Can Moneydance be installed in Garuda?
if so, how is it done? Assume it is unoffiical software, not supported
Welcome to Garuda!
Moneydance is in the AUR so you can either use the GUI tool pamac (called add-remove software) and search for it and press install.
Or
paru -S moneydance
Remeber Garuda is still Arch! Anything in the Arch repos or AUR can still be installed here!
