[Moderate Issue] Nohang causes GPU to not wake from suspend
Hello, I've been having an issue where Nohang causes my AMD Rx580 gpu to not wake from suspend when my system is out of memory.
How to reproduce:
On a Garuda install
  1. Install Mprime
  2. Select test #3 (large FFTs) (simulates a low memory condition)
  3. Suspend system
  4. Wake system up and observe that your GPU is not working anymore
  5. Hard reset system
How to prevent:
  1. Disable nohang (systemctl disable nohang)
  2. Repeat Large FFT test
  3. Upon waking from suspend, note that your system wakes up fine
Update: it seems as though Nohang has been replaced with systemd-oomd. I would recommend not using Nohang anymore.
  Kernel: 6.0.1-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    root=UUID=94295869-60a8-437b-96c1-fe11373a43f4 rw rootflags=subvol=@
    sysrq_always_enabled=1
  Desktop: KDE Plasma v: 5.26.0 tk: Qt v: 5.15.6 info: latte-dock
    wm: kwin_wayland vt: 2 dm: SDDM Distro: Garuda Linux base: Arch Linux
  Type: Desktop Mobo: ASUSTeK model: PRIME X570-PRO v: Rev X.0x
    serial: <superuser required> UEFI: American Megatrends v: 4403
    date: 04/27/2022
  Device-1: hidpp_battery_0 model: Logitech Wireless Touch Keyboard K400
  Info: model: AMD Ryzen 5 3600X bits: 64 type: MT MCP arch: Zen 2 gen: 3
    L3: 32 MiB desc: 2x16 MiB
  Speed (MHz): avg: 2199 high: 2200 min/max: 2200/4409 boost: enabled
    scaling: driver: acpi-cpufreq governor: powersave cores: 1: 2200 2: 2200
    3: 2200 4: 2200 5: 2200 6: 2200 7: 2199 8: 2199 9: 2200 10: 2200 11: 2200
    12: 2200 bogomips: 91198
    protection
    vendor: Micro-Star MSI driver: amdgpu v: kernel arch: GCN-4
    code: Arctic Islands process: GF 14nm built: 2016-20 pcie: gen: 1
    speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s ports:
    active: DP-1,DP-2,HDMI-A-2 empty: DVI-D-1,HDMI-A-1 bus-ID: 07:00.0
    chip-ID: 1002:67df class-ID: 0300 temp: 54.0 C
  Display: wayland server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.3
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu d-rect: 5120x3000
    display-ID: 0
  Monitor-1: DP-1 pos: primary,top-left res: 2560x1440 size: N/A modes: N/A
  Monitor-2: DP-2 pos: bottom-r res: 640x480 size: N/A modes: N/A
  Monitor-3: HDMI-A-2 pos: middle-c res: 1920x1080 size: N/A modes: N/A
  OpenGL: renderer: AMD Radeon RX 580 Series (polaris10 LLVM 14.0.6 DRM
    3.48 6.0.1-zen2-1-zen) v: 4.6 Mesa 22.2.1 direct render: Yes
    vendor: Micro-Star MSI driver: snd_hda_intel bus-ID: 3-1:2 v: kernel
    chip-ID: 046d:0a03 pcie: class-ID: 0102 gen: 1 speed: 2.5 GT/s lanes: 16
    link-max: gen: 3 speed: 8 GT/s bus-ID: 07:00.1 chip-ID: 1002:aaf0
    bus-ID: 09:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: Logitech Logitech USB Microphone type: USB
    driver: snd-usb-audio
  Sound API: ALSA v: k6.0.1-zen2-1-zen running: yes
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 03:00.0
    bus-ID: 1-6:2 chip-ID: 8087:0029 class-ID: e001
  Local Storage: total: 2.39 TiB used: 238.19 GiB (9.7%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT500MX500SSD1
    size: 465.76 GiB block-size: physical: 4096 B logical: 512 B
    speed: 6.0 Gb/s type: SSD serial: <filter> rev: 023 scheme: GPT
    model: WD2003FZEX-00SRLA0 size: 1.82 TiB block-size: physical: 4096 B
    rev: 1A01 scheme: GPT
  ID-3: /dev/sdc maj-min: 8:32 vendor: SanDisk model: SD9SN8W-128G-1006
    size: 119.24 GiB block-size: physical: 4096 B logical: 512 B
    speed: 6.0 Gb/s type: SSD serial: <filter> rev: 3006 scheme: GPT
  ID-1: / raw-size: 47.31 GiB size: 47.31 GiB (100.00%) used: 37.47 GiB
    (79.2%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
  ID-2: /boot/efi raw-size: 200 MiB size: 196.9 MiB (98.45%) used: 91 MiB
    (46.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
  ID-3: /home raw-size: 127.59 GiB size: 127.59 GiB (100.00%) used: 66.55
    GiB (52.2%) fs: btrfs dev: /dev/sda3 maj-min: 8:3
  ID-4: /var/log raw-size: 47.31 GiB size: 47.31 GiB (100.00%) used: 37.47
    GiB (79.2%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
  ID-5: /var/tmp raw-size: 47.31 GiB size: 47.31 GiB (100.00%) used: 37.47
  ID-2: swap-2 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/sdb1 maj-min: 8:17
  System Temperatures: cpu: 39.0 C mobo: 44.0 C gpu: amdgpu temp: 54.0 C
  Fan Speeds (RPM): fan-1: 0 fan-2: 1728 fan-3: 0 fan-4: 0 fan-5: 0
    fan-6: 0 fan-7: 0 gpu: amdgpu fan: 1406
  Processes: 407 Uptime: 1m wakeups: 2 Memory: 15.53 GiB used: 3.1 GiB
  (19.9%) Init: systemd v: 251 default: graphical tool: systemctl
  Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 2304 pm: pacman pkgs: 2278
  libs: 592 tools: gnome-software,octopi,pamac,paru,yay pm: flatpak pkgs: 26
  Shell: Bash v: 5.1.16 running-in: konsole inxi: 3.3.22
Garuda (2.6.8-1):
  System install date:     2022-01-06
  Last full system update: 2022-10-24
Edit: It seems that Systemd-oomd does the exact same thing
journalctl -b -1
Oct 24 02:57:28 RyzenCore kernel: CPU9 is up
Oct 24 02:57:28 RyzenCore kernel: smpboot: Booting Node 0 Processor 10 APIC 0xb
Oct 24 02:57:28 RyzenCore kernel: microcode: CPU10: patch_level=0x08701021
Oct 24 02:57:28 RyzenCore kernel: ACPI: \_PR_.C009: Found 2 idle states
Oct 24 02:57:28 RyzenCore kernel: CPU10 is up
Oct 24 02:57:28 RyzenCore kernel: smpboot: Booting Node 0 Processor 11 APIC 0xd
Oct 24 02:57:28 RyzenCore kernel: microcode: CPU11: patch_level=0x08701021
Oct 24 02:57:28 RyzenCore kernel: ACPI: \_PR_.C00B: Found 2 idle states
Oct 24 02:57:28 RyzenCore kernel: CPU11 is up
Oct 24 02:57:28 RyzenCore kernel: ACPI: PM: Waking up from system sleep state S3
Oct 24 02:57:28 RyzenCore kernel: ACPI: EC: interrupt unblocked
Oct 24 02:57:28 RyzenCore kernel: ACPI: EC: event unblocked
Oct 24 02:57:28 RyzenCore kernel: sd 2:0:0:0: [sda] Starting disk
Oct 24 02:57:28 RyzenCore kernel: sd 15:0:0:0: [sdc] Starting disk
Oct 24 02:57:28 RyzenCore kernel: sd 5:0:0:0: [sdb] Starting disk
Oct 24 02:57:28 RyzenCore kernel: serial 00:04: activated
Oct 24 02:57:28 RyzenCore kernel: ata5: SATA link down (SStatus 0 SControl 300)
Oct 24 02:57:28 RyzenCore kernel: ata4: SATA link down (SStatus 0 SControl 300)
Oct 24 02:57:28 RyzenCore kernel: ata10: SATA link down (SStatus 0 SControl 300)
Oct 24 02:57:28 RyzenCore kernel: ata9: SATA link down (SStatus 0 SControl 300)
Oct 24 02:57:28 RyzenCore kernel: ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Oct 24 02:57:28 RyzenCore kernel: ata16: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Oct 24 02:57:28 RyzenCore kernel: ata3.00: supports DRM functions and may not be fully accessible
Oct 24 02:57:28 RyzenCore kernel: ata3.00: configured for UDMA/133
Oct 24 02:57:28 RyzenCore kernel: ata16.00: configured for UDMA/100
Oct 24 02:57:28 RyzenCore kernel: [drm] PCIE GART of 256M enabled (table at 0x000000F400380000).
Oct 24 02:57:28 RyzenCore kernel: [drm:detect_link_and_local_sink [amdgpu]] *ERROR* No EDID read.
Oct 24 02:57:28 RyzenCore kernel: [drm] UVD and UVD ENC initialized successfully.
Oct 24 02:57:28 RyzenCore kernel: [drm] VCE initialized successfully.
Oct 24 02:57:28 RyzenCore kernel: igb 0000:03:00.0 enp3s0: igb: enp3s0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
Oct 24 02:57:28 RyzenCore kernel: ata6: found unknown device (class 0)
Oct 24 02:57:28 RyzenCore kernel: ata6: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Oct 24 02:57:28 RyzenCore kernel: ata6.00: configured for UDMA/133
Oct 24 02:57:28 RyzenCore kernel: OOM killer enabled.
Oct 24 02:57:28 RyzenCore kernel: Restarting tasks ... done.
Oct 24 02:57:28 RyzenCore kernel: random: crng reseeded on system resumption
Oct 24 02:57:28 RyzenCore kernel: amdgpu 0000:07:00.0: amdgpu: GPU fault detected: 147 0x01500402 for process  pid 0 thread  pid 0
Oct 24 02:57:28 RyzenCore kernel: amdgpu 0000:07:00.0: amdgpu:   VM_CONTEXT1_PROTECTION_FAULT_ADDR   0x0000022A
Oct 24 02:57:28 RyzenCore kernel: amdgpu 0000:07:00.0: amdgpu:   VM_CONTEXT1_PROTECTION_FAULT_STATUS 0x08004002
Oct 24 02:57:28 RyzenCore kernel: amdgpu 0000:07:00.0: amdgpu: VM fault (0x02, vmid 4, pasid 0) at page 554, read from 'TC1' (0x54433100) (4)
Oct 24 02:57:28 RyzenCore kernel: PM: suspend exit
Oct 24 02:57:28 RyzenCore kernel: audit: type=1130 audit(1666594647.339:163): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-suspend comm="syst>
Oct 24 02:57:28 RyzenCore kernel: audit: type=1131 audit(1666594647.339:164): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-suspend comm="syst>
Oct 24 02:57:27 RyzenCore audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/s>
Oct 24 02:57:27 RyzenCore audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/sy>
Oct 24 02:57:27 RyzenCore rtkit-daemon[1408]: The canary thread is apparently starving. Taking action.
Oct 24 02:57:28 RyzenCore ananicy-cpp[826]: [2022-10-24 02:57:27.182] [info] firefox(10660)
Oct 24 02:57:28 RyzenCore warp-svc[849]: 2022-10-24T06:57:27.347Z DEBUG warp::warp_service: Routes changed:
Oct 24 02:57:28 RyzenCore warp-svc[849]: DelNeighbour; Destination: 10.0.1.5;
Oct 24 02:57:28 RyzenCore warp-svc[849]: DelNeighbour; Destination: 224.0.0.22;
Oct 24 02:57:28 RyzenCore warp-svc[849]: DelNeighbour; Destination: 10.0.1.255;
Oct 24 02:57:28 RyzenCore warp-svc[849]: DelNeighbour; Destination: 239.0.0.250;
Oct 24 02:57:28 RyzenCore warp-svc[849]: DelNeighbour; Destination: 239.255.255.250;
Oct 24 02:57:28 RyzenCore warp-svc[849]: DelNeighbour; Destination: 10.0.1.2;
Oct 24 02:57:28 RyzenCore warp-svc[849]: DelNeighbour; Destination: 255.255.255.255;
Oct 24 02:57:28 RyzenCore warp-svc[849]: DelNeighbour; Destination: 224.0.0.251;
Oct 24 02:57:28 RyzenCore warp-svc[849]: DelNeighbour; Destination: 10.0.1.220;
Oct 24 02:57:28 RyzenCore warp-svc[849]: DelNeighbour; Destination: 10.0.1.6;
Oct 24 02:57:28 RyzenCore warp-svc[849]: DelNeighbour; Destination: 10.0.1.1;
Oct 24 02:57:28 RyzenCore warp-svc[849]: DelNeighbour; Destination: ff02::1:ff4e:ab68;
Oct 24 02:57:28 RyzenCore warp-svc[849]: DelNeighbour; Destination: ff02::c;
Oct 24 02:57:28 RyzenCore warp-svc[849]: DelNeighbour; Destination: ff02::2;
Oct 24 02:57:28 RyzenCore warp-svc[849]: DelNeighbour; Destination: ff02::16;
Oct 24 02:57:28 RyzenCore warp-svc[849]: DelNeighbour; Destination: ff02::fb;
Oct 24 02:57:28 RyzenCore warp-svc[849]: NewNeighbour; Destination: 10.0.1.2;
Oct 24 02:57:28 RyzenCore warp-svc[849]: NewNeighbour; Destination: 10.0.1.1;
Oct 24 02:57:28 RyzenCore warp-svc[849]: 2022-10-24T06:57:27.355Z ERROR watchdog: warp::watchdog: Watchdog reports hung daemon watchdog_name="main loop" hang>
Oct 24 02:57:27 RyzenCore systemd-sleep[10626]: System returned from sleep state.
Oct 24 02:57:27 RyzenCore rtkit-daemon[1408]: Demoting known real-time threads.
Oct 24 02:57:27 RyzenCore systemd[1]: systemd-suspend.service: Deactivated successfully.
Oct 24 02:57:27 RyzenCore rtkit-daemon[1408]: Successfully demoted thread 10173 of process 9987.
Oct 24 02:57:27 RyzenCore systemd[1]: Finished System Suspend.
Oct 24 02:57:27 RyzenCore rtkit-daemon[1408]: Demoted 1 threads.
Oct 24 02:57:27 RyzenCore systemd[1]: Stopped target Sleep.
Oct 24 02:57:27 RyzenCore ModemManager[916]: <info>  [sleep-monitor] system is resuming
Oct 24 02:57:27 RyzenCore systemd[1]: Reached target Suspend.
Oct 24 02:57:28 RyzenCore bluetoothd[830]: Controller resume with wake event 0x0
Oct 24 02:57:27 RyzenCore systemd[1]: Stopped target Suspend.
Oct 24 02:57:27 RyzenCore systemd-logind[846]: Operation 'sleep' finished.
