Issue Description
After following the excelent guide from @FGD (one big thanks again!)
I notice that my touchpad gestures are not working as intended.
Screenshot of my libinput-gestures-qt
When doing 3 fingers right and 3 fingers left, it switches desktops like I would use 4 fingers.
Kernel: 6.14.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=4f3937b5-6c07-4580-8883-8cef1f42d4f5 rw rootflags=subvol=@
cryptdevice=UUID=3d769afd-2828-481c-8e36-8aba99397d5a:luks-3d769afd-2828-481c-8e36-8aba99397d5a
root=/dev/mapper/luks-3d769afd-2828-481c-8e36-8aba99397d5a
resume=UUID=4f3937b5-6c07-4580-8883-8cef1f42d4f5 resume_offset=57068631
wm: kwin_wayland tools: avail: i3lock vt: 1 dm: SDDM Distro: Garuda
Type: Laptop System: Framework product: Laptop v: AB
Mobo: Framework model: FRANBMCP0B v: AB serial: <superuser required>
part-nu: FRANBMCP0B uuid: <superuser required> UEFI: INSYDE v: 03.07
date: 12/14/2021
ID-1: BAT1 charge: 48.0 Wh (100.0%) condition: 48.0/55.0 Wh (87.3%)
volts: 17.3 min: 15.4 model: NVT Framewo type: Li-ion serial: <filter>
status: not charging
Info: model: 11th Gen Intel Core i7-1165G7 bits: 64 type: MT MCP
microcode: 0xB8
smt: enabled cache: L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB
desc: 4x1.2 MiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 3831 min/max: 400/4700 scaling: driver: intel_pstate
governor: powersave cores: 1: 3831 2: 3831 3: 3831 4: 3831 5: 3831 6: 3831
7: 3831 8: 3831 bogomips: 44851
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Framework
built: 2020-21 ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4
bus-ID: 00:02.0 chip-ID: 8086:9a49 class-ID: 0300
Device-2: Realtek Laptop Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-7:2 chip-ID: 0bda:5634
Monitor-1: eDP-1 model: BOE Display 0x095f built: 2019 res:
mode: 2256x1504 hz: 60 scale: 135% (1.35) to: 1671x1114 dpi: 201 gamma: 1.2
size: 285x190mm (11.22x7.48") diag: 343mm (13.5") ratio: 3:2
modes: 2256x1504
drv: iris x11: drv: iris
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.0.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Iris Xe Graphics (TGL
GT2) device-ID: 8086:9a49 memory: 15.2 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.4.309 layers: 9 device: 0 type: integrated-gpu name: Intel
Iris Xe Graphics (TGL GT2) driver: mesa intel v: 25.0.4-arch1.1
device-ID: 8086:9a49 surfaces: xcb,xlib,wayland device: 1 type: cpu
name: llvmpipe (LLVM 19.1.7 256 bits) driver: mesa llvmpipe
v: 25.0.4-arch1.1 (LLVM 19.1.7) device-ID: 10005:0000
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Framework
bus-ID: 00:1f.3 chip-ID: 8086:a0c8 class-ID: 0403
API: ALSA v: k6.14.3-zen1-1-zen status: kernel-api tools: N/A
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: aa:00.0
IF: wlp170s0 state: up mac: <filter>
IF-ID-1: br-64316bb60675 state: down mac: <filter>
IF-ID-2: br-8f600333d6f8 state: down mac: <filter>
IF-ID-3: docker0 state: down mac: <filter>
IF-ID-4: virbr0 state: down mac: <filter>
IF-ID-5: virbr1 state: down mac: <filter>
IF-ID-6: virbr2 state: down mac: <filter>
wpa_supplicant
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 8087:0032
rfk-block: hardware: no software: yes address: <filter> bt-v: 5.3 lmp-v: 12
Local Storage: total: 931.51 GiB used: 386.28 GiB (41.5%)
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QGXA7 temp: 40.9 C
ID-1: / raw-size: 896.96 GiB size: 896.96 GiB (100.00%)
used: 386.28 GiB (43.1%) fs: btrfs dev: /dev/dm-0 maj-min: 253:0
mapped: luks-3d769afd-2828-481c-8e36-8aba99397d5a
used: 768 KiB (0.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 896.96 GiB size: 896.96 GiB (100.00%)
ID-4: /var/log raw-size: 896.96 GiB size: 896.96 GiB (100.00%)
ID-5: /var/tmp raw-size: 896.96 GiB size: 896.96 GiB (100.00%)
ID-1: swap-1 type: file size: 64 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
ID-2: swap-2 type: zram size: 31.13 GiB used: 1 MiB (0.0%) priority: 100
ID-3: swap-3 type: partition size: 34.25 GiB used: 0 KiB (0.0%)
priority: -3 dev: /dev/dm-1 maj-min: 253:1
mapped: luks-a59fcb28-cd12-4a13-abcf-1ad9ee0585a5
System Temperatures: cpu: 53.0 C mobo: N/A
Fan Speeds (rpm): cpu: 3461
Memory: total: 32 GiB note: est. available: 31.13 GiB used: 7.59 GiB (24.4%)
Processes: 354 Power: uptime: 44m states: freeze,mem,disk suspend: s2idle
suspend, test_resume image: 12.41 GiB services: org_kde_powerdevil,
power-profiles-daemon, thermald, upowerd Init: systemd v: 257
Packages: pm: pacman pkgs: 2325 libs: 509 tools: octopi,pamac,paru,yay
Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: garuda-inxi default: fish
System install date: 2022-05-10
Last full system update: 2025-04-24 ↻
1/2 Solution
After thinking and researching, I found the ~/.config/libinput-gestures.conf
file.
So I created a copy ~/.config/libinput-gestures.conf.bak
Now I deleted the 3 finger gestures in the gui and re-added them.
Running a diff:
diff ~/.config/libinput-gestures.conf.bak ~/.config/libinput-gestures.conf
19,20d18
< gesture swipe right 3 xdotool key alt+Left
< gesture swipe left 3 xdotool key alt+Right
21a20,21
Hmmmm. nothing has really changed, only the position of the config lines.
Before the migration I used X11, now wayland.
Holdup. What do I see there? xdotool
? even after deleting and adding them again?
This should be ydotool
Editing the file by hand, replacing xdotool
with ydotool
Restarting the service with:
systemctl --user restart libinput-gestures.service
and for good measure:
libinput-gestures-setup restart
. . . Still not working, WHY?!
Testing:
sleep 10 && ydotool key alt+Left
Switching to browser, nothing happens.
Grrr!
ydotool key --help
See `/usr/include/linux/input-event-codes.h' for available key codes (KEY_*).
Finding:
#define KEY_LEFTALT 56
#define KEY_LEFT 105
#define KEY_RIGHT 106
Lets try:
sleep 3 && ydotool key 56:1 105:1 105:0 56:0
Hey it works!
So now config:
gesture swipe left 3 ydotool key 56:1 106:1 106:0 56:0
gesture swipe right 3 ydotool key 56:1 105:1 105:0 56:0
restart:
And now I can use my back alt+left
gesture again but
alt+right
swipe switches desktop, whhhhhyyyyyy
