Hey, so I was doing an update using the update alias earlier and for some reason my system took a crap and reloaded the desktop partway through. I tried updating again but ran into some problems. I then tried to restore an old snapshot. The snapshot seemingly worked at first but when booting into the system after restoring it, it said that there was an error in regards to the kernel and it needing to be loaded first. So I ended up booting into a live environment and using chroot to reinstall grub and install a new kernel. I am now currently back in the working system but there are no snapshots created automatically or manually. I see nothing under snapper within Btrfs assistant and clicking on new does nothing either. Also, not sure if this will help, but updating the system says something along the lines of snapper missing type I think. And updating grub outputs what seems like snapshots that I can't access or boot from.
sudo update-grub
[sudo] password for adamj:
Found theme: /usr/share/grub/themes/garuda-dr460nized/theme.txt
Found initrd image: /boot/intel-ucode.img /boot/initramfs-linux-zen.img
Found fallback initrd image(s) in /boot: intel-ucode.img initramfs-linux-zen-fallback.img
Found linux image: /boot/vmlinuz-linux-cachyos
Found initrd image: /boot/intel-ucode.img /boot/initramfs-linux-cachyos.img
Found fallback initrd image(s) in /boot: intel-ucode.img initramfs-linux-cachyos-fallback.img
grub-probe: error: cannot find a GRUB drive for /dev/sdc1. Check your device.map.
Found Windows Boot Manager on /dev/[email protected]/EFI/Microsoft/Boot/bootmgfw.efi
Adding boot menu entry for UEFI Firmware Settings ...
Detecting snapshots ...
Found snapshot: 2022-02-27 23:41:18 | [email protected]_234140482 | N/A | N/A |
Found snapshot: 2022-02-27 23:39:51 | [email protected]_234118553 | N/A | N/A |
Found snapshot: 2022-02-27 23:38:00 | [email protected]_233951712 | N/A | N/A |
Found snapshot: 2022-02-27 20:28:31 | [email protected]_234140482/.snapshots/380/snapshot | post | bubblewrap desktop-file-utils fprintd geoclue jre-openjdk-headless libng |
Found snapshot: 2022-02-27 20:28:26 | [email protected]_234140482/.snapshots/379/snapshot | pre | pacman -Su |
Found snapshot: 2022-02-27 16:35:17 | [email protected]_234140482/.snapshots/378/snapshot | post | expat garuda-dr460nized geoip-database lib32-libjpeg-turbo libjpeg-turbo |
Found snapshot: 2022-02-27 16:35:15 | [email protected]_234140482/.snapshots/377/snapshot | pre | pacman -Su |
Found snapshot: 2022-02-27 16:34:08 | [email protected]_234140482/.snapshots/376/snapshot | post | electron12 |
Found snapshot: 2022-02-27 16:34:06 | [email protected]_234140482/.snapshots/375/snapshot | pre | pacman -Rns electron12 |
Found snapshot: 2022-02-26 01:32:16 | [email protected]_234140482/.snapshots/374/snapshot | post | yuzu-mainline-bin |
Found snapshot: 2022-02-26 01:32:15 | [email protected]_234140482/.snapshots/373/snapshot | pre | pacman --remove -c -s -- yuzu-mainline-bin |
Found snapshot: 2022-02-26 00:34:57 | [email protected]_234140482/.snapshots/372/snapshot | post | clang expat garuda-dr460nized grub-btrfs intel-media-sdk jdk11-openjdk j |
Found snapshot: 2022-02-26 00:34:40 | [email protected]_234140482/.snapshots/371/snapshot | pre | pacman -Su |
Found snapshot: 2022-02-26 00:31:43 | [email protected]_234140482/.snapshots/370/snapshot | post | yuzu-mainline-bin |
Found snapshot: 2022-02-26 00:31:41 | [email protected]_234140482/.snapshots/369/snapshot | pre | pacman -S yuzu-mainline-bin |
Found snapshot: 2022-02-18 05:40:28 | [email protected]_233800042 | N/A | N/A |
Found snapshot: 2022-02-18 05:23:11 | [email protected]_054028336 | N/A | N/A |
Found snapshot: 2022-02-18 05:21:35 | [email protected]_052311921 | N/A | N/A |
Found snapshot: 2022-02-18 05:17:47 | [email protected]_052135433 | N/A | N/A |
