Hello.
Kernel: 5.16.2-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=9440b6ff-b9e8-4d3a-89cf-6a2d5f4fe48a rw [email protected]
Type: Laptop System: Acer product: Nitro AN515-55 v: V2.06
Mobo: CML model: Stonic_CMS v: V2.06 serial: <superuser required>
UEFI: Insyde v: 2.06 date: 08/19/2021
ID-1: BAT1 charge: 57.2 Wh (100.0%) condition: 57.2/57.5 Wh (99.5%)
volts: 17.5 min: 15.4 model: LGC AP18E8M type: Li-ion serial: <filter>
status: Full
Info: model: Intel Core i5-10300H bits: 64 type: MT MCP arch: Comet Lake
family: 6 model-id: 0xA5 (165) stepping: 2 microcode: 0xEA
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 808 high: 845 min/max: 800/4500 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 819 4: 800
5: 800 6: 800 7: 800 8: 845 bogomips: 39999
Device-1: Intel CometLake-H GT2 [UHD Graphics]
vendor: Acer Incorporated ALI driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile]
vendor: Acer Incorporated ALI driver: nvidia v: 495.46
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1f95
Device-3: Quanta HD User Facing type: USB driver: uvcvideo bus-ID: 1-5:4
chip-ID: 0408:a061 class-ID: 0e02
loaded: modesetting,nvidia display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142
Device-1: Intel Comet Lake PCH cAVS vendor: Acer Incorporated ALI
Device-2: NVIDIA driver: snd_hda_intel v: kernel bus-ID: 01:00.1
chip-ID: 10de:10fa class-ID: 0403
Sound Server-1: ALSA v: k5.16.2-zen1-1-zen running: yes
Sound Server-2: PulseAudio v: 15.0 running: yes
Sound Server-3: PipeWire v: 0.3.44 running: yes
Device-2: Realtek vendor: Acer Incorporated ALI driver: r8169 v: kernel
port: 3000 bus-ID: 07:00.0 chip-ID: 10ec:2600 class-ID: 0200
bus-ID: 1-14:5 chip-ID: 8087:0026 class-ID: e001
Report: bt-adapter note: tool can't run ID: hci0 rfk-id: 0 state: down
bt-service: disabled rfk-block: hardware: no software: no address: N/A
Local Storage: total: 476.94 GiB used: 18.39 GiB (3.9%)
model: PC SN530 SDBPNPZ-512G-1014 size: 476.94 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: 21103900 temp: 31.9 C scheme: GPT
ID-1: / raw-size: 39.06 GiB size: 39.06 GiB (100.00%)
used: 18.33 GiB (46.9%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
used: 56.8 MiB (59.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 39.06 GiB size: 39.06 GiB (100.00%)
ID-4: /var/log raw-size: 39.06 GiB size: 39.06 GiB (100.00%)
ID-5: /var/tmp raw-size: 39.06 GiB size: 39.06 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.59 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 40.0 C pch: 41.0 C mobo: N/A
Processes: 262 Uptime: 10m wakeups: 1 Memory: 7.6 GiB
used: 2.91 GiB (38.3%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1669 lib: 501 Shell: fish
Garuda:
System install date: 2022-01-27
Last full system update: 2022-01-28
Using TLP: No
Hi, I have some problems with the control of my sound, when I wanted to download a package I had to remove something that should not. Can you tell me how to make the sound reappear on my taskbar and not work at all. Could you tell me how to resolve it please.