Oct 24 02:57:28 RyzenCore audit[835]: ANOM_ABEND auid=4294967295 uid=0 gid=0 ses=4294967295 pid=835 comm="irqbalance" exe="/usr/bin/irqbalance" sig=11 res=1
Oct 24 02:57:28 RyzenCore kernel: irqbalance[835]: segfault at 2 ip 0000558a1b45dae4 sp 00007ffc9c625c50 error 4 in irqbalance[558a1b456000+b000]
Oct 24 02:57:28 RyzenCore kernel: Code: 0f 84 21 ff ff ff e9 fc fe ff ff 0f 1f 00 4d 85 e4 74 0b 41 80 3c 24 00 0f 85 08 07 00 00 48 8b b3 48 02 00 00 48 85 >
Oct 24 02:57:28 RyzenCore kernel: audit: type=1701 audit(1666594648.043:165): auid=4294967295 uid=0 gid=0 ses=4294967295 pid=835 comm="irqbalance" exe="/usr/>
Oct 24 02:57:28 RyzenCore audit: BPF prog-id=34 op=LOAD
Oct 24 02:57:28 RyzenCore kernel: audit: type=1334 audit(1666594648.067:166): prog-id=34 op=LOAD
Oct 24 02:57:28 RyzenCore kernel: audit: type=1334 audit(1666594648.068:167): prog-id=35 op=LOAD
Oct 24 02:57:28 RyzenCore kernel: audit: type=1334 audit(1666594648.068:168): prog-id=36 op=LOAD
Oct 24 02:57:28 RyzenCore audit: BPF prog-id=35 op=LOAD
Oct 24 02:57:28 RyzenCore audit: BPF prog-id=36 op=LOAD
Oct 24 02:57:28 RyzenCore kscreenlocker_greet[10588]: qt.qpa.wayland: Wayland does not support QWindow::requestActivate()
Oct 24 02:57:28 RyzenCore kernel: audit: type=1130 audit(1666594648.112:169): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump@1-10723-0>
Oct 24 02:57:28 RyzenCore audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump@1-10723-0 comm="systemd" exe="/usr/li>
Oct 24 02:57:28 RyzenCore NetworkManager[898]: <info>  [1666594648.1125] manager: sleep: wake requested (sleeping: yes  enabled: yes)
Oct 24 02:57:28 RyzenCore NetworkManager[898]: <info>  [1666594648.1126] device (enp3s0): state change: activated -> unmanaged (reason 'sleeping', sys-iface->
Oct 24 02:57:28 RyzenCore systemd[1]: Started Process Core Dump (PID 10723/UID 0).
Oct 24 02:57:28 RyzenCore NetworkManager[898]: <info>  [1666594648.1278] dhcp4 (enp3s0): canceled DHCP transaction
Oct 24 02:57:28 RyzenCore NetworkManager[898]: <info>  [1666594648.1279] dhcp4 (enp3s0): activation: beginning transaction (timeout in 45 seconds)
Oct 24 02:57:28 RyzenCore NetworkManager[898]: <info>  [1666594648.1288] dhcp4 (enp3s0): state changed no lease
Oct 24 02:57:28 RyzenCore systemd[1]: Starting autorandr execution hook...
Oct 24 02:57:28 RyzenCore ananicy-cpp[826]: [2022-10-24 02:57:28.317] [info] firefox(10720)
Oct 24 02:57:28 RyzenCore ananicy-cpp[826]: [2022-10-24 02:57:28.317] [info] firefox(10721)
Oct 24 02:57:28 RyzenCore ananicy-cpp[826]: [2022-10-24 02:57:28.318] [info] firefox(10720)
Oct 24 02:57:28 RyzenCore ananicy-cpp[826]: [2022-10-24 02:57:28.319] [info] firefox(10721)
Oct 24 02:57:28 RyzenCore ananicy-cpp[826]: [2022-10-24 02:57:28.320] [info] firefox(10746)
Oct 24 02:57:28 RyzenCore ananicy-cpp[826]: [2022-10-24 02:57:28.320] [info] firefox(10748)
Oct 24 02:57:28 RyzenCore ananicy-cpp[826]: [2022-10-24 02:57:28.321] [info] firefox(10749)
Oct 24 02:57:28 RyzenCore ananicy-cpp[826]: [2022-10-24 02:57:28.321] [info] firefox(10750)
Oct 24 02:57:28 RyzenCore ananicy-cpp[826]: [2022-10-24 02:57:28.321] [info] firefox(10751)
Oct 24 02:57:28 RyzenCore ananicy-cpp[826]: [2022-10-24 02:57:28.321] [info] firefox(10752)
Oct 24 02:57:28 RyzenCore ananicy-cpp[826]: [2022-10-24 02:57:28.322] [info] firefox(10748)
Oct 24 02:57:28 RyzenCore ananicy-cpp[826]: [2022-10-24 02:57:28.322] [info] firefox(10753)
Oct 24 02:57:28 RyzenCore ananicy-cpp[826]: [2022-10-24 02:57:28.322] [info] firefox(10749)
Oct 24 02:57:28 RyzenCore ananicy-cpp[826]: [2022-10-24 02:57:28.322] [info] firefox(10750)
Oct 24 02:57:28 RyzenCore ananicy-cpp[826]: [2022-10-24 02:57:28.322] [info] firefox(10752)
Oct 24 02:57:28 RyzenCore avahi-daemon[828]: Withdrawing address record for 10.0.1.14 on enp3s0.
Oct 24 02:57:28 RyzenCore avahi-daemon[828]: Leaving mDNS multicast group on interface enp3s0.IPv4 with address 10.0.1.14.
Oct 24 02:57:28 RyzenCore avahi-daemon[828]: Interface enp3s0.IPv4 no longer relevant for mDNS.
Oct 24 02:57:28 RyzenCore avahi-daemon[828]: Withdrawing address record for fe80::4dca:72c4:214e:ab68 on enp3s0.
