I’m very impressed by and enjoyed Garuda Linux which I’ve installed some time ago. It’s really well-designed system and easy to work with!
One thing bothers me unfortunately:
as I am Pole, I noticed there are not present any Polish spell-checker inside Garuda system built-in. Is there any way to fix it? Anybody helps?
Cheers.
@Sunda-Spirit
Thanks for the reply.
What I meant was just a system spell-checker (in Garuda itself) what is surprisingly empty by default. Of course I know there plenty of language-addons for the browsers, etc.
“I am a Pole” is a correct expression in the context of nationality. It means that someone is a Pole or a Polish woman. But your suggestion could be right as well. So both I guess.
Hey, thanks. I tested it by installing in terminal (“yay -S hunspell-pl”). But there is still an empty space in sys-settings (as you can see on screenshot here).
