A few updates in and I don’t have the lovely little boarder that came initially upon setting up ):
I do remember the update saying snapper was newer than kwin but I probably should have highlighted that too
root=UUID=a8244d02-6075-4ad0-99c3-02245ebed019 rw rootflags=subvol=@
resume=UUID=a16d9524-e554-439d-9669-084d8e183f84 loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.3.4 tk: Qt v: N/A info: frameworks v: 6.12.0
Type: Laptop System: HP product: HP ENVY Laptop 17-ce1xxx
Mobo: HP model: 86B0 v: 84.16 serial: <superuser required>
part-nu: 6UX02AV uuid: <superuser required> UEFI: Insyde v: F.07
date: 08/06/2020
ID-1: BAT0 charge: 30.6 Wh (81.8%) condition: 37.4/37.4 Wh (100.0%)
volts: 11.5 min: 11.6 model: 333-1B-35-A LK03052XL type: Li-ion
Info: model: Intel Core i7-10510U bits: 64 type: MT MCP
stepping: 0xC (12) microcode: 0xFC
Speed (MHz): avg: 400 min/max: 400/4900 scaling: driver: intel_pstate
governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
8: 400 bogomips: 36799
Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: Hewlett-Packard
ports: active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 00:02.0
Device-2: NVIDIA GP108M [GeForce MX250] vendor: Hewlett-Packard
driver: nouveau v: kernel non-free: 550/565.xx+ status: current (as of
2025-01; EOL~2026-12-xx) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-2021 pcie: gen: 1 speed: 2.5 GT/s lanes: 4 link-max: gen: 3
speed: 8 GT/s bus-ID: 02:00.0 chip-ID: 10de:1d13 class-ID: 0302
temp: 41.0 C
alternate: fbdev,intel,nv,vesa dri: iris,nouveau gpu: i915 display-ID: 0
Monitor-1: eDP-1 model: ChiMei InnoLux 0x176c built: 2018 res:
mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 128 gamma: 1.2
size: 381x214mm (15x8.43") diag: 437mm (17.2") ratio: 16:9
modes: 1920x1080
API: EGL v: 1.5 hw: drv: intel iris drv: nvidia nouveau platforms:
device: 0 drv: nouveau device: 1 drv: iris device: 2 drv: swrast gbm:
drv: nouveau surfaceless: drv: nouveau wayland: drv: iris x11: drv: iris
API: OpenGL v: 4.6 compat-v: 4.3 vendor: intel mesa v: 25.0.3-arch1.1
device-ID: 8086:9b41 memory: 7.48 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.4.309 layers: 5 device: 0 type: integrated-gpu name: Intel
UHD Graphics (CML GT2) driver: N/A device-ID: 8086:9b41
Device-1: Intel Comet Lake PCH-LP cAVS vendor: Hewlett-Packard
driver: sof-audio-pci-intel-cnl alternate: snd_hda_intel, snd_soc_avs,
snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:02c8 class-ID: 0401
API: ALSA v: k6.13.8-zen1-1-zen status: kernel-api with: aoss
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:4
v: 3.0 port: 5060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: class-ID: 0104
Local Storage: total: 953.87 GiB used: 28.51 GiB (3.0%)
model: MZVLQ1T0HALB-000H1 size: 953.87 GiB block-size: physical: 512 B
fw-rev: HPS2NFXV temp: 17.9 C scheme: GPT
ID-1: / raw-size: 936.73 GiB size: 936.73 GiB (100.00%)
used: 28.51 GiB (3.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 936.73 GiB size: 936.73 GiB (100.00%)
ID-4: /var/log raw-size: 936.73 GiB size: 936.73 GiB (100.00%)
ID-5: /var/tmp raw-size: 936.73 GiB size: 936.73 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.31 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 16.85 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 45.0 C pch: 43.0 C mobo: N/A gpu: nouveau
temp: 41.0 C
Memory: total: 16 GiB note: est. available: 15.31 GiB used: 3.87 GiB (25.2%)
Processes: 334 Power: uptime: 13m states: freeze,mem,disk suspend: s2idle
image: 6.11 GiB services: org_kde_powerdevil, power-profiles-daemon,
Packages: pm: pacman pkgs: 1476 libs: 384 tools: octopi,paru pm: flatpak
pkgs: 0 Compilers: gcc: 14.2.1 Shell: garuda-inxi default: fish v: 4.0.1
System install date: 2025-03-28
Last full system update: 2025-04-11 ↻
