Monitor blanking issue after changing video settings
So, ever since I switched over to Garuda linux as my daily driver early last year, I have had this aggrevating issue… I use a 4k monitor via a VESA certified displayport, and whenever I have the desktop resolution at full, the screen blanks out for a second or two at random intervals… It hasn’t been a big deal cuz when I set it to 2560x1440, I don’t have any such issues… Until yesturday…
I thought I might as well check to see if a recent update may have fixed the problem, so I switched to 4k, messed around a little bit… And then when it was clear nothing changed, I switched back to the other resolution… But this time it decided to bring the glitch with it… So now, I have to figure this out because my computer is barely usable. To add to this, it seems to have developed some new consistancies at this lower resolution. It blanks whenever I bring up that window menu through the top left corner, and it goes wild blanking when certain windows are maximized, esp Pamac for some bizarre reason. It still does it randomly too. But it won’t do it at all when certain applications like VLC are fullscreened… I have been searching everywhere for even a place to start figuring ou what is going on without much luck, and so after gaining a blistering headache from it all, I signed up here…
I have an AMD R9 390 GPU, and a Z-Edge 4k monitor. I also have an old 1440x900 Viewsonic via DVI as a secondary monitor that I mostly use for widgets so I can keep an eye on temps, activity, etc. at a glance. I am using the default Zen Kernel, and the KDE Plasma 6 Desktop Environment with the default Dragonized setup.
I know this isn’t a hardware issue because I do technically dual boot Windows (I only have a small partition of 10 for like 2 things.) and in spite of having it at full resolution and refresh rate, I have had zero blanking problems, wven after this expanded version started. It also doesn’t happen in X11 at my normal res (though still does in 4k)
I’ve tried messing more with the video settings lowering the DPI scaling to 100%, etc, but I’m genuinely at a loss… I even checked to make sure it hadn’t reset my prioritizing of the AMDGPU drivers over the Radeon ones through the GRUB menu, but no… So if anyone has any knowledge or can at least give me an idea of where to start, please let me know.
It could simply be the DP-cable. With a cheap DP-cable it happens often for me. It picks up electric disturbances very easily, like opening microwave door, turning on a CFL-light, etc, and monitor gets no signal for a second or two.
I feel like if it was merely the DP cable, it would be consistant regardless of settings and completely random… It might explain the way it functions on X11, blanking only on full 4k, but it doesn’t explain the issues on Wayland… I can literally deliberately trigger it by simply maximizing Pamac. And it does it every so often, even at the resolutions that run flawlessly on X11… I really want to keep using Wayland, but it’s just unusable right now, and all that changed was I changed the resolution to 4k, and then changed it back… That’s the only difference between it worki g flawlessly and bugging out… I’d try to reinstall Wayland, see if that fixes it, but it’s built into KDE, so that’s just gonna break everything…
Does it do the same on the other DP ports of the gpu? Have you tried the mesa-tkg-git driver?
The best thing to do is to start by posting your garuda-inxi. That way we would have all the information we need about your hardware, drivers and the exact model of the monitor. That makes it easier to help.
Furthermore, Linux is not Windows - just because something works on Windows doesn’t mean it will work on Linux.
You have an old R9 390 with 1x DisplayPort 1.2 - maybe Linux doesn’t like the fact that your unknown monitor model may have a different DP version set or that 4K doesn’t work properly for some other reason. And obviously it hasn’t worked for over a year…if there is a problem you fix it immediately and don’t wait until it gets worse btw…
Edit: Take a look on this:
This may not be the same, but it gets the idea across for your troubleshooting.
I only have one displayport on my GPU…
Sorry, been busy a few days, I will post that when I find the time. And thing is, it hasn’t gotten worse so to speak. It just has started happening on Wayland at lower resolutions. TBH I think it might be two seperate issues. I’ll check out that other post as well. Thank you.
On the monitor itself in its menu can you set the display port version on my lg the option is in menu → general an lets me pick from dp 1.0 on up
Are you on kde 6.1 turn off adaptive sync tell me if it does anything
I can’t find such an option in my monitor’s display settings…
Yes, I am, and I did that, and no change.
