I have a Dell Latitude 7390 with a Sierra Wireless EM7455 / Dell DE5811e Snapdragon X7 LTE modem. I also have a Mint Mobile SIM card installed. I used the System Settings/Connections control panel and added a new Mobile Broadband connection following the wizard. It works and I can successfully connect to Mint Mobile. A speed test via SpeedTest.net in Firefox showed I was getting about 65Mbps down and about 4.5Mbps up.
If I could leave it right here it seems everything is fine. The setup was easy and without incident, I got connected, and I can even browse with acceptable bandwidth. However, it seems to have a very hard time connecting, telling me is is connected and then immediately disconnected several times before it finally settles down and stays connected. Also, the connection takes about a minute or more, not the few seconds that it should. I also have frequent disconnects, sometimes so frequent it is like not having a connection at all.
When it is connected, everything looks good. The signal strength is strong, and the signal quality good. I just need it to be more stable to be usable, and also prevent it from eating my battery so fast with connection attempts.
❯ mmcli --modem=any
General | path: /org/freedesktop/ModemManager1/Modem/0
| device id: 7b65f8ff9d4ff15a20fd6b7064c01bd262d8e931
Hardware | manufacturer: Sierra Wireless, Incorporated
| model: DW5811e Snapdragon™ X7 LTE
| firmware revision: SWI9X30C_02.24.03.00
| carrier config: default
| h/w revision: EM7455B
| supported: gsm-umts, lte
| current: gsm-umts, lte
| equipment id: 352733100762426
System | device: /sys/devices/pci0000:00/0000:00:14.0/usb2/2-2
| drivers: qcserial, cdc_mbim
| plugin: dell
| primary port: cdc-wdm0
| ports: cdc-wdm0 (mbim), ttyUSB0 (ignored), ttyUSB1 (ignored),
| ttyUSB2 (at), wwp0s20f0u2i12 (net)
Numbers | own: xxxxxxxxxxx (Edited out)
Status | lock: sim-pin2
| unlock retries: sim-pin2 (10)
| state: connected
| power state: on
| access tech: lte
| signal quality: 38% (cached)
Modes | supported: allowed: 3g; preferred: none
| allowed: 4g; preferred: none
| allowed: 3g, 4g; preferred: 4g
| allowed: 3g, 4g; preferred: 3g
| current: allowed: 3g, 4g; preferred: 4g
Bands | supported: utran-1, utran-3, utran-4, utran-5, utran-8, utran-2,
| eutran-1, eutran-2, eutran-3, eutran-4, eutran-5, eutran-7, eutran-8,
| eutran-12, eutran-13, eutran-20, eutran-25, eutran-26, eutran-29,
| eutran-41
| current: utran-1, utran-3, utran-4, utran-5, utran-8, utran-2,
| eutran-41
IP | supported: ipv4, ipv6, ipv4v6
3GPP | imei: xxxxxxxxxxxxxx (Edited out)
| enabled locks: fixed-dialing
| operator id: 310260
| operator name: Mint
| registration: home
| packet service state: attached
3GPP EPS | ue mode of operation: csps-2
SIM | primary sim path: /org/freedesktop/ModemManager1/SIM/0
| sim slot paths: slot 1: /org/freedesktop/ModemManager1/SIM/0 (active)
| slot 2: none
Bearer | paths: /org/freedesktop/ModemManager1/Bearer/0
Any help is appreciated. Feel free to ask for any additional information you need. Here is the required garuda-inxi
output:
❯ garuda-inxi
Kernel: 6.4.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=cd28c1a1-ce9c-46ca-a940-f08d8bd3849f rw rootflags=subvol=@
resume=UUID=931f2a2d-59cb-4704-8216-338f14645cb5 loglevel=3 ibt=off
Type: Laptop System: Dell product: Latitude 7390 v: N/A
Mobo: Dell model: 09386V v: A00 serial: <superuser required> UEFI: Dell
v: 1.32.0 date: 04/10/2023
ID-1: BAT0 charge: 40.0 Wh (93.2%) condition: 42.9/42.9 Wh (100.0%)
volts: 7.9 min: 7.4 model: LGC-LGC7.78 DELL 2X39G type: Li-ion
Info: model: Intel Core i7-8650U bits: 64 type: MT MCP arch: Coffee Lake
model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xF2
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1450 high: 2100 min/max: 400/4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 2100
4: 2100 5: 800 6: 800 7: 2100 8: 2100 bogomips: 33599
Device-1: Intel UHD Graphics 620 vendor: Dell driver: i915 v: kernel
empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:5917
Device-2: Microdia Integrated_Webcam_HD driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:2 chip-ID: 0c45:6717
class-ID: 0e02
Monitor-1: eDP-1 model: ChiMei InnoLux 0x1382 built: 2017 res: 1920x1080
hz: 60 dpi: 166 gamma: 1.2 size: 293x165mm (11.54x6.5") diag: 336mm (13.2")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 23.1.4 renderer: Mesa Intel UHD Graphics 620 (KBL
GT2) direct-render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_soc_avs bus-ID: 00:1f.3
API: ALSA v: k6.4.6-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.75 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I219-LM vendor: Dell driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15d7 class-ID: 0200
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:24fd
IF-ID-1: wwp0s20f0u2i12 state: unknown mac: <filter>
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:3 chip-ID: 8087:0a2b
Local Storage: total: 476.94 GiB used: 33.01 GiB (6.9%)
model: MZVLB512HAJQ-000H1 size: 476.94 GiB block-size: physical: 512 B
fw-rev: EXA73H1Q temp: 31.9 C scheme: GPT
ID-1: / raw-size: 459.59 GiB size: 459.59 GiB (100.00%)
used: 33.01 GiB (7.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 459.59 GiB size: 459.59 GiB (100.00%)
ID-4: /var/log raw-size: 459.59 GiB size: 459.59 GiB (100.00%)
ID-5: /var/tmp raw-size: 459.59 GiB size: 459.59 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.5 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 17.05 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 66.0 C pch: 60.0 C mobo: N/A
Processes: 255 Uptime: 41m wakeups: 9683 Memory: total: 16 GiB
available: 15.5 GiB used: 3.22 GiB (20.8%) Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 13.1.1 Packages:
pm: pacman pkgs: 1553 libs: 494 tools: octopi,paru Shell: Zsh v: 5.9
running-in: guake inxi: 3.3.28
System install date: 2023-07-12
Last full system update: 2023-07-26
