4:4 chip-ID: 8087:0032
rfk-block: hardware: no software: yes address: <filter> bt-v: 5.3 lmp-v: 12
Local Storage: total: 8.3 TiB used: 1.18 TiB (14.2%)
ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Samsung model: SSD 970 EVO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QEXE7 temp: 37.9 C
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung
fw-rev: 2B2QEXM7 temp: 46.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST4000VN006-3CW104
tech: HDD rpm: 5400 serial: <filter> fw-rev: SC60 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Crucial model: M4-CT128M4SSD2
tech: SSD serial: <filter> fw-rev: 040H scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WD10EZEX-08WN4A0 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 1A02 scheme: GPT
ID-6: /dev/sdd maj-min: 8:48 vendor: Western Digital
model: WD2002FAEX-007BA0 size: 1.82 TiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s tech: N/A serial: <filter> fw-rev: 1D05
scheme: MBR
ID-1: / raw-size: 120 GiB size: 120 GiB (100.00%) used: 77.67 GiB (64.7%)
fs: btrfs dev: /dev/dm-8 maj-min: 253:8 mapped: vglinux-garuda
ID-2: /boot raw-size: 512 MiB size: 512 MiB (100.00%)
used: 247.9 MiB (48.4%) fs: btrfs dev: /dev/nvme0n1p7 maj-min: 259:10
ID-3: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%)
used: 250.4 MiB (49.0%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:5
ID-4: /home raw-size: 120 GiB size: 120 GiB (100.00%)
used: 77.67 GiB (64.7%) fs: btrfs dev: /dev/dm-8 maj-min: 253:8
ID-5: /var/log raw-size: 120 GiB size: 120 GiB (100.00%)
ID-6: /var/tmp raw-size: 120 GiB size: 120 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.26 GiB used: 7.2 MiB (0.0%) priority: 100
System Temperatures: cpu: 47.1 C mobo: 32.0 C gpu: amdgpu temp: 52.0 C
mem: 52.0 C
Memory: total: 32 GiB available: 31.26 GiB used: 5.6 GiB (17.9%)
Processes: 466 Power: uptime: 4h 26m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.46 GiB services: org_kde_powerdevil,upowerd
Packages: pm: pacman pkgs: 2535 libs: 640 tools: octopi,pamac,paru,yay
Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: garuda-inxi default: fish
v: 4.0.1 running-in: yakuake inxi: 3.3.37
System install date: 2025-03-20
Last full system update: 2025-04-12 ↻