Oct 24 02:57:28 RyzenCore avahi-daemon[828]: Leaving mDNS multicast group on interface enp3s0.IPv6 with address fe80::4dca:72c4:214e:ab68.
Oct 24 02:57:28 RyzenCore avahi-daemon[828]: Interface enp3s0.IPv6 no longer relevant for mDNS.
Oct 24 02:57:28 RyzenCore NetworkManager[898]: <info>  [1666594648.8267] manager: NetworkManager state is now CONNECTED_GLOBAL
Oct 24 02:57:28 RyzenCore NetworkManager[898]: <info>  [1666594648.8739] manager: NetworkManager state is now DISCONNECTED
Oct 24 02:57:28 RyzenCore NetworkManager[898]: <info>  [1666594648.8750] device (enp3s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface>
Oct 24 02:57:28 RyzenCore dbus-daemon[831]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispa>
Oct 24 02:57:29 RyzenCore systemd[1]: Starting Network Manager Script Dispatcher Service...
Oct 24 02:57:29 RyzenCore warp-svc[849]: 2022-10-24T06:57:29.112Z DEBUG warp::warp_service: Routes changed:
Oct 24 02:57:29 RyzenCore warp-svc[849]: DelNeighbour; Destination: 10.0.1.255;
Oct 24 02:57:29 RyzenCore warp-svc[849]: DelNeighbour; Destination: 239.255.255.250;
Oct 24 02:57:29 RyzenCore warp-svc[849]: DelNeighbour; Destination: 10.0.1.2;
Oct 24 02:57:29 RyzenCore warp-svc[849]: DelNeighbour; Destination: 255.255.255.255;
Oct 24 02:57:29 RyzenCore warp-svc[849]: DelNeighbour; Destination: 10.0.1.1;
Oct 24 02:57:29 RyzenCore warp-svc[849]: DelNeighbour; Destination: 224.0.0.22;
Oct 24 02:57:29 RyzenCore warp-svc[849]: DelNeighbour; Destination: ff02::16;
Oct 24 02:57:29 RyzenCore warp-svc[849]: 2022-10-24T06:57:29.113Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="network_changed"
Oct 24 02:57:29 RyzenCore warp-svc[849]: 2022-10-24T06:57:29.113Z DEBUG main_loop: warp::warp_service: Network change detected new_info=
Oct 24 02:57:29 RyzenCore warp-svc[849]:  old_info=IPv4: [enp3s0; 10.0.1.14; Ethernet]; DNS servers:;   10.0.1.1:53;
Oct 24 02:57:29 RyzenCore warp-svc[849]: 2022-10-24T06:57:29.113Z DEBUG main_loop: warp::warp_service: Reconnecting on network change
Oct 24 02:57:29 RyzenCore warp-svc[849]: 2022-10-24T06:57:29.113Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="status_change"
Oct 24 02:57:29 RyzenCore warp-svc[849]: 2022-10-24T06:57:29.113Z  INFO main_loop: warp::warp_service: WARP status: No network
Oct 24 02:57:29 RyzenCore warp-svc[849]: 2022-10-24T06:57:29.113Z DEBUG main_loop: warp::warp_service::ipc_handlers: Sending IPC status update: No network
Oct 24 02:57:29 RyzenCore warp-svc[849]: 2022-10-24T06:57:29.113Z DEBUG main_loop: warp::warp_service::ipc_handlers: Ipc Broadcast ResponseStatus: No network
Oct 24 02:57:29 RyzenCore dbus-daemon[831]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Oct 24 02:57:29 RyzenCore systemd[1]: Started Network Manager Script Dispatcher Service.
Oct 24 02:57:29 RyzenCore audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib>
Oct 24 02:57:29 RyzenCore kernel: audit: type=1130 audit(1666594649.128:170): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher >
Oct 24 02:57:29 RyzenCore NetworkManager[898]: <info>  [1666594649.1410] device (90:E1:7B:EF:8F:14): state change: unmanaged -> unavailable (reason 'managed'>
Oct 24 02:57:29 RyzenCore systemd-coredump[10744]: [🡕] Process 835 (irqbalance) of user 0 dumped core.
