Modify Contextual Menu
Hello Garuda users, I want to know how i can change the contextual menu.
When i chose a file with a right click i want to add some entry for secure remove.
So i want to add an entry named 'Sremove' who launch the srm command to delete the file
Any one can help me ?
Thank's
Kernel: 6.2.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=eaf68fbc-1cea-4b35-8b45-d5afbd38a4d0 rw [email protected]
Desktop: KDE Plasma v: 5.27.3 tk: Qt v: 5.15.8 wm: kwin_x11 dm: SDDM
Type: Laptop System: LENOVO product: 20YG006MFR v: ThinkPad E15 Gen 3
Mobo: LENOVO model: 20YG006MFR serial: <filter> UEFI: LENOVO
v: R1OET27W (1.06 ) date: 05/17/2021
ID-1: BAT0 charge: 16.0 Wh (31.4%) condition: 50.9/57.0 Wh (89.3%)
volts: 10.9 min: 11.5 model: Celxpert 5B11C732 type: Li-poly
serial: <filter> status: discharging cycles: 148
Info: model: AMD Ryzen 7 5700U with Radeon Graphics socket: FP6 bits: 64
type: MT MCP arch: Zen 2 gen: 3 level: v3 note: check built: 2020-22
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x68 (104) stepping: 1
microcode: 0x8608103
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1450 high: 1800 min/max: 1400/4370 boost: enabled
base/boost: 1800/4350 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.2 V ext-clock: 100 MHz cores: 1: 1800 2: 1400 3: 1400 4: 1400
5: 1400 6: 1400 7: 1400 8: 1400 9: 1400 10: 1400 11: 1400 12: 1400
13: 1400 14: 1400 15: 1400 16: 1800 bogomips: 57498
Device-1: AMD Lucienne vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5
lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1
empty: DP-1,HDMI-A-1 bus-ID: 04:00.0 chip-ID: 1002:164c class-ID: 0300
temp: 45.0 C
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-3:3 chip-ID: 04f2:b6be class-ID: fe01 serial: <filter>
Monitor-1: eDP-1 mapped: eDP model: AU Optronics 0xe48d built: 2019
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
API: OpenGL v: 4.6 Mesa 23.0.1 renderer: AMD Radeon Graphics (renoir LLVM
15.0.7 DRM 3.49 6.2.9-zen1-1-zen) direct-render: Yes
link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.1 chip-ID: 1002:1637
snd_sof_amd_rembrandt pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max:
gen: 4 speed: 16 GT/s bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
speed: 16 GT/s bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.2.9-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.67 status: n/a (root, process) with:
port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: Lenovo driver: rtw_8822ce v: N/A modules: rtw88_8822ce pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:c822
bus-ID: 2-4:3 chip-ID: 0bda:c123 class-ID: e001 serial: <filter>
Report: hciconfig ID: hci0 rfk-id: 1 state: down
address: <filter>
Info: acl-mtu: 1021:6 sco-mtu: 255:12 link-policy: rswitch hold sniff park
link-mode: peripheral accept
Local Storage: total: 480.69 GiB used: 168.21 GiB (35.0%)
model: MZALQ512HBLU-00BL1 size: 476.94 GiB block-size: physical: 512 B
rev: 7L1QFXM7 temp: 28.9 C scheme: GPT
SMART: yes health: PASSED on: 10d 17h cycles: 1,972
read-units: 11,669,339 [5.97 TB] written-units: 10,835,951 [5.54 TB]
ID-2: /dev/sda maj-min: 8:0 type: USB model: General size: 3.75 GiB
block-size: physical: 512 B logical: 512 B type: N/A serial: <filter>
rev: 5.00 scheme: MBR
ID-1: / raw-size: 195.31 GiB size: 195.31 GiB (100.00%)
used: 168.18 GiB (86.1%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p5
maj-min: 259:5
used: 29.7 MiB (11.6%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 195.31 GiB size: 195.31 GiB (100.00%)
maj-min: 259:5
ID-4: /var/log raw-size: 195.31 GiB size: 195.31 GiB (100.00%)
maj-min: 259:5
ID-5: /var/tmp raw-size: 195.31 GiB size: 195.31 GiB (100.00%)
maj-min: 259:5
ID-1: swap-1 type: zram size: 38.01 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 51.0 C mobo: N/A gpu: amdgpu temp: 46.0 C
Fan Speeds (RPM): fan-1: 0 fan-2: 0
Processes: 386 Uptime: 30m wakeups: 1 Memory: 38.01 GiB
used: 6.6 GiB (17.4%) Init: systemd v: 253 default: graphical
pkgs: 5460 libs: 425 tools: octopi,pamac,paru pm: rpm pkgs: 0
inxi: 3.3.26
System install date:     2023-03-08
Last full system update: 2023-04-03
Windows dual boot:       Yes
Refusing to post the output of the required "garuda-inxi" on a help request will likely result in you not receiving any help from the Garuda team. A failure to provide your system specs may also result in your thread being closed without notice, (as without this information providing assistance is often next to impossible).
Before opening a new help request, please search the Arch and Garuda Wiki's, and read any relevant sections related to your issue. Also, thoroughly search any error messages in the forum's search engine and on the web. For in depth information on how to search for answers to Linux issues effectively read the tips on the Garuda Wiki:
