After last week’s update, my 3g stopped working saying it has a ppp problem, anyone knows why?
- Always post your
garuda-inxiwhenever asking for support on forum. - From your picture alone I can see you are in a partially upgraded state. Do a,
garuda-update
in your terminal and update your system.
Kernel: 6.5.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1 clocksource: tsc
available: hpet,acpi_pm parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen
root=UUID=b747150b-4498-4391-aab8-6873a0325b57 rw rootflags=subvol=@ quiet quiet
resume=UUID=1f23545f-f484-4172-a9b4-1e861a39654f loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.9 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: PRIME B450M-A v: Rev X.0x serial: <superuser required>
UEFI: American Megatrends v: 0219 date: 06/08/2018
Info: model: AMD Ryzen 3 2200G with Radeon Vega Graphics bits: 64 type: MCP arch: Zen level: v3
note: check built: 2017-19 process: GF 14nm family: 0x17 (23) model-id: 0x11 (17) stepping: 0
microcode: 0x810100B
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB
L2: 2 MiB desc: 4x512 KiB L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1999 high: 2851 min/max: 1600/3500 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 1585 2: 2039 3: 2851 4: 1524 bogomips: 27947
Device-1: AMD Raven Ridge [Radeon Vega Series / Radeon Mobile Series] vendor: ASUSTeK PRIME
driver: amdgpu v: kernel arch: GCN-5 code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3
speed: 8 GT/s lanes: 16 ports: active: DP-2 empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 08:00.0
chip-ID: 1002:15dd class-ID: 0300 temp: 39.0 C
Display: x11 server: X.Org v: 21.1.9 with: Xwayland v: 23.2.2 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi gpu: amdgpu
Screen-1: 0 s-res: 1360x768 s-dpi: 96 s-size: 359x203mm (14.13x7.99") s-diag: 412mm (16.24")
Monitor-1: DP-2 mapped: DisplayPort-1 model: LG (GoldStar) W1943 serial: <filter> built: 2010
res: 1360x768 hz: 60 dpi: 85 gamma: 1.2 size: 406x229mm (15.98x9.02") diag: 466mm (18.4")
ratio: 16:9 modes: max: 1360x768 min: 720x400
surfaceless: drv: radeonsi x11: drv: radeonsi inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.2.1-arch1.2 glx-v: 1.4
direct-render: yes renderer: AMD Radeon Vega 8 Graphics (raven LLVM 16.0.6 DRM 3.54
6.5.8-zen1-1-zen) device-ID: 1002:15dd memory: 1000 MiB unified: no
API: Vulkan v: 1.3.269 layers: 9 device: 0 type: integrated-gpu name: AMD Radeon Vega 8
Graphics (RADV RAVEN) driver: mesa radv v: 23.2.1-arch1.2 device-ID: 1002:15dd
surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe (LLVM 16.0.6 256 bits)
driver: mesa llvmpipe v: 23.2.1-arch1.2 (LLVM 16.0.6) device-ID: 10005:0000 surfaces: xcb,xlib
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: ASUSTeK PRIME B450M-A
driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 08:00.1
Device-2: AMD Family 17h/19h HD Audio vendor: ASUSTeK PRIME B450M-A driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 08:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.5.8-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.83 status: active with: 1: pipewire-pulse status: active
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK PRIME B450M-A
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 07:00.0
IF: enp7s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 447.13 GiB used: 33.52 GiB (7.5%)
SMART Message: Unable to run smartctl. Root privileges require
d.
ID-1: /dev/sda maj-min: 8:0 vendor: KLEVV model: NEO N400 SSD 480GB size: 447.13 GiB
fw-rev: 1_T5 scheme: GPT
ID-1: / raw-size: 120 GiB size: 120 GiB (100.00%) used: 14.3 GiB (11.9%) fs: btrfs dev: /dev/sda3
maj-min: 8:3
ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%) used: 576 KiB (0.1%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 120 GiB size: 120 GiB (100.00%) used: 19.22 GiB (16.0%) fs: btrfs
dev: /dev/sda4 maj-min: 8:4
ID-4: /var/log raw-size: 120 GiB size: 120 GiB (100.00%) used: 14.3 GiB (11.9%) fs: btrfs
dev: /dev/sda3 maj-min: 8:3
ID-5: /var/tmp raw-size: 120 GiB size: 120 GiB (100.00%) used: 14.3 GiB (11.9%) fs: btrfs
ID-1: swap-1 type: zram size: 6.7 GiB used: 94.5 MiB (1.4%) priority: 100 comp: zstd
avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 4 dev: /dev/zram0
ID-2: swap-2 type: partition size: 10 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda2
maj-min: 8:2
System Temperatures: cpu: 39.8 C mobo: N/A gpu: amdgpu temp: 39.0 C
Processes: 260 Uptime: 40m wakeups: 0 Memory: total: 8 GiB note: est. available: 6.7 GiB
used: 1.75 GiB (26.1%) Init: systemd v: 254 default: graphical tool: systemctl Compilers:
gcc: 13.2.1 Packages: 1366 pm: pacman pkgs: 1359 libs: 388 tools: octopi,paru pm: snap pkgs: 7
Client: shell wrapper v: 5.2.15-release inxi: 3.3.30
Garuda (2.6.17-1):
System install date: 2023-06-08
Last full system update: 2023-11-02 ↻
I updated the system and apps, and the problem is still the same
I move it from Issues & Assistance to Networking Support
Thanks, I didn’t notice there was a topic section for networks
Nov 03 14:29:26 Alan-PC NetworkManager[561]: <info> [1699010966.7058] device (ttyUSB2): state change: config -> failed (reason 'ppp-failed', sys-iface-state: 'managed')
Nov 03 14:29:26 Alan-PC NetworkManager[561]: <warn> [1699010966.7065] device (ttyUSB2): Activation: failed for connection 'MTN'
Nov 03 14:29:26 Alan-PC NetworkManager[561]: <info> [1699010966.7068] device (ttyUSB2): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
Nov 03 14:29:26 Alan-PC NetworkManager[561]: <info> [1699010966.7072] policy: auto-activating connection 'MTN' (19464760-fad4-4bf5-9842-d4fc16df8656)
Nov 03 14:29:26 Alan-PC NetworkManager[561]: <info> [1699010966.7078] device (ttyUSB2): Activation: starting connection 'MTN' (19464760-fad4-4bf5-9842-d4fc16df8656)
Nov 03 14:29:26 Alan-PC NetworkManager[561]: <info> [1699010966.7079] device (ttyUSB2): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Nov 03 14:29:27 Alan-PC NetworkManager[561]: <info> [1699010967.9125] device (ttyUSB2): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Nov 03 14:29:27 Alan-PC NetworkManager[561]: <info> [1699010967.9127] modem["ttyUSB2"]: using modem-specified IP timeout: 20 seconds
Nov 03 14:29:27 Alan-PC NetworkManager[561]: <info> [1699010967.9129] ppp-manager: starting PPP connection
Nov 03 14:29:27 Alan-PC NetworkManager[561]: <info> [1699010967.9156] ppp-manager: pppd started with pid 8199
Nov 03 14:29:27 Alan-PC pppd[8199]: Plugin /usr/lib/pppd/2.5.0/nm-pppd-plugin.so loaded.
Nov 03 14:29:27 Alan-PC NetworkManager[8199]: Plugin /usr/lib/pppd/2.5.0/nm-pppd-plugin.so loaded.
Nov 03 14:29:27 Alan-PC pppd[8199]: nm-ppp-plugin: initializing
Nov 03 14:29:27 Alan-PC pppd[8199]: Warning: couldn't open ppp database /run/pppd/pppd2.tdb
Nov 03 14:29:27 Alan-PC NetworkManager[8199]: Warning: couldn't open ppp database /run/pppd/pppd2.tdb
Nov 03 14:29:27 Alan-PC pppd[8199]: pppd 2.5.0 started by root, uid 0
Nov 03 14:29:27 Alan-PC pppd[8199]: nm-ppp-plugin: status 2 / phase 'serial connection'
Nov 03 14:29:27 Alan-PC pppd[8199]: Can't create lock file /run/pppd/lock/LCK..ttyUSB2: No such file or directory
Nov 03 14:29:27 Alan-PC NetworkManager[8199]: Can't create lock file /run/pppd/lock/LCK..ttyUSB2: No such file or directory
Nov 03 14:29:27 Alan-PC pppd[8199]: nm-ppp-plugin: status 0 / phase 'dead'
Nov 03 14:29:27 Alan-PC pppd[8199]: nm-ppp-plugin: cleaning up
Nov 03 14:29:27 Alan-PC pppd[8199]: Exit.
can this help figure the problem?
I can’t find the pppd file in run, is that the problem? And how can it be solved?
I tried to make the pppd folder and i copied the ppp database from another computer running garuda linux too, and it worked, but when i shut down the computer and turn it back on, the pppd file is all gone, please help
You can always set the file’s properties to immutable, then there is no possibility that the file you created can be deleted. You can easily research on how to set and remove the immutable flag if this idea interests you.
still the same issue, should I send the journal for when the computer restarts?
I would suggest downgrading Network Manager to the version in use when your connection was working properly, (if a NM upgrade occurred).
I tried to downgrade network packages, but the problem was from ppp package, the new ppp 2.5.0 package was the problem alongside with the other packages that were conflicted with it, so i reinstalled ppp2.4.9 and i had to remove the conflicted packages and everything is now working normally. Thanks for the help.
