Not sure how this happened and honestly would not have noticed had it not been for me needing to connect Bluetooth headphones. Everything seems to be functioning, just missing gnome system settings app/window.
╭─reggie@garudaG in ~
╰─λ garuda-inxi
Kernel: 6.7.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=927d0085-95c1-4e99-aa40-693309747cdb rw rootflags=subvol=@
resume=UUID=4960071c-ede6-4da6-ac6a-a2823cfcbcf3 loglevel=3 ibt=off
Desktop: GNOME v: 45.4 tk: GTK v: 3.24.41 wm: gnome-shell
tools: gsd-screensaver-proxy avail: lxlock dm: GDM v: 45.0.1 Distro: Garuda
Type: Laptop System: Dell product: XPS 15 9570 v: N/A
Mobo: Dell model: 07GHH0 v: A00 serial: <superuser required> part-nu: 087C
uuid: <superuser required> UEFI: Dell v: 1.31.0 date: 03/13/2023
ID-1: BAT0 charge: 71.4 Wh (92.5%) condition: 77.2/97.0 Wh (79.6%)
volts: 11.9 min: 11.4 model: SMP DELL GPM0365 type: Li-ion serial: <filter>
Info: model: Intel Core i9-8950HK bits: 64 type: MT MCP arch: Coffee Lake
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF4
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 3852 high: 4401 min/max: 800/4800 scaling:
driver: intel_pstate governor: powersave cores: 1: 4401 2: 4400 3: 4204
4: 800 5: 3834 6: 4401 7: 4401 8: 3903 9: 3547 10: 4300 11: 4265 12: 3774
bogomips: 69597
ports: active: eDP-1 empty: DP-1,DP-2,DP-3 bus-ID: 00:02.0
chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] vendor: Dell
driver: nvidia v: 550.54.14 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2024-02; EOL~2026-12-xx) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-2021 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1c8c
class-ID: 0302
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-12:4
chip-ID: 0c45:671d class-ID: 0e02
compositor: gnome-shell driver: X: loaded: intel,nvidia
unloaded: modesetting,nouveau alternate: fbdev,nv,vesa dri: i965 gpu: i915
display-ID: :1 screens: 1
s-diag: 583mm (22.95")
Monitor-1: eDP-1 mapped: eDP1 model: Sharp 0x148d built: 2018
res: 1920x1080 hz: 60 dpi: 143 gamma: 1.2 size: 340x190mm (13.39x7.48")
diag: 395mm (15.5") ratio: 16:9 modes: 3840x2160
API: Vulkan v: 1.3.276 layers: 4 device: 0 type: discrete-gpu name: NVIDIA
GeForce GTX 1050 Ti with Max-Q Design driver: nvidia v: 550.54.14
device-ID: 10de:1c8c surfaces: xcb,xlib device: 1 type: integrated-gpu
name: Intel UHD Graphics 630 (CFL GT2) driver: mesa intel
v: 24.0.2-arch1.1 device-ID: 8086:3e9b surfaces: xcb,xlib device: 2
type: cpu name: llvmpipe (LLVM 16.0.6 256 bits) driver: mesa llvmpipe
v: 24.0.2-arch1.1 (LLVM 16.0.6) device-ID: 10005:0000 surfaces: xcb,xlib
API: ALSA v: k6.7.8-zen1-1-zen status: kernel-api tools: N/A
Server-2: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
vendor: Rivet Networks Killer Wireless-n/a/ac 1535 driver: ath10k_pci
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 3b:00.0
chip-ID: 168c:003e class-ID: 0280 temp: 27.0 C
IF: wlp59s0 state: up mac: <filter>
IF-ID-1: tailscale0 state: unknown speed: -1 duplex: full mac: N/A
IF-ID-3: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:2 chip-ID: 0cf3:e301
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 4.2
Local Storage: total: 953.87 GiB used: 306.75 GiB (32.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: PC401 NVMe 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 80007E00 temp: 34.9 C
ID-1: / raw-size: 919.48 GiB size: 919.48 GiB (100.00%)
used: 306.75 GiB (33.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 600 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 919.48 GiB size: 919.48 GiB (100.00%)
ID-4: /var/log raw-size: 919.48 GiB size: 919.48 GiB (100.00%)
ID-5: /var/tmp raw-size: 919.48 GiB size: 919.48 GiB (100.00%)
ID-1: swap-1 type: zram size: 30.99 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 34.09 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 65.0 C pch: 52.0 C mobo: N/A
Memory: total: 32 GiB note: est. available: 30.99 GiB used: 6.43 GiB (20.7%)
Processes: 374 Power: uptime: 7m states: freeze,mem,disk suspend: s2idle
suspend, test_resume image: 12.33 GiB services: gsd-power,upowerd
Packages: 1866 pm: pacman pkgs: 1810 libs: 557
tools: gnome-software,pamac,paru pm: flatpak pkgs: 56 Compilers: gcc: 13.2.1
Shell: garuda-inxi default: Bash v: 5.2.26 running-in: gnome-terminal
inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2023-09-22
Last full system update: 2024-03-04 ↻