Found snapshot: 2022-02-08 05:05:33 | [email protected]_051747333 | N/A | N/A |
Found snapshot: 2022-02-06 04:01:18 | [email protected]_050533893 | N/A | N/A |
Found snapshot: 2022-02-02 23:12:52 | [email protected]_040118184 | N/A | N/A |
Found snapshot: 2022-02-02 22:46:57 | [email protected]_231252474 | N/A | N/A |
Found snapshot: 2022-02-02 20:53:07 | [email protected]_224657520 | N/A | N/A |
Found 24 snapshot(s)
Unmount /tmp/grub-btrfs.jQvoP2PuWs .. Success
done
Kernel: 5.16.11-1-cachyos x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/[email protected]_205307865/boot/vmlinuz-linux-cachyos
root=UUID=95b636ca-42a5-47b4-9b7a-038581af6cdf rw
[email protected]_205307865 quiet splash
resume=UUID=41193397-191d-45b5-8c2b-405cf71e73b2 loglevel=3
Desktop: KDE Plasma 5.24.2 tk: Qt 5.15.2 info: latte-dock
wm: kwin_wayland vt: 2 dm: SDDM Distro: Garuda Linux base: Arch Linux
Type: Laptop System: ASUSTeK product: X510UA v: 1.0
Mobo: ASUSTeK model: X510UA v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: X510UA.312 date: 04/29/2020
ID-1: BAT0 charge: 6.2 Wh (22.1%) condition: 28.1/42.1 Wh (66.9%)
volts: 11.5 min: 11.5 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: Discharging cycles: 440
Info: model: Intel Core i7-7500U bits: 64 type: MT MCP
arch: Amber/Kaby Lake note: check family: 6 model-id: 0x8E (142)
stepping: 9 microcode: 0xEC
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 2476 high: 2734 min/max: 400/3500 scaling:
driver: intel_pstate governor: performance cores: 1: 2511 2: 2678 3: 1983
4: 2734 bogomips: 23220
Type: l1tf
Device-1: Intel HD Graphics 620 vendor: ASUSTeK driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:5916 class-ID: 0300
Device-2: IMC Networks VGA UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-6:3 chip-ID: 13d3:5a07 class-ID: 0e02 serial: <filter>
Display: wayland server: X.Org 1.22.1 compositor: kwin_wayland driver:
loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.0x11.3")
s-diag: 583mm (23")
Monitor-1: XWAYLAND0 res: 1920x1080 hz: 60 dpi: 143
size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.3.7
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK
Sound Server-1: ALSA v: k5.16.11-1-cachyos running: yes
Sound Server-3: PipeWire v: 0.3.47 running: yes
Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel
bus-ID: 02:00.0 chip-ID: 8086:24fd class-ID: 0280
bus-ID: 1-8:4 chip-ID: 8087:0a2b class-ID: e001
address: <filter>
Local Storage: total: 961.34 GiB used: 102.87 GiB (10.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 500GB
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO M.2 500GB
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: SanDisk
model: Cruzer Force size: 29.81 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: 1.00 scheme: MBR
ID-1: / raw-size: 448.4 GiB size: 448.4 GiB (100.00%)
used: 102.84 GiB (22.9%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
used: 27.9 MiB (9.3%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 448.4 GiB size: 448.4 GiB (100.00%)
ID-4: /var/log raw-size: 448.4 GiB size: 448.4 GiB (100.00%)
ID-5: /var/tmp raw-size: 448.4 GiB size: 448.4 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.51 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 17.06 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 57.0 C pch: 44.5 C mobo: N/A
Fan Speeds (RPM): cpu: 3100
Processes: 254 Uptime: 9m wakeups: 1 Memory: 15.51 GiB
used: 3.12 GiB (20.1%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1567 lib: 391 Shell: fish
v: 3.3.1 running-in: konsole inxi: 3.3.12
Garuda (2.5.5-1):
System install date: 2022-02-23
Last full system update: 2022-02-28
Failed units: systemd-sysctl.service
Invalid snapshot '--type'.
==> root:
(8/8) Syncing all file systems...
