Missing opengl 2 (or higher)
hey, i was sick of seeing all of those "packet x is not in any mirrorlist" or something along those lines info messages for the updates so i added garuda, anyways i've just noticed that i can not open cura, it gives me a error Could not probe OpenGL. This program requires OpenGL 2.0 or higher. Please check your video card drivers. and the OpenGL info thingy told me indeed my laptop is running opengl 1.4, but as stated above i need at least 2.0, so on the amd website i went. my laptop uses the amd ryzen 5 3500U APU and the only drivers they have on there are for windows... is there any other way to get opengl 2 or higher on the laptop?
inxi:
  Kernel: 5.18.10-hardened1-1-hardened arch: x86_64 bits: 64 compiler: gcc
    v: 12.1.0 parameters: pti=on page_alloc.shuffle=1
    BOOT_IMAGE=/@/boot/vmlinuz-linux-hardened
    root=UUID=d16ddc96-5d12-402f-bbcb-9fa585484f0b rw rootflags=subvol=@
    cryptdevice=UUID=3c647ba3-56c7-43a5-bafc-5f6213b05312:luks-3c647ba3-56c7-43a5-bafc-5f6213b05312
    root=/dev/mapper/luks-3c647ba3-56c7-43a5-bafc-5f6213b05312
  Desktop: KDE Plasma v: 5.25.2 tk: Qt v: 5.15.5 info: latte-dock
  Type: Laptop System: LENOVO product: 82C7 v: Lenovo V15-ADA
    serial: <superuser required> Chassis: type: 10 v: Lenovo V15-ADA
  Mobo: LENOVO model: LNVNB161216 v: No DPK serial: <superuser required>
    UEFI: LENOVO v: E8CN30WW date: 07/28/2021
  ID-1: BAT0 charge: 12.5 Wh (35.2%) condition: 35.5/35.3 Wh (100.6%)
    volts: 7.5 min: 7.6 model: CPT-COS L16C2PB1 type: Li-poly serial: <filter>
    status: discharging cycles: 9
  Info: model: AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx bits: 64
    type: MT MCP arch: Zen/Zen+ note: check gen: 1 built: 2019 process: GF 12nm
    family: 0x17 (23) model-id: 0x18 (24) stepping: 1 microcode: 0x8108109
    L3: 4 MiB desc: 1x4 MiB
  Speed (MHz): avg: 1244 high: 1348 min/max: 1400/2100 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1275 2: 1348
    3: 1224 4: 1221 5: 1222 6: 1222 7: 1222 8: 1221 bogomips: 33547
    vendor: Lenovo driver: amdgpu v: kernel arch: GCN 5 process: GF 14nm
    built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports: active: eDP-1
    empty: HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:15d8 class-ID: 0300
  Device-2: IMC Networks Integrated Camera type: USB driver: uvcvideo
    bus-ID: 3-1:2 chip-ID: 13d3:5a08 class-ID: 0e02 serial: <filter>
  Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x0812 built: 2018
    res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
  OpenGL: renderer: AMD Radeon Vega 8 Graphics (raven LLVM 14.0.6 DRM 3.46
  5.18.10-hardened1-1-hardened)
    v: 4.6 Mesa 22.1.3 direct render: Yes
  Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Lenovo
    bus-ID: 03:00.1 chip-ID: 1002:15de class-ID: 0403
    driver: snd_pci_acp3x v: kernel
    alternate: snd_rn_pci_acp3x,snd_pci_acp5x,snd_pci_acp6x,snd_acp_pci,snd_sof_amd_renoir
    pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 03:00.5 chip-ID: 1022:15e2
    class-ID: 0480
  Sound Server-1: ALSA v: k5.18.10-hardened1-1-hardened running: yes
  Sound Server-3: PipeWire v: 0.3.54 running: yes
  Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
    vendor: Lenovo driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 bus-ID: 02:00.0 chip-ID: 168c:003e class-ID: 0280
  Device-1: Qualcomm Atheros QCA61x4 Bluetooth 4.0 type: USB driver: btusb
    v: 0.8 bus-ID: 3-2:3 chip-ID: 0cf3:e300 class-ID: e001
    address: <filter>
  Local Storage: total: 700.51 GiB used: 221 GiB (31.5%)
    model: MZALQ512HALU-000L2 size: 476.94 GiB block-size: physical: 512 B
    rev: BL2QFXV7 temp: 23.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT240BX500SSD1
    type: SSD serial: <filter> rev: 052 scheme: GPT
    used: 221 GiB (47.2%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-3c647ba3-56c7-43a5-bafc-5f6213b05312
    used: 736 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-1: swap-1 type: zram size: 5.68 GiB used: 1.5 MiB (0.0%) priority: 100
    mapped: luks-48d04c79-6793-4578-a7bd-b7f3baa922dc
  System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 32.0 C
  Processes: 272 Uptime: 16m wakeups: 23690 Memory: 5.68 GiB
  used: 3.06 GiB (53.9%) Init: systemd v: 251 default: graphical
  tool: systemctl Compilers: gcc: 12.1.0 Packages: pacman: 1328 lib: 352
  Shell: Bash v: 5.1.16 running-in: konsole inxi: 3.3.19
e[1;34mGaruda (2.6.4-2):e[0m
e[1;34m  System install date:e[0m     2022-06-18
e[1;34m  Last full system update:e[0m 2022-07-10
e[1;34m  Is partially upgraded:  e[0m No
e[1;34m  Relevant software:      e[0m NetworkManager
e[1;34m  Windows dual boot:      e[0m Probably (Run as root to verify)
e[1;34m  Snapshots:              e[0m Snapper
e[1;34m  Failed units:           e[0m
You already have OpenGL 4.6
Could you try any different kernel, perhaps hardened is preventing OpenGL access?
i've just tried zen and the plain linux kernel, but neither of them worked, why does the glx thingy tell me i'm running 1.4 if the inxi says it's 4.6 ?
Are you using the appimage package?
If so, it could be this bug
and especially relevant linked bug:
i do, the latest update wasn't in the aur yet, and the older ones seem really bugged, thank you that worked for now