                                                   Module linux-vdso.so.1 with build-id 125bff577f2f2b43644c0ffc71adfbbaba5e11b6
                                                   Module libgpg-error.so.0 with build-id 470d76ceb1e53cb017f78c08936e9bafaeb4058b
                                                   Module liblz4.so.1 with build-id 84ea95d811dad359e94e100ebe6a746294ffe8a7
                                                   Module libzstd.so.1 with build-id ab54c2881f53ab314e134f3e08c76d504376dd5d
                                                   Module liblzma.so.5 with build-id 8a7334fec02fef6a82ff641a68b3e3200a44a702
                                                   Module libgcrypt.so.20 with build-id 8bf3cb884124273640de797a3e77d86c98434ea4
                                                   Module libcap.so.2 with build-id 9b38b08de708f439a9d0a4f8b9914151bc8d4b50
                                                   Module libgcc_s.so.1 with build-id 85db482c4585a328d95ec41124337a967bb24d8f
                                                   Module libpcre2-8.so.0 with build-id 917fc43d2c9f8539a3e324555c6c73886e8000a8
                                                   Module ld-linux-x86-64.so.2 with build-id 22bd7a2c03d8cfc05ef7092bfae5932223189bc1
                                                   Module libc.so.6 with build-id 1e94beb079e278ac4f2c8bce1f53091548ea1584
                                                   Module libm.so.6 with build-id 2c8ff1d29b255da5b7371efd5caf57444d622838
                                                   Module libsystemd.so.0 with build-id 63caa6a43422a3b88218d35317cf7611aa9f51ef
                                                   Module libnl-3.so.200 with build-id 46f3feeefe77129f1eeaa5f20ddd8561821f1924
                                                   Module libnl-genl-3.so.200 with build-id 4d1bfe8da05df88b7314c3f4b7e6547bd6b6b4f4
                                                   Module libnuma.so.1 with build-id ccbee658a05ac57d8be31340671552113245e85d
                                                   Module libglib-2.0.so.0 with build-id 3ef8f9239c93af698703b12c5c6738fe0129eaa7
                                                   Module libcap-ng.so.0 with build-id 707f9d3134a43306625e3dab8662899ea368ac91
                                                   Module irqbalance with build-id 4a9fe15ea5e5c2feb934f6ff9592c22d1b51a10c
                                                   Stack trace of thread 835:
                                                   #0  0x0000558a1b45dae4 n/a (irqbalance + 0xaae4)
                                                   #1  0x0000558a1b45e561 n/a (irqbalance + 0xb561)
                                                   #2  0x0000558a1b45e79b n/a (irqbalance + 0xb79b)
                                                   #3  0x0000558a1b46035c n/a (irqbalance + 0xd35c)
                                                   #4  0x00007f66de267042 n/a (libglib-2.0.so.0 + 0x56042)
                                                   #5  0x00007f66de26681b g_main_context_dispatch (libglib-2.0.so.0 + 0x5581b)
                                                   #6  0x00007f66de2bcec9 n/a (libglib-2.0.so.0 + 0xabec9)
                                                   #7  0x00007f66de265d7f g_main_loop_run (libglib-2.0.so.0 + 0x54d7f)
                                                   #8  0x0000558a1b45681d n/a (irqbalance + 0x381d)
                                                   #9  0x00007f66dde5e290 n/a (libc.so.6 + 0x23290)
                                                   #10 0x00007f66dde5e34a __libc_start_main (libc.so.6 + 0x2334a)
                                                   #11 0x0000558a1b457d55 n/a (irqbalance + 0x4d55)
                                                   Stack trace of thread 853:
                                                   #0  0x00007f66ddf360bf __poll (libc.so.6 + 0xfb0bf)
                                                   #1  0x00007f66de2bce2f n/a (libglib-2.0.so.0 + 0xabe2f)
                                                   #2  0x00007f66de2650d2 g_main_context_iteration (libglib-2.0.so.0 + 0x540d2)
                                                   #3  0x00007f66de265122 n/a (libglib-2.0.so.0 + 0x54122)
                                                   #4  0x00007f66de293c55 n/a (libglib-2.0.so.0 + 0x82c55)
                                                   #5  0x00007f66ddec18fd n/a (libc.so.6 + 0x868fd)
                                                   #6  0x00007f66ddf43a60 n/a (libc.so.6 + 0x108a60)
                                                   ELF object binary architecture: AMD x86-64
Oct 24 02:57:29 RyzenCore audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=irqbalance comm="systemd" exe="/usr/lib/systemd/systemd>
Oct 24 02:57:29 RyzenCore systemd[1]: irqbalance.service: Main process exited, code=dumped, status=11/SEGV
Oct 24 02:57:29 RyzenCore systemd[1]: irqbalance.service: Failed with result 'core-dump'.
Oct 24 02:57:29 RyzenCore systemd[1]: systemd-coredump@1-10723-0.service: Deactivated successfully.
Oct 24 02:57:29 RyzenCore audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump@1-10723-0 comm="systemd" exe="/usr/lib>
Oct 24 02:57:29 RyzenCore NetworkManager[898]: <info>  [1666594649.1690] device (90:E1:7B:EF:8F:14): state change: unavailable -> disconnected (reason 'none'>
Oct 24 02:57:29 RyzenCore audit: BPF prog-id=0 op=UNLOAD
Oct 24 02:57:29 RyzenCore autorandr[10791]: Failed to load profile 'default': Profile not found (line 1502)
Oct 24 02:57:29 RyzenCore autorandr[10791]: autorandr running as user jecks-thinkcentre (started from batch instance)
Oct 24 02:57:29 RyzenCore autorandr[10747]: Running autorandr as jecks-thinkcentre for display :1
Oct 24 02:57:29 RyzenCore systemd[1]: autorandr.service: Deactivated successfully.
Oct 24 02:57:29 RyzenCore systemd[1]: Finished autorandr execution hook.