As for my inxi
Kernel: 6.9.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=d350dd15-d185-412d-b75a-6ce316958c35 rw rootflags=subvol=@
amdgpu.si_support=1 amdgpu.cik_support=1 radeon.si_support=0
radeon.cik_support=0 ibt=off
Desktop: KDE Plasma v: 6.1.0 tk: Qt v: N/A info: frameworks v: 6.3.0
Type: Desktop Mobo: ASUSTeK model: M5A97 R2.0 v: Rev 1.xx
UEFI: American Megatrends v: 2601 date: 03/24/2015
Info: model: AMD FX-6300 bits: 64 type: MCP arch: Piledriver level: v2
built: 2012-13 process: GF 32nm family: 0x15 (21) model-id: 2 stepping: 0
microcode: 0x6000852
Topology: cpus: 1x cores: 6 smt: <unsupported> cache: L1: 288 KiB
desc: d-6x16 KiB; i-3x64 KiB L2: 6 MiB desc: 3x2 MiB L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1894 high: 3793 min/max: 1400/3500 boost: enabled
scaling: driver: acpi-cpufreq governor: ondemand cores: 1: 1572 2: 1400
3: 1517 4: 1683 5: 1400 6: 3793 bogomips: 45513
Device-1: AMD Hawaii PRO [Radeon R9 290/390] vendor: Micro-Star MSI
driver: amdgpu v: kernel alternate: radeon arch: GCN-2 code: Sea Islands
process: GF/TSMC 16-28nm built: 2013-17 pcie: gen: 2 speed: 5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s ports: active: DP-1,DVI-D-1
empty: DVI-D-2,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 1002:67b1 class-ID: 0300
temp: 49.0 C
gpu: amdgpu d-rect: 2859x960 display-ID: 0
Monitor-1: DP-1 pos: primary,left res: 1707x960 size: N/A modes: N/A
Monitor-2: DVI-D-1 pos: right res: 1152x720 size: N/A modes: N/A
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.1.1-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon R9 390 Series (radeonsi
hawaii LLVM 17.0.6 DRM 3.57 6.9.5-zen1-1-zen) device-ID: 1002:67b1
API: Vulkan v: 1.3.279 layers: 13 device: 0 type: discrete-gpu name: AMD
Radeon R9 390 Series (RADV HAWAII) driver: mesa radv v: 24.1.1-arch1.1
device-ID: 1002:67b1 surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.1.1-arch1.1 (LLVM 17.0.6) device-ID: 10005:0000
Device-1: AMD SBx00 Azalia vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 00:14.2 chip-ID: 1002:4383 class-ID: 0403
Device-2: AMD Hawaii HDMI Audio [Radeon R9 290/290X / 390/390X]
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1
chip-ID: 1002:aac8 class-ID: 0403
Device-3: Corsair VOID PRO Wireless Gaming Headset
lanes: 1 mode: 1.1 bus-ID: 10-2:2 chip-ID: 1b1c:0a1a class-ID: 0300
API: ALSA v: k6.9.5-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.7 status: active with: 1: pipewire-pulse
vendor: ASUSTeK P8 series driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 02:00.0 chip-ID: 10ec:8168
IF-ID-1: pvpnksintrf1 state: unknown speed: N/A duplex: N/A mac: <filter>
Device-1: Broadcom BCM20702A0 Bluetooth 4.0 driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 7-2:2 chip-ID: 0a5c:21e8
rfk-block: hardware: no software: no address: <filter> bt-v: 4.0 lmp-v: 6
Local Storage: total: 2.73 TiB used: 2.4 TiB (87.8%)
model: WDS100T2B0A-00SM50 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 00WD
model: WDS100T2G0A-00JH30 size: 931.52 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 0000
scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital model: WDS100T2B0A
tech: SSD serial: <filter> fw-rev: 90WD scheme: GPT
ID-1: / raw-size: 773.3 GiB size: 773.3 GiB (100.00%)
used: 684.53 GiB (88.5%) fs: btrfs dev: /dev/sda4 maj-min: 8:4
used: 25.9 MiB (26.9%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 773.3 GiB size: 773.3 GiB (100.00%)
ID-4: /var/log raw-size: 773.3 GiB size: 773.3 GiB (100.00%)
ID-5: /var/tmp raw-size: 773.3 GiB size: 773.3 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.53 GiB used: 153.8 MiB (1.0%)
priority: 100 comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 6
System Temperatures: cpu: 37.0 C mobo: 30.0 C gpu: amdgpu temp: 49.0 C
Fan Speeds (rpm): cpu: 1383 fan-2: 0 fan-3: 1175 gpu: amdgpu fan: 1919
Power: 12v: N/A 5v: N/A 3.3v: 3.22 vbat: 3.29 gpu: amdgpu watts: 42.19
Memory: total: 16 GiB available: 15.53 GiB used: 2.62 GiB (16.9%)
Processes: 253 Power: uptime: 1m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.19 GiB services: org_kde_powerdevil,
Packages: 2191 pm: pacman pkgs: 2151 libs: 592 tools: paru pm: flatpak
pkgs: 40 Compilers: clang: 17.0.6 gcc: 14.1.1 Shell: garuda-inxi
default: Bash v: 5.2.26 running-in: konsole inxi: 3.3.34
System install date:     2023-07-12
Last full system update: 2024-06-20
Failed units:            fancontrol.service
Edit: I just noticed that it is listing the resolutions of my monitors wrong… That seems really bizarre… It seems to list them correctly on X11, so maybe that’s a hint?