Oct 24 02:57:29 RyzenCore audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=autorandr comm="systemd" exe="/usr/lib/systemd/systemd>
Oct 24 02:57:29 RyzenCore audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=autorandr comm="systemd" exe="/usr/lib/systemd/systemd">
Oct 24 02:57:29 RyzenCore ananicy-cpp[826]: [2022-10-24 02:57:29.828] [info] firefox(10796)
Oct 24 02:57:29 RyzenCore ananicy-cpp[826]: [2022-10-24 02:57:29.828] [info] firefox(10797)
Oct 24 02:57:29 RyzenCore ananicy-cpp[826]: [2022-10-24 02:57:29.829] [info] firefox(10796)
Oct 24 02:57:29 RyzenCore ananicy-cpp[826]: [2022-10-24 02:57:29.829] [info] firefox(10797)
Oct 24 02:57:30 RyzenCore ananicy-cpp[826]: [2022-10-24 02:57:30.330] [info] firefox(10803)
Oct 24 02:57:30 RyzenCore ananicy-cpp[826]: [2022-10-24 02:57:30.331] [info] firefox(10804)
Oct 24 02:57:30 RyzenCore ananicy-cpp[826]: [2022-10-24 02:57:30.331] [info] firefox(10805)
Oct 24 02:57:30 RyzenCore ananicy-cpp[826]: [2022-10-24 02:57:30.332] [info] firefox(10804)
Oct 24 02:57:30 RyzenCore ananicy-cpp[826]: [2022-10-24 02:57:30.333] [info] firefox(10803)
Oct 24 02:57:30 RyzenCore ananicy-cpp[826]: [2022-10-24 02:57:30.333] [info] firefox(10805)
Oct 24 02:57:30 RyzenCore ModemManager[916]: <info>  [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:01.2/0000:01:00.0/0000>
Oct 24 02:57:31 RyzenCore ananicy-cpp[826]: [2022-10-24 02:57:31.835] [info] firefox(10811)
Oct 24 02:57:31 RyzenCore ananicy-cpp[826]: [2022-10-24 02:57:31.836] [info] firefox(10812)
Oct 24 02:57:31 RyzenCore ananicy-cpp[826]: [2022-10-24 02:57:31.836] [info] firefox(10811)
Oct 24 02:57:32 RyzenCore ananicy-cpp[826]: [2022-10-24 02:57:32.337] [info] firefox(10813)
Oct 24 02:57:32 RyzenCore kernel: igb 0000:03:00.0 enp3s0: igb: enp3s0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
Oct 24 02:57:32 RyzenCore kernel: IPv6: ADDRCONF(NETDEV_CHANGE): enp3s0: link becomes ready
Oct 24 02:57:32 RyzenCore NetworkManager[898]: <info>  [1666594652.5379] device (enp3s0): carrier: link connected
Oct 24 02:57:32 RyzenCore NetworkManager[898]: <info>  [1666594652.5383] device (enp3s0): state change: unavailable -> disconnected (reason 'carrier-changed'>
Oct 24 02:57:32 RyzenCore NetworkManager[898]: <info>  [1666594652.5400] policy: auto-activating connection 'Wired connection 1' (819a02fa-a4f3-302a-93d0-b22>
Oct 24 02:57:32 RyzenCore NetworkManager[898]: <info>  [1666594652.5407] device (enp3s0): Activation: starting connection 'Wired connection 1' (819a02fa-a4f3>
Oct 24 02:57:32 RyzenCore NetworkManager[898]: <info>  [1666594652.5410] device (enp3s0): state change: disconnected -> prepare (reason 'none', sys-iface-sta>
Oct 24 02:57:32 RyzenCore NetworkManager[898]: <info>  [1666594652.5414] manager: NetworkManager state is now CONNECTING
Oct 24 02:57:32 RyzenCore NetworkManager[898]: <info>  [1666594652.5417] device (enp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'm>
Oct 24 02:57:32 RyzenCore NetworkManager[898]: <info>  [1666594652.5429] device (enp3s0): state change: config -> ip-config (reason 'none', sys-iface-state: >
Oct 24 02:57:32 RyzenCore NetworkManager[898]: <info>  [1666594652.5481] dhcp4 (enp3s0): activation: beginning transaction (timeout in 45 seconds)
Oct 24 02:57:32 RyzenCore avahi-daemon[828]: Joining mDNS multicast group on interface enp3s0.IPv6 with address fe80::4dca:72c4:214e:ab68.
Oct 24 02:57:32 RyzenCore avahi-daemon[828]: New relevant interface enp3s0.IPv6 for mDNS.
Oct 24 02:57:32 RyzenCore avahi-daemon[828]: Registering new address record for fe80::4dca:72c4:214e:ab68 on enp3s0.*.
Oct 24 02:57:32 RyzenCore NetworkManager[898]: <info>  [1666594652.5656] dhcp4 (enp3s0): error parsing DHCP option 15 (domain_name): 'localhost' is not a val>
Oct 24 02:57:32 RyzenCore NetworkManager[898]: <info>  [1666594652.5665] dhcp4 (enp3s0): state changed new lease, address=10.0.1.14
Oct 24 02:57:32 RyzenCore NetworkManager[898]: <info>  [1666594652.5672] policy: set 'Wired connection 1' (enp3s0) as default for IPv4 routing and DNS
Oct 24 02:57:32 RyzenCore avahi-daemon[828]: Joining mDNS multicast group on interface enp3s0.IPv4 with address 10.0.1.14.
Oct 24 02:57:32 RyzenCore avahi-daemon[828]: New relevant interface enp3s0.IPv4 for mDNS.
Oct 24 02:57:32 RyzenCore avahi-daemon[828]: Registering new address record for 10.0.1.14 on enp3s0.IPv4.