Yes, use X11 and wait for upstream Nvidia fixes :slight_smile:
Nvidia fixes? But my card’s AMD. Am I missing something?
No, it looks like I need more sleep or coffee. :smiling_face:
I’m having the same problem. Whenever I switch 144hz my screen starts to blinking if there is a change on the screen. So right now I’m using at 120hz. 120hz more stable than 144hz but when I fullscreen a program it turns black then gets normal. I tested with different HDMI cables it still happening but noticed something that if I boot garuda iso there is no problem. I also use AMD and there is my garuda-inxi:
root=UUID=d52237ff-a7a0-4331-8886-9ee88dd36458 rw rootflags=subvol=@
quiet resume=UUID=cd40837e-8789-45da-9064-aa348baee28e loglevel=3 ibt=off
Mobo: ASUSTeK model: PRIME B550M-K v: Rev X.0x
UEFI: American Megatrends v: 2803 date: 04/28/2022
Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3674 high: 3700 min/max: 2200/4650 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3700 2: 3700
3: 3700 4: 3700 5: 3648 6: 3700 7: 3700 8: 3700 9: 3635 10: 3598 11: 3700
12: 3617 bogomips: 88797
Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT] vendor: ASUSTeK
active: HDMI-A-1 empty: DP-1, DP-2, DP-3, Writeback-1 bus-ID: 0d:00.0
chip-ID: 1002:73bf class-ID: 0300
gpu: amdgpu display-ID: 0
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6800 (radeonsi navi21
LLVM 17.0.6 DRM 3.57 6.9.5-zen1-1-zen) device-ID: 1002:73bf
Radeon RX 6800 (RADV NAVI21) driver: mesa radv v: 24.1.1-arch1.1
device-ID: 1002:73bf surfaces: xcb,xlib,wayland device: 1 type: cpu
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0d:00.1 chip-ID: 1002:ab28
bus-ID: 0f:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: ASUSTek ROG DELTA S driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4:2
chip-ID: 0b05:1943 class-ID: 0300
speed: 5 GT/s lanes: 1 bus-ID: 06:00.0 chip-ID: 8086:2723 class-ID: 0280
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 0a:00.0 chip-ID: 10ec:8168
IF: enp10s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8:5 chip-ID: 8087:0029
Local Storage: total: 2.3 TiB used: 104.09 GiB (4.4%)
model: WD Blue SN570 500GB size: 465.76 GiB block-size: physical: 512 B
fw-rev: 234110WD temp: 39.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2UB102
ID-3: /dev/sdb maj-min: 8:16 vendor: SanDisk model: Cruzer Blade
size: 29.25 GiB block-size: physical: 512 B logical: 512 B type: USB
fw-rev: 1.00 scheme: GPT
ID-1: / raw-size: 448.39 GiB size: 448.39 GiB (100.00%)
used: 104.09 GiB (23.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 448.39 GiB size: 448.39 GiB (100.00%)
ID-4: /var/log raw-size: 448.39 GiB size: 448.39 GiB (100.00%)
ID-5: /var/tmp raw-size: 448.39 GiB size: 448.39 GiB (100.00%)
ID-2: swap-2 type: partition size: 17.08 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 46.5 C mobo: N/A gpu: amdgpu temp: 46.0 C
mem: 46.0 C
Memory: total: 16 GiB available: 15.53 GiB used: 3.02 GiB (19.5%)
Processes: 353 Power: uptime: 0m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.2 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2009 libs: 583 tools: octopi,paru Compilers:
clang: 17.0.6 gcc: 14.1.1 Shell: garuda-inxi default: fish v: 3.7.1
System install date:     2024-06-22
Last full system update: 2024-06-22
That is similar though not quite the same. Also, I figured out the weird nonmatching resolution. It seems to be referencing the DPI scaling for the res, so back to square one…
I feel like a complete fool rn… I blew some compressed air into both ends of the cable and the sockets, and now it works flawlessly… It still does it in 4k but to a significantly reduced degree, so I’m fairly confident a deeper cleaning will fix the issue… Mind you, I dunno why none of my previous attempts to clean it fixed it but regardless, this did it… I am happy I figured it out.
Perhaps you might want to invest in a higher quality cable, as cabling causes far more issues than most would suspect.