Oct 24 02:57:32 RyzenCore warp-svc[849]: 2022-10-24T06:57:32.597Z DEBUG warp::warp_service: Routes changed:
Oct 24 02:57:32 RyzenCore warp-svc[849]: NewNeighbour; Destination: 10.0.1.1;
Oct 24 02:57:32 RyzenCore NetworkManager[898]: <info>  [1666594652.5999] device (enp3s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state>
Oct 24 02:57:32 RyzenCore NetworkManager[898]: <info>  [1666594652.6033] device (enp3s0): state change: ip-check -> secondaries (reason 'none', sys-iface-sta>
Oct 24 02:57:32 RyzenCore NetworkManager[898]: <info>  [1666594652.6037] device (enp3s0): state change: secondaries -> activated (reason 'none', sys-iface-st>
Oct 24 02:57:32 RyzenCore NetworkManager[898]: <info>  [1666594652.6045] manager: NetworkManager state is now CONNECTED_SITE
Oct 24 02:57:32 RyzenCore NetworkManager[898]: <info>  [1666594652.6055] device (enp3s0): Activation: successful, device activated.
Oct 24 02:57:32 RyzenCore ananicy-cpp[826]: [2022-10-24 02:57:32.838] [info] NetworkManager(10816)
Oct 24 02:57:32 RyzenCore ananicy-cpp[826]: [2022-10-24 02:57:32.841] [info] NetworkManager(10816)
Oct 24 02:57:32 RyzenCore ananicy-cpp[826]: [2022-10-24 02:57:32.841] [info] NetworkManager(10817)
Oct 24 02:57:32 RyzenCore NetworkManager[898]: <info>  [1666594652.8745] manager: NetworkManager state is now CONNECTED_GLOBAL
Oct 24 02:57:33 RyzenCore warp-svc[849]: 2022-10-24T06:57:33.605Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="network_changed"
Oct 24 02:57:33 RyzenCore warp-svc[849]: 2022-10-24T06:57:33.605Z DEBUG main_loop: warp::warp_service: Network change detected new_info=IPv4: [enp3s0; 10.0.1>
Oct 24 02:57:33 RyzenCore warp-svc[849]:  old_info=
Oct 24 02:57:33 RyzenCore warp-svc[849]: 2022-10-24T06:57:33.605Z DEBUG main_loop: warp::warp_service: Reconnecting on network change
Oct 24 02:57:33 RyzenCore warp-svc[849]: 2022-10-24T06:57:33.605Z DEBUG main_loop: warp::warp_service: Entering main loop arm arm="status_change"
Oct 24 02:57:33 RyzenCore warp-svc[849]: 2022-10-24T06:57:33.605Z  INFO main_loop: warp::warp_service: WARP status: Disconnected
Oct 24 02:57:33 RyzenCore warp-svc[849]: 2022-10-24T06:57:33.605Z DEBUG main_loop: warp::warp_service::ipc_handlers: Sending IPC status update: Disconnected
Oct 24 02:57:33 RyzenCore warp-svc[849]: 2022-10-24T06:57:33.605Z DEBUG main_loop: warp::warp_service::ipc_handlers: Ipc Broadcast ResponseStatus: Disconnect>
Oct 24 02:57:37 RyzenCore ananicy-cpp[826]: [2022-10-24 02:57:37.344] [info] firefox(10828)
Oct 24 02:57:37 RyzenCore ananicy-cpp[826]: [2022-10-24 02:57:37.345] [info] firefox(10828)
Oct 24 02:57:38 RyzenCore warp-svc[849]: 2022-10-24T06:57:38.112Z DEBUG warp::warp_service: Routes changed:
Oct 24 02:57:38 RyzenCore warp-svc[849]: NewNeighbour; Destination: 10.0.1.6;
Oct 24 02:57:38 RyzenCore kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring gfx timeout, signaled seq=9497, emitted seq=9499
Oct 24 02:57:38 RyzenCore kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* Process information: process firefox pid 9987 thread firefox:cs0 pid 10007
Oct 24 02:57:38 RyzenCore kernel: amdgpu 0000:07:00.0: amdgpu: GPU reset begin!
Oct 24 02:57:39 RyzenCore kernel: amdgpu: cp is busy, skip halt cp
Oct 24 02:57:39 RyzenCore kernel: amdgpu: rlc is busy, skip halt rlc
Oct 24 02:57:39 RyzenCore kernel: amdgpu 0000:07:00.0: amdgpu: BACO reset
Oct 24 02:57:39 RyzenCore kernel: amdgpu 0000:07:00.0: amdgpu: GPU reset succeeded, trying to resume
Oct 24 02:57:39 RyzenCore kernel: [drm] PCIE GART of 256M enabled (table at 0x000000F400380000).
Oct 24 02:57:39 RyzenCore kernel: [drm] VRAM is lost due to GPU reset!
Oct 24 02:57:42 RyzenCore systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Oct 24 02:57:42 RyzenCore audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/>
Oct 24 02:57:42 RyzenCore kernel: kauditd_printk_skb: 7 callbacks suppressed
Oct 24 02:57:42 RyzenCore kernel: audit: type=1131 audit(1666594662.948:178): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher >
Oct 24 02:57:45 RyzenCore kernel: amdgpu 0000:07:00.0: amdgpu:
                                  last message was failed ret is 0
Oct 24 02:57:47 RyzenCore systemd-logind[846]: Power key pressed short.
